KKL VAG-COM 409.1 диагностика на Golf 4
B_A_D
Регистриран на: Сря 03 фев 2010 16:30
Мнениеот B_A_D » Пет 08 ное 2013 0:16
Колата е Golf 4 TDI 1.9 110 h.p. 1998г.
Софтуера който ползвах е VCDS_LITE_1.0
Долу съм копирал резултатите който извадих от AutoScan на VCDS_LITE_1.0
Код: Избери всички
VCDS-Lite Version: Release 1.0
Friday, 08 November 2013, 00:06:44:0
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,47,55,56,57,75,76
Address 01: Engine       Labels: Redir Fail!
   Controller: 038 906 018 J
   Component:  1,9l R4 EDC   00SG  1810
   Coding: 00002
   Shop #: WSC 01317
1 Fault Found:
00575 - Intake Manifold Pressure
            17-10 - Control Difference - Intermittent
Readiness: N/A
Address 08: Auto HVAC       Labels: 3Bx-907-044.LBL
   Controller: 3B1 907 044 A
   Component: CLIMATRONIC     S 7.0
   Coding: 01000
   Shop #: WSC 01317
1 Fault Found:
01206 - Signal for Duration of Ignition; OFF
            35-10 - - - Intermittent
Address 46: Central Conv.       Labels: 1J0-959-799.LBL
   Controller: 1J0 959 799 J
   Component: 03 Zentral-SG Komf.0001
   Coding: 04097
   Shop #: WSC 01317
9 Faults Found:
00955 - Key 1
            09-10 - Adaptation Limit Surpassed - Intermittent
00932 - Electric Window Motor; Drivers Side (V147)
            62-10 - No or Incorrect Adjustment - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            27-00 - Implausible Signal
00943 - Heated Exterior Mirror; Driver Side (Z4)
00913 - Window Regulator Switch; Front Right Driver (E81)
            27-10 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
00930 - Locking Module for Central Locking; Rear Left (F222)
00935 - Electric Window Motor; Rear Right (V27)
00931 - Locking Module for Central Locking; Rear Right (F223)
End   --------------------------------------------------------------------------------------------------
Ако може някой да обясни по - точно грешка:
B_A_D
Re: KKL VAG-COM 409.1 диагностика на Golf 4
Мнениеот B_A_D » Пет 08 ное 2013 20:24
:question
kris11
Автомобил: VW Sharan 7M8
Мнениеот kris11 » Вто 12 ное 2013 14:43
няма сигнал в момента на запалване. Да не държиш климатроника изключен ??
