Код: Избери всички
VCDS
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 20.4.2 Data version: 20200807 DS317.0
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Wednesday,16,August,2023,22:00:17:51107
VIN: WVWZZZ3CZ8E246902 License Plate:
Mileage: 251790km-156455mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 55 56 62 6D 72 76
VIN: WVWZZZ3CZ8E246902 Mileage: 251790km-156455miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 1010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Sporadic communication error 1000
6D-Trunk Elect. -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Cannot be reached 1100
76-Park Assist -- Status: Cannot be reached 1100
VCDS
Self-Diagnosis Log
Page 2
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BL HW: 03L 907 309
Component: R4 2.0l TDI G001SG 9977
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 43486 002 1048576
VCID: 708509B4838410A683-8024
2 Faults Found:
049682 - Steering Column Control Module
U0212 - 000 - No Communications - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 251797 km
Time Indication: 0
Date: 2023.08.02
Time: 01:29:26
Freeze Frame:
RPM: 782 /min
Speed: 0.0 km/h
Temperature: 28.8°C
Voltage: 13.68 V
Bin. Bits: 00000000
Torque: 0.0 Nm
Temperature: 45.9°C
049508 - No Communications with HVAC Control Module (J301)
U0164 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 251797 km
Time Indication: 0
Date: 2023.08.02
Time: 01:29:27
Freeze Frame:
RPM: 782 /min
Speed: 0.0 km/h
Temperature: 28.8°C
Voltage: 13.76 V
Bin. Bits: 00000000
Torque: 0.0 Nm
Temperature: 45.9°C
Readiness: 0 0 0 0 1
VCDS
Self-Diagnosis Log
Page 3
VIN: WVWZZZ3CZ8E246902 License Plate: ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 J HW: 3C0 614 109 J
Component: J104 C4 440 V1 0005
Revision: --020--- Serial number: 00000785549348
Coding: 0000267
Shop #: WSC 05311 000 00000
VCID: 253EA755F70B52932B-8070
2 Faults Found:
00474 - Control Module for Immobilizer
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 13
Reset counter: 204
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:35
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 13.75 V
Bin. Bits: 00011111
Count: 215
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 204
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:35
VCDS
Self-Diagnosis Log
Page 4
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 DA HW: 3C0 907 044 DA
Component: ClimatronicPQ46 132 0811
Revision: 00132023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 637023EBCFC5C64D3B-8036
4 Faults Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01110010
Fault Priority: 3
Fault Frequency: 11
Reset counter: 206
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:40:36
01592 - Air Quality Sensor (G238)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 6
Reset counter: 206
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:40:37
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 246
Mileage: 251747 km
Time Indication: 0
Date: 2023.08.02
Time: 12:58:56
01810 - Actuating Motor for Temperature Flap; Right (V159)
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 251772 km
VCDS
Self-Diagnosis Log
Page 5
Time Indication: 0
Date: 2023.08.02
Time: 13:30:22
VCDS
Self-Diagnosis Log
Page 6
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000008330070
Coding: E78A8F0700041A00470A00000F000000000B5D435C000100000000000000 Shop #: WSC 05124 000 00000
VCID: 71820FB1878F1AAF8B-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 210308 003 0205
Coding: 00046997
Shop #: WSC 05124
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 110810 054 0403
Coding: 00209069
Shop #: WSC 05124
10 Faults Found:
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01111010
Fault Priority: 1
Fault Frequency: 2
Reset counter: 206
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 13.80 V
ON
ON
OFF
OFF
ON
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 206
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:41:00
Freeze Frame:
VCDS
Self-Diagnosis Log
Page 7
ON
Voltage: 12.45 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 246
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:00
Freeze Frame:
ON
Voltage: 13.75 V
ON
ON
OFF
OFF
ON
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 251772 km
Time Indication: 0
Date: 2023.08.02
Time: 13:28:00
Freeze Frame:
OFF
Voltage: 12.60 V
OFF
ON
OFF
OFF
OFF
01314 - Engine Control Module
VCDS
Self-Diagnosis Log
Page 8
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.00 V
ON
ON
OFF
OFF
OFF
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 206
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:41:00
Freeze Frame:
ON
Voltage: 12.45 V
ON
ON
OFF
OFF
OFF
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
VCDS
Self-Diagnosis Log
Page 9
Voltage: 14.00 V
ON
ON
OFF
OFF
OFF
00153 - Windshield Wiper Motor; Driver Side (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.90 V
ON
ON
OFF
OFF
OFF
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.00 V
ON
ON
OFF
OFF
OFF
01309 - Power Steering Control Module (J500)
Freeze Frame:
VCDS
Self-Diagnosis Log
Page 10
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.00 V
ON
ON
OFF
OFF
OFF
------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__005 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP8CFV1V
Coding: 0012341
VCID: 3B487313AFFDD635FB-806E
Subsystem 1 - Serial number: 6333FTS693940878
Subsystem 2 - Serial number: 6343FTS664621018
Subsystem 3 - Serial number: 6353ETS6SV98TVNH
Subsystem 4 - Serial number: 6363ETS6RN39TVNP
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
No fault code found. -------------------------------------------------------------------------------
VCDS
Self-Diagnosis Log
Page 11
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 AE HW: 3C0 953 549 AE
Component: J0527 0020
Revision: 00026000 Serial number: 3C9953507AT
Coding: 0000112
VCID: 6F840BB79FF90E999B-803A
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
2 Faults Found:
014 - Defective - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 E HW: 3C0 920 871 E
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 65536 645 577705
VCID: 263FA552FB16549853-8072
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 24
Reset counter: 246
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:36
VCDS
Self-Diagnosis Log
Wednesday,16,August,2023,22:00:18:51107
Page 12
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P084260064
Coding: F9817F0E0202022002
VCID: 2330A3ABCF05468D3B-8076
14 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 204
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:42:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 204
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:42:40
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 204
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:42:44
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Reset counter: 246
VCDS
Self-Diagnosis Log
Page 13
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Reset counter: 246
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:36
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 246
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:36
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 246
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:36
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Reset counter: 246
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:36
VCDS
Self-Diagnosis Log
Page 14
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Reset counter: 246
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:36
00457 - Central Electronics Control Module / BCM (J519)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 246
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:37
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Reset counter: 246
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:37
00317 - Rear Lid Control Module (J605)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Reset counter: 246
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:37
00470 - Company Comfort Databus in Single Wire
012 - Electrical Fault in Circuit
Freeze Frame:
VCDS
Self-Diagnosis Log
Page 15
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 206
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:46:26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 206
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:46:26
VCDS
Self-Diagnosis Log
Page 16
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 799 G HW: 3C0 959 799 G
Component: IMMO 070 0383
Revision: 00070000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 3D56771D5783223BEB-8068
Subsystem 1 - Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
3 Faults Found:
01176 - Key
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 204
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:46:34
02828 - Enabling Steering Column Lock from Diagnostic Interface
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 244
Time Indication: 0
02829 - Enabling Steering Column Lock from Steering Wheel Electronics
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 244
Time Indication: 0
VCDS
Self-Diagnosis Log
Page 17
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1131
Revision: 31008001 Serial number: 00000288288421
Coding: 0000247
VCID: 3C49711053F8D832E3-8068
2 Faults Found:
Freeze Frame:
Fault Status: 00101110
Fault Priority: 4
Fault Frequency: 6
Reset counter: 246
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 18
Reset counter: 246
Time Indication: 0
------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.135 H08 1901
Shop #: WSC 02069 000 90108
VCID: 354E8765B7DBF203AB-8060
1 Fault Found:
000 - -
VCDS
Self-Diagnosis Log
Page 18
Address 46: Central Conv. Labels:. 3C0-959-799-46.clb
Component: KESSY PQ46 R 070 0227
Coding: 00900A00D1430E763004941570004F0B607C01030404A0
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
10 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 206
Mileage: 251797 km
Time Indication: 0
Date: 2023.08.02
Time: 01:27:54
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 206
Mileage: 251797 km
Time Indication: 0
Date: 2023.08.02
Time: 01:27:54
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 246
Time Indication: 0
Freeze Frame:
VCDS
Self-Diagnosis Log
Page 19
Fault Priority: 4
Fault Frequency: 1
Reset counter: 246
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 246
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 246
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 246
Time Indication: 0
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 246
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 246
Time Indication: 0
VCDS
Self-Diagnosis Log
Page 20
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 246
Time Indication: 0
------------------------------------------------------------------------------- Address 52: Door Elect, Pass.
Cannot be reached
VCDS
Self-Diagnosis Log
Page 21
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000457088
Coding: 0000056
VCID: 293A9F59E727AAB74B-807C
3 Faults Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 13
Reset counter: 206
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:35
Freeze Frame:
Voltage: 13.30 V
Count: 36
Speed: 0.0 km/h
Hex Value: 0x12E1
Hex Value: 0x0001
Hex Value: 0x1010
00576 - Terminal 15
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 246
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:44
Freeze Frame:
Voltage: 12.80 V
Count: 54
Speed: 0.0 km/h
Hex Value: 0x1271
Hex Value: 0x0001
Hex Value: 0x1010
Freeze Frame:
VCDS
Self-Diagnosis Log
Page 22
Fault Priority: 3
Fault Frequency: 13
Reset counter: 206
Mileage: 251746 km
Time Indication: 0
Date: 2023.08.02
Time: 18:45:44
Freeze Frame:
Voltage: 12.70 V
Count: 76
Speed: 0.0 km/h
Hex Value: 0x1271
Hex Value: 0x0001
Hex Value: 0x1010
VCDS
Self-Diagnosis Log
Page 23
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 B HW: 5M0 907 357 B
Component: AFS-Steuergeraet X024
Revision: 00H01000 Serial number:
Coding: 2311169
VCID: 3340837B8FD5E6FDBB-8066
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000035
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 206
Mileage: 251797 km
Time Indication: 0
Date: 2023.08.02
Time: 01:30:23
Freeze Frame:
Voltage: 12.78 V
Speed: 0.0 km/h
ABS 1
VCDS
Self-Diagnosis Log
Page 24
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 AD
Component: Radio GR0 034 0033
Revision: 0003404S Serial number: VWZ2Z2H7626524
Coding: 0040400
Shop #: WSC 05314 000 00000
VCID: 687D199CE3DC206E43-803C
3 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
00849 - S-contact at Ignition/Starter Switch (D)
004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000000363297
Coding: 0000208
VCDS
Self-Diagnosis Log
Page 25
Address 6D: Trunk Elect. Labels: 3C9-827-383.clb
Part No SW: 3C9 827 383 B HW: 3C9 827 383 E
Component: J605 HECKDECKEL 0600
Revision: 00H27001
Shop #: WSC 23250 384 715754
VCID: 3045897483C490E683-8064
Subsystem 1 - Part No: 3C9 827 384 B
Component: J756 HECKDECKEL 0600
Subsystem 2 - Serial number: 0800H27001001A0160ÿ
5 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 29
Reset counter: 246
Mileage: 251696 km
Time Indication: 0
Date: 2023.08.02
Time: 08:09:45
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 246
Mileage: 251696 km
Time Indication: 0
Date: 2023.08.02
Time: 08:09:45
Freeze Frame:
Fault Priority: 6
Fault Frequency: 28
Reset counter: 246
Mileage: 251696 km
Time Indication: 0
Date: 2023.08.02
Time: 08:09:45
Freeze Frame:
VCDS
Self-Diagnosis Log
Page 26
Fault Priority: 6
Reset counter: 246
Mileage: 251696 km
Time Indication: 0
Date: 2023.08.02
Time: 08:09:45
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 246
Mileage: 251697 km
Time Indication: 0
Date: 2023.08.02
Time: 08:14:03
------------------------------------------------------------------------------- Address 72: Door, Rear Right
Cannot be reached
------------------------------------------------------------------------------- Address 76: Park Assist
Cannot be reached
End-------------------------(Elapsed Time: 02:45)--------------------------
