VCDS (VAG-COM) - работа и грешки
Re: VCDS (VAG-COM) - работа и грешки
Здравейте, имам една VW джета 2015 година 1.8 TSI. При студена оборотие не ги поддържа като загрее си работи нормално. От време на време свети чека, не винаги в VAG-a вади следните грешки.
3 Faults Found:
15072 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2023.11.14
Time: 14:50:03
Engine RPM: 1399.75 /min
Normed load value: 13.3 %
Vehicle speed: 0 km/h
Coolant temperature: 58 °C
Intake air temperature: 47 °C
Ambient air pressure: 940 mbar
Voltage terminal 30: 11.855 V
Unlearning counter according OBD: 33
Engine: operating status: IS
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 0 s
MAP_MES_SAE: 40 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.041 V
FAC_TPS_1_SAE: 14.843750 %
FUP_H_SAE: 7770.0 kPa
14868 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 00 [104] - Incorrect Correlation
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 182009 km
Date: 2023.11.14
Time: 16:55:54
Engine RPM: 784.25 /min
Normed load value: 22.4 %
Vehicle speed: 1 km/h
Intake air temperature: 21 °C
Voltage terminal 30: 14.179 V
Unlearning counter according OBD: 40
STATE_LS_SAE[1]: CL
T_AST_SAE: 434 s
MAP_MES_SAE: 56 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 13.671875 %
FUP_H_SAE: 14890.0 kPa
14870 - Bank 1: Camshaft A (Intake)
P0011 00 [096] - Retard Setpoint not Reached (Over-Advanced)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 182014 km
Date: 2023.11.14
Time: 16:31:12
Engine RPM: 1727.00 /min
Normed load value: 49.8 %
Vehicle speed: 55 km/h
Coolant temperature: 83 °C
Intake air temperature: 44 °C
Voltage terminal 30: 14.082 V
Unlearning counter according OBD: 34
Engine: operating status: PL
CAM_VCP[IN_1]: -1.313 °
CAM_SP_IND_VCP[IN_1]: 40.500 °
T_AST_SAE: 373 s
Engine oil temperature: 91.0 °C
PWM_HLD_VCP[IN_1]: 31.787 %
STATE_PWM_VCP[IN_1]: ACT
Readiness: 0000 0100
Веригата не е сменяна около 185 хиляди е. Не трака и няма шумове. Свещите са подменени с нови. От какво може да е проблема?
3 Faults Found:
P1570 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2023.11.14
Time: 14:50:03
T_AST_SAE: 0 s
MAP_MES_SAE: 40 kPa
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 182009 km
Date: 2023.11.14
Time: 16:55:54
STATE_LS_SAE[1]: CL
T_AST_SAE: 434 s
MAP_MES_SAE: 56 kPa
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 182014 km
Date: 2023.11.14
Time: 16:31:12
T_AST_SAE: 373 s
Здравейте, показва ми тези грешки, колата е Bora 2.0 бензин/газ. Сменени са свещи и кабели.
- Регистриран на: Пон 31 дек 2007 15:12
- Автомобил: Passat B8 TDI
- Двигател: DFG 2018
- Местоположение: Стара Загора / София
здравейте, някой би ли услужил с кабел за vcds за vw след 2017г - София близо до Парадайс или Стара Загора
- vladoki
- Регистриран на: Нед 13 май 2007 14:19
- Автомобил: vw golf
- Двигател: GTI
- Местоположение: Перник
Здравейте,
Има ли колеги от Перник с диагностиката да направим една такава на едно голфче 4 помпа дюза ?
- vladoki
- Двигател: GTI
Здравейте, някой може ли да качи файловете за KKL Vag Com 409.1.
- Sonny_89
- Регистриран на: Сря 25 мар 2015 17:48
- Автомобил: VW Passat B7 + Opel Astra H
- Двигател: CFFB + Z19DTH
Някой да е имал подобен проблем. Не мога да използвам бутон "Meas. blocks"
- Регистриран на: Пон 04 апр 2022 17:59
- Автомобил: VW GOLF 5 19 TDI 105 hp
- Двигател: BKC 2004
Paco99 написа:Здравейте, показва ми тези грешки, колата е Bora 2.0 бензин/газ. Сменени са свещи и кабели.
Ръгай някоя добавка на Бардал 5в1 или на Лики моли за клапани за бензинови коли и карай на бензин докато не издухаш резервоара. Предимно извънградско и то в обороти 2500-3000.
- megatronS
- Регистриран на: Съб 14 юни 2014 9:08
- Автомобил: Space Shuttle
- Местоположение: Враца
Пускам отново линк за VCDS 1.2 FULL, който работи с обикновен USB KKL кабел. Линкът ще е валиден 10 дена:
https://dox.abv.bg/download?id=4c49dd41eb# - Линк за сваляне
- The_Game
- Регистриран на: Нед 24 фев 2008 21:25
- Автомобил: Golf IV
- Двигател: ALH 1999
- Местоположение: Ловеч
Здравейте, опитвам се да вкарам кода за Security Access на 9-ти канал Cent. Elect. но не го приема. Кода който въвеждам е 31347 и дава Invalid Key.
Весията на VCDS е 12.12.0 коолата е Golf 5 BKD.
Възможно ли е да е от версията на програмата или от това че не е оригинлна. По други канали Security Access кодовете ги приема.
The_Game написа:Здравейте, опитвам се да вкарам кода за Security Access на 9-ти канал Cent. Elect. но не го приема. Кода който въвеждам е 31347 и дава Invalid Key.
ако е китайски, поискай инсталатор с Loader
за пример за версия 23:
VIIPlusLoader-08.023.02-FULL-Installer.exe
антивирусната го познава като вируса, явно е някакъв крак.
Като стартирам vcds-a през loader-a, успявам да въведа 31347, иначе и на мен ми даваше че е невалиден.
- The_Game
Благодаря! Китайски е кабела ми. Намерих версия 20.4.0 с VCDS Loader, следвах инструкциите. Инсталирах първо 20.4.0 след това изключих антивирусната и инсталирах лоудъра обаче при теста ми дава Interface Not found. Изтрих всичко пробвах наново и пак така.
Търсих и тези файлове из гугъл VIIPlusLoader-08.023.02-FULL-Installer.exe но не успях да ги намеря.
кабела ти нали каза че е за vcds 12. трябва за версия 12 да намериш инсталатор с Loader. пиши на китаеца от който си го купил
- The_Game
Аз съм я взимал преди 10-тина години, дори не помня от кого точно съм я поръчал (от olx беше). Иначе инсталатор 12.12.0. имам предполагам ако на него му сложа лоудъра трябва да стане. Ще пробвам и пиша след това.
- The_Game
Не става, иска си специален Loader за версия 12.12.0 . Не успях да намеря подобно нещо в гугъл, някой има ли такъв Loader за 12.12.0.
- megatronS
Отвори тоя кабел и снимай платката от двете страни и ще ти кажа дали може да работи с най-новата оригинална версия на Росс-Теч, без да се занимаваш с тези стари версии вече.
Потребители, разглеждащи този форум: Няма регистрирани потребители и 7 госта
