VW Golf Biagini Passo
Based on the Golf Country, with body from an VW Golf 1 Convertible. 4X4 four seat convertible by VW and a slightly modified body from the normal convertible. It was built in Italy by FIAT.
Four different models of the rare Biagini Passo was built.
Passo 1.8i L Plus fromf 11/1991 to 12/1993
Passo 1.8i LX from 12/1990 to 11/1991
Passo 1.8i LX (with catalyst) from 11/1991 to 12/1993
Passo 1.8i L from 12/1990 to 11/1991 (this model had an weaker engine... about 88Hp.)
The technical data of the VW Golf Biagini Passo
Engine: 1,8 l-four-cylinder engine with 98 HP (72 kW), Catalyst, 5 speed gearbox
Drive: Permanent all-wheel-drive with viscous coupling
Measure:
Length 4255 mm
With 1705 mm
Height 1555mm
Wheelbase 2480 mm
Width of track front/rear 1435/1443 mm
Turning circle 10,5 m
Wheels 6 J x 15
Tires 195/60 R 15
Weight:
Weight when empty 1245 kg
Totally weight 1640kg
Maximum speed: 155Km/h
Acceleration: 0-80 km/h 8,2Sec. 0-100 km/h 12,3Sec
Fuel consumption: unlead petrol
With constant 90Km/h 8,5l
With constant 120Km/h 11,4l
In city traffic 11,9l
