Някой може ли да разчете този лог фаил? интересува ме,дебитомера как е .
Sunday,24,September,2023,15:24:29
038 906 019 CJ,, Brezel EDC 0000SG 1045,
,Group A:,'010,,,,Group B:, Not Running,,,,Group C:, Not Running
,,MAF,Atmos. pressure,Intake air press.,Throttle,,,,,,,,,,
,TIME,850-1050,sensor -f96-,2000-2200,100%,TIME,,,,,TIME,,,,
Marker,STAMP, mg/str, mbar, mbar,%,STAMP,,,,,STAMP,,,,
,0.01,431.2,938.4,979.2,0.0,,,,,,,,,,
,0.34,436.1,938.4,979.2,0.0,,,,,,,,,,
,0.70,431.2,938.4,979.2,0.0,,,,,,,,,,
,1.06,431.2,938.4,979.2,0.0,,,,,,,,,,
,1.41,421.4,938.4,979.2,0.0,,,,,,,,,,
,1.75,431.2,938.4,979.2,0.0,,,,,,,,,,
,2.09,387.1,938.4,979.2,82.0,,,,,,,,,,
,2.45,460.6,938.4,1009.8,32.5,,,,,,,,,,
,2.79,539.0,938.4,1122.0,25.9,,,,,,,,,,
,3.14,519.4,938.4,1162.8,46.7,,,,,,,,,,
,3.48,583.1,938.4,1234.2,20.8,,,,,,,,,,
,3.83,539.0,938.4,1213.8,21.6,,,,,,,,,,
,4.17,499.8,938.4,1162.8,27.1,,,,,,,,,,
,4.51,480.2,938.4,1142.4,32.5,,,,,,,,,,
,4.86,509.6,938.4,1183.2,42.7,,,,,,,,,,
,5.20,671.3,938.4,1315.8,0.0,,,,,,,,,,
,5.56,524.3,938.4,1285.2,18.4,,,,,,,,,,
,5.91,607.6,938.4,1264.8,61.6,,,,,,,,,,
,6.25,563.5,938.4,1285.2,71.0,,,,,,,,,,
,6.61,602.7,938.4,1336.2,72.9,,,,,,,,,,
,6.97,686.0,938.4,1458.6,75.7,,,,,,,,,,
,7.31,798.7,938.4,1683.0,0.0,,,,,,,,,,
,7.66,499.8,938.4,1366.8,12.9,,,,,,,,,,
,8.00,578.2,938.4,1275.0,51.8,,,,,,,,,,
,8.35,578.2,938.4,1295.4,51.8,,,,,,,,,,
,8.71,588.0,938.4,1336.2,56.5,,,,,,,,,,
,9.05,627.2,938.4,1387.2,55.3,,,,,,,,,,
,9.41,666.4,938.4,1468.8,48.2,,,,,,,,,,
,9.75,725.2,938.4,1591.2,47.5,,,,,,,,,,
,10.10,793.8,938.4,1713.6,78.4,,,,,,,,,,
,10.46,975.1,938.4,1968.6,100.0,,,,,,,,,,
,10.80,1141.7,938.4,2284.8,100.0,,,,,,,,,,
,11.15,1244.6,938.4,2539.8,100.0,,,,,,,,,,
,11.50,975.1,938.4,2223.6,100.0,,,,,,,,,,
,11.85,965.3,938.4,2080.8,100.0,,,,,,,,,,
,12.19,970.2,938.4,2070.6,100.0,,,,,,,,,,
,12.54,1014.3,938.4,2142.0,100.0,,,,,,,,,,
,12.91,1053.5,938.4,2244.0,100.0,,,,,,,,,,
,13.27,1029.0,938.4,2264.4,100.0,,,,,,,,,,
,13.63,1004.5,938.4,2223.6,100.0,,,,,,,,,,
,13.98,984.9,938.4,2213.4,100.0,,,,,,,,,,
,14.33,705.6,938.4,2029.8,0.0,,,,,,,,,,
,14.67,602.7,938.4,1591.2,0.0,,,,,,,,,,
,15.03,553.7,938.4,1366.8,0.0,,,,,,,,,,
,15.38,485.1,938.4,1244.4,0.0,,,,,,,,,,
,15.73,470.4,938.4,1142.4,0.0,,,,,,,,,,
,16.08,450.8,938.4,1091.4,0.0,,,,,,,,,,
,16.42,441.0,938.4,1060.8,0.0,,,,,,,,,,
,30.33,514.5,938.4,1213.8,27.1,,,,,,,,,,
,30.67,539.0,938.4,1224.0,27.1,,,,,,,,,,
,31.02,543.9,938.4,1244.4,44.3,,,,,,,,,,
,31.36,592.9,938.4,1305.6,100.0,,,,,,,,,,
,31.70,641.9,938.4,1407.6,100.0,,,,,,,,,,
,32.03,730.1,938.4,1550.4,100.0,,,,,,,,,,
,32.39,857.5,938.4,1785.0,100.0,,,,,,,,,,
,32.75,1063.3,938.4,2101.2,100.0,,,,,,,,,,
,33.10,1249.5,938.4,2448.0,100.0,,,,,,,,,,
,33.44,1029.0,938.4,2448.0,100.0,,,,,,,,,,
,33.80,970.2,938.4,2131.8,100.0,,,,,,,,,,
,34.14,984.9,938.4,2091.0,100.0,,,,,,,,,,
,34.49,1009.4,938.4,2121.6,100.0,,,,,,,,,,
,34.83,1024.1,938.4,2193.0,100.0,,,,,,,,,,
,35.18,1024.1,938.4,2254.2,100.0,,,,,,,,,,
,35.52,1009.4,938.4,2233.8,100.0,,,,,,,,,,
,35.87,975.1,938.4,2193.0,100.0,,,,,,,,,,
,36.21,656.6,938.4,1856.4,0.0,,,,,,,,,,
,36.55,583.1,938.4,1519.8,0.0,,,,,,,,,,
,36.91,543.9,938.4,1336.2,0.0,,,,,,,,,,
,37.27,470.4,938.4,1213.8,0.0,,,,,,,,,,
,37.62,480.2,938.4,1132.2,0.0,,,,,,,,,,
,37.96,436.1,938.4,1081.2,0.0,,,,,,,,,,
,38.30,445.9,938.4,1050.6,0.0,,,,,,,,,,
,38.64,441.0,938.4,1030.2,0.0,,,,,,,,,,
,38.99,431.2,938.4,1020.0,0.0,,,,,,,,,,
,39.33,441.0,938.4,1009.8,0.0,,,,,,,,,,
,39.68,411.6,938.4,999.6,0.0,,,,,,,,,,
Дебитомер 1.9 AJM 115к.с.
Re: Дебитомер 1.9 AJM 115к.с.
По този лог не може да се определи дали е ок, защото си хванал само с групата на реално даваното количество. Трябва да изведеш и стойностите, които компа търси и след това се прави сравнение с полученото давано и така се хваща.
По този лог се вижда, че дебитомера работи, това е сигурно, защото стойностите се променят в голям диапазон, но дали работи правилно не може да се каже.
- lubomir911
- Регистриран на: Сря 17 ное 2021 11:37
- Автомобил: vw Bora
- Двигател: AJM 2000
благодаря за отговора! На кой канал трябва да направя лог?
Колата върви нормално до момента в който не започна изпреварване.Като чели леко тресе, губи малко мощност и започва да пуши черно. За това мисля, че може дебитомера да не сработва нещо...
Това са логове на 3,10 и 11 канал
- Прикачени файлове
- LOG-тнтн.zip
- (859 Байтове) Свален 24 пъти
- LOG-01-003-010-011.zip
- (1.12 KиБ) Свален 23 пъти
- lubomir911
Monday,25,September,2023,10:48:44
,Group A:,'003,,,,Group B:,'010,,,,Group C:,'011
,,Engine speed,MAF (specified),MAF (actual),EGR duty cycle,,MAF,Atmos. pressure,Intake air press.,Throttle,,Engine speed,Spec. intake press.,Actual intake press.,D.cycle MAP
,TIME,820-900,230-420,230-420,10-95%,TIME,850-1050,sensor -f96-,2000-2200,100%,TIME,2850-3150,2000-2150,2000-2200,40-95%
Marker,STAMP, /min, mg/str, mg/str, %,STAMP, mg/str, mbar, mbar,%,STAMP, /min, mbar, mbar, %
,0.36,1218,850.0,504.7,4.8,0.72,524.3,938.4,1111.8,100.0,0.01,1176,1203.6,1060.8,29.1
,1.44,1365,850.0,553.7,4.8,1.80,602.7,938.4,1264.8,100.0,1.08,1302,1774.8,1152.6,21.5
,2.52,1575,850.0,705.6,4.8,2.88,774.2,938.4,1621.8,100.0,2.16,1491,2091.0,1346.4,24.7
,3.60,1869,850.0,1029.0,4.8,3.96,1225.0,938.4,2346.0,100.0,3.24,1764,2213.4,1825.8,47.8
,4.68,2310,850.0,1009.4,4.8,5.04,1029.0,938.4,2121.6,100.0,4.32,2163,2213.4,2386.8,71.7
,5.76,2709,850.0,1063.3,4.8,6.12,1033.9,938.4,2233.8,100.0,5.40,2562,2213.4,2182.8,67.7
,6.84,3087,850.0,999.6,4.8,7.20,994.7,938.4,2193.0,100.0,6.48,2982,2213.4,2203.2,68.5
,7.92,3423,850.0,960.4,4.8,8.28,960.4,938.4,2182.8,100.0,7.56,3318,2213.4,2193.0,68.5
,9.00,3612,850.0,955.5,4.8,9.36,661.5,938.4,1825.8,0.0,8.64,3633,2213.4,2182.8,68.1
,10.08,1869,850.0,553.7,4.8,10.44,480.2,938.4,1224.0,0.0,9.72,2436,1193.4,1530.0,42.6
,11.16,924,850.0,455.7,19.9,11.52,450.8,938.4,1040.4,0.0,10.79,1029,1040.4,1132.2,28.7
Monday,25,September,2023,10:46:49
,0.36,1806,850.0,837.9,4.8,0.72,1024.1,948.6,1917.6,100.0,0.01,1722,1734.0,1479.0,29.9
,1.44,2184,850.0,1244.6,4.8,1.80,1087.8,948.6,2264.4,100.0,1.08,2016,2213.4,2264.4,65.7
,2.52,2541,850.0,1087.8,4.8,2.87,1107.4,948.6,2213.4,100.0,2.16,2415,2213.4,2121.6,63.4
,3.60,2898,850.0,1063.3,4.8,3.95,1014.3,948.6,2172.6,100.0,3.23,2772,2213.4,2223.6,67.3
,4.68,3213,850.0,1014.3,4.8,5.04,1004.5,948.6,2182.8,100.0,4.31,3108,2213.4,2172.6,65.7
,5.74,3465,850.0,989.8,4.8,6.10,666.4,948.6,1805.4,0.0,5.37,3402,2213.4,2193.0,66.1
,6.81,1701,850.0,534.1,4.8,7.17,504.7,948.6,1142.4,0.0,6.45,2247,1193.4,1448.4,42.6
,7.90,903,850.0,450.8,19.9,8.25,455.7,948.6,1020.0,0.0,7.53,945,1040.4,1081.2,28.7
,39.17,1764,850.0,813.4,4.8,38.46,637.0,938.4,1377.0,27.8,38.81,1764,2080.8,1387.2,36.3
,40.25,1932,850.0,1220.1,4.8,39.53,965.3,938.4,1825.8,100.0,39.89,1869,2213.4,2131.8,59.4
,41.31,2142,850.0,1117.2,4.8,40.59,1141.7,938.4,2305.2,100.0,40.95,2058,2213.4,2244.0,64.5
,42.39,2331,850.0,1127.0,4.8,41.67,1122.1,938.4,2233.8,100.0,42.03,2268,2213.4,2254.2,67.3
,43.47,2520,850.0,1063.3,4.8,42.75,1112.3,938.4,2244.0,100.0,43.11,2457,2213.4,2203.2,67.7
,44.54,2688,850.0,1068.2,4.8,43.82,1068.2,938.4,2162.4,100.0,44.19,2646,2213.4,2193.0,67.7
,45.63,2856,850.0,1048.6,4.8,44.91,1053.5,938.4,2213.4,100.0,45.27,2793,2213.4,2213.4,67.7
,46.71,3003,850.0,1024.1,4.8,45.99,1043.7,948.6,2213.4,100.0,46.34,2961,2213.4,2203.2,67.7
,47.77,3129,850.0,1004.5,4.8,47.06,1024.1,948.6,2203.2,100.0,47.41,3087,2213.4,2203.2,67.7
,48.85,3150,850.0,975.1,4.8,48.13,999.6,948.6,2213.4,100.0,48.49,3234,2213.4,2213.4,68.5
,49.93,3087,850.0,499.8,4.8,49.20,558.6,948.6,1581.0,0.0,49.57,3150,1244.4,1377.0,42.6
Според мен дебитомера ти е ОК.
Ето източника, на който се базирам: https://www.ross-tech.com/vag-com/cars/tdi.html
Цитирам по-конкретно, как се тества дебитомера:
Air system part I: MAF
Go into Engine measuring block 003
Start Logging data
In a high gear (4th/5th), give full throttle from 2500 rpm up to 3500rpm.
Find and Open the Log file in Windows Explorer
Graph MAF actual -vs- rpm in Excel
The MAF is OK if the actual value is at least 850-900 mg/h at 3000 rpm.
При теб при последните 2 лога виждам, че критерия е изпълнен и при 100% натиснат педал на газта и на 3000 и над 3000 оборота имаш стойности: 960, 999, 1004, 1048.
Също се вижда и, че турбото дава колкото се иска, тоест проблема не е и от него.
По симптомите които описваш на мен ми прилича много на тръгнали дюзи, помпа или съединител(заради тресенето) или комбинация от тези.
Черният пушек е симптом на много богата смес, тоест влиза много нафта в цилиндрите и недоизгаря. Това е нормално при TDI от тези години при кик-даун в първия момент, но ако пуши продължително докато изпреварваш нещата не са добре.
Start Logging data
- lubomir911
railfan написа:Според мен дебитомера ти е ОК.
Start Logging data
Благодаря за изчерпателната информация! Съединител и демпфер са чисто нови. Предния собственик каза, че я е чипосвал някъде в Годеч, не знам има ли значение.От скоро почна да прави тези номера. По принцип върви много.Този проблем става на високи предавки примерно на 5-та и 6-та скорост на магистрала карам с 120 и искам да изпреварвам, натискам педала на газта, колата почва да ускорява и в един момент усещам нещо като задържане и леко прекъсване, и тогава почва да пуши черно, и пуши постоянно докато не върна газта. Дюзите ги гледах на ПХ и стойностите им бяха близки до 0. Мога ли нещо друго да проверя?
Последна промяна от lubomir911 на Вто 26 сеп 2023 14:56, променено общо 2 пъти.
- lubomir911
Ходих и на димомер да замерват димността и резултата беше много добър. Средна димност 0,18( m-1) от норма 1,5(m-1) , на място като я форсирам с рязко натискане на педала до долу също няма никакъв дим
Щом колата е чипосвана, това обяснява нещата. Най - вероятно проблема идва от чипа, зависи как е настройвана, трябваше с това да почнеш.
В Годеч чипират Адлер ауто - вероятно там е чипосвана и по принцип ги водят читави тези мапери. Вариант е да отидеш да си я оправят, или да намериш някой да ти върне фабричният софтуер.
- lubomir911
Това е много добра идея.Не се сещах, че може да е от чипа. Ще трябва да се разходя до Годеч да видим какво ще кажат.
Благодаря ти още един път!
Потребители, разглеждащи този форум: simo7 и 52 госта
