Наближава :arrow 10-ти юбилеен Volkswagen Club Fest 2019 (10-ти, 11-ти и 12-ти Май 2019 г.)
VCDS - Грешки Пасат б6
marincho90
Регистриран на: Нед 18 авг 2013 15:17
Автомобил: Passat B6
Двигател: BKP 2006
Мнениеот marincho90 » Вто 11 окт 2016 16:47
Здравейте колеги! Трябва ми малко помощ.
Tuesday,11,October,2016,16:33:53:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZ3CZ6E026939 License Plate:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 53 56 77
VIN: WVWZZZ3CZ6E026939 Mileage: 174480km/108416miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BKP.clb
Part No SW: 03G 906 018 HW:
Component: R4 2.0l PPD1.1 G 9970
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00930 264 93968
VCID: E2CBCC033DBAEA0E627-80B7
3 Faults Found:
16705 - Engine Speed Sensor (G28)
P0321 - 006 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 36
Reset counter: 186
Mileage: 174438 km
Time Indication: 0
Date: 2016.10.09
Time: 13:58:55
Freeze Frame:
RPM: 160 /min
Text: 0 Nm
Speed: 0.0 km/h
Time: 0.00 s
Angle: 0.0 °
Bin. Bits: 00000000
Bin. Bits: 00000001
19558 - Motor for Intake Manifold Flap (V157)
P3102 - 006 - No Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 5
Fault Frequency: 156
Reset counter: 42
Mileage: 169651 km
Time Indication: 0
Date: 2016.06.16
Time: 13:38:04
Freeze Frame:
RPM: 2016 /min
Text: 0 Nm
Speed: 0.0 km/h
Text: 0.0 %
Voltage: 12.54 V
Text: 1016 Nm
Text: 32 Nm
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00001000
Fault Priority: 4
Fault Frequency: 2
Reset counter: 176
Mileage: 174264 km
Time Indication: 0
Date: 2016.09.30
Time: 07:29:47
Freeze Frame:
RPM: 0 /min
Text: 0 Nm
Speed: 0.0 km/h
Text: 0.0 %
Voltage: 11.75 V
Bin. Bits: 00011001
Bin. Bits: 00000000
Readiness: N/A
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 M HW: 3C0 614 095 M
Component: ESP 440 C2 H015 0001
Revision: H015 Serial number: 0657411135
Coding: 0013602
Shop #: WSC 05311 000 00000
VCID: 2C57E23B8FFEEC7E18B-8079
1 Fault Found:
02840 - Wake-Up Line from Central Convenience Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 6
Fault Frequency: 17
Reset counter: 219
Time Indication: 0
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 J HW: 3C0 907 044 J
Component: ClimatronicPQ46 041 0101
Revision: 00041003 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 285F1E2B9B06C05EFC3-807D
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H38 1002
Revision: 00H38000 Serial number: 00000001653274
Coding: E1888F0700041A00000A00000F00000000095D435C
VCID: 2B55E1278AF0EB46111-807E
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00065493
Shop #: WSC 05311
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 05311
3 Faults Found:
02395 - Parking Light Front Right (M3)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 216
Mileage: 174185 km
Time Indication: 0
Date: 2016.09.25
Time: 19:38:00
Freeze Frame:
OFF
Voltage: 12.50 V
OFF
ON
OFF
OFF
OFF
01502 - Bulb for Rear Fog; Left (L46)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 218
Mileage: 157853 km
Time Indication: 0
Date: 2014.11.30
Time: 13:21:00
Freeze Frame:
ON
Voltage: 12.15 V
ON
ON
OFF
OFF
OFF
01519 - Bulb for Back-Up Lights; Right (M17)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 174285 km
Time Indication: 0
Date: 2016.09.30
Time: 18:29:00
Freeze Frame:
ON
Voltage: 13.50 V
ON
ON
OFF
OFF
ON
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 A HW: 3C0 909 605 A
Component: 0D AIRBAG VW8 028 2321
Revision: 06028000 Serial number: 0034ZS5EFTTX
Coding: 0012356
VCID: 24470A1BE72E243ED0B-8071
Subsystem 1 - Serial number: 6332MSMEA03310A0
Subsystem 2 - Serial number: 6342MSME00B37790
Subsystem 3 - Serial number: 6351HTS6R5AQKA23
Subsystem 4 - Serial number: 6361HTS62M7I5MP2
Subsystem 5 - Serial number: 6371VTS62M7M47U2
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
Component: Lenksдulenmodul 005 0010
Revision: 00005000 Serial number: 3C5953507C
Coding: 0000013
VCID: 2A5BE423850AF24EEA7-807F
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 870 L HW: 3C0 920 870 L
Component: KOMBIINSTRUMENT VD1 3028
Revision: V0018000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 00001 001 00001
Address 18: Aux. Heat
Cannot be reached
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 A HW: 3C0 907 951 A
Component: Gateway 006 0010
Revision: 00006000 Serial number: 0500C054050347
Coding: 3D3D0C04CE1002
VCID: 1F4D05F7CE4807E68D9-804A
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 HW: 3C0 959 433
Component: IMMO 038 0347
Revision: 00038000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: E7DDDD17D6988F26B59-80B2
Subsystem 1 - Part No: 3C0 905 861 A
Component: ELV 021 0350
3C0905861A ELV 021 0350
4 Faults Found:
02823 - Requirements for Locking the Steering Column Lock not met
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 7
Fault Frequency: 21
Reset counter: 219
Mileage: 173829 km
Time Indication: 0
Date: 2016.09.19
Time: 08:18:13
02861 - Electronic Steering Column Lock Check Sum Error
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 206
Mileage: 173829 km
Time Indication: 0
Date: 2016.09.19
Time: 08:18:13
02815 - Steering Column Lock; Supply Voltage for Locking Motor
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 9
Reset counter: 220
Mileage: 173829 km
Time Indication: 0
Date: 2016.09.19
Time: 08:18:13
02817 - Steering Column Lock; Enabling Wire from Steering Wheel Electronics
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 219
Mileage: 174298 km
Time Indication: 0
Date: 2016.10.03
Time: 13:26:43
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2341
Coding: 0000181
VCID: 3663C05341B2A6AE7EF-8063
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.12 1502
VCID: 306FF64BA3D6889E243-8065
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 038 0434
Coding: 00900A0801860E763804941570084B0E703C00
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 18
Reset counter: 149
Mileage: 0 km
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000180
VCID: 377DCD5746B85FA6659-8062
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000011
VCID: 2149030FF83C3116BBD-8074
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 L
Component: Radio BVX 012 0022
Coding: 0022200
VCID: 2F6DF537BEE897663D9-807A
Address 77: Telephone Labels: 3C0-035-729.lbl
Part No SW: 3C0 035 729 C HW: 3C0 035 729 C
Component: Telefon 4909
Revision: 00007000 Serial number: 0000000062051
Coding: 0016123
VCID: 23450907E2202306A91-8076
End ---------------------------------------------------------------------
VW_passatOR
Регистриран на: Пон 19 яну 2015 21:43
Автомобил: VW Passat B6
Двигател: 2.0 TDI 2005 BMP
Re: VCDS - Грешки Пасат б6
Мнениеот VW_passatOR » Вто 11 окт 2016 18:13
Това с което мога да ти помогна по грешките, предния десен габарит е изгорял, провери също така и буксите както на стоповете така и на светлината за мъгла отзад. За т.нар. Steering Column Lock е мн писано както в този форум така и като цяло в интернет при този модел. На кратко това е вид имобилайзер който ако не е в изправност не ти позволява да запалиш колата. По записаната грешка разбирам че се е случвало вече поне веднъж. Нз дали е постоянно но веднъж проявило се не може да разчиташ кога и къде ще се повтори. Ремонтира се със замяна. По спомен за това точно се коментираше сума около 500-600 лв с труд но с това не се ангажирам със сигурност.
marincho90
Двигател: BKP 2006
Мнениеот marincho90 » Вто 11 окт 2016 19:21
Благодаря за информацията колега. Дава ми грешка и за вредните емисии незнам защо. Emission workshop и engine fault workshop и за подгревните постоянно мига
georgimufc
Регистриран на: Пон 04 юни 2018 14:26
Мнениеот georgimufc » Сря 06 юни 2018 8:58
Здравейте колеги,
Наскоро си купих Пасат Б6, 2008 г., 2.0 ТДИ, 140 к.с., автоматик. Колата е страхотна и се радвам, че се спрях на марката и модела.
При диагностика ми показа около 10 грешки. По таблото не ми свети нито една сигнална лампа. Изчистихме ги, покарахме я малко и след това останаха само тези:
001027
000275
000568
01810
Рових се във форума и в чичко гугъл, но не успях да намеря нищо. Ще съм ви много благодарен, ако споделите мнения и препоръки как да действам, за да се отстранят въпросните грешки.
Пуснах и тема, обаче няма отговор.
VWGT
Мнениеот VWGT » Сря 06 юни 2018 10:27
georgimufc
Мнениеот georgimufc » Сря 06 юни 2018 14:26
Благодаря много колега!
Чудя се за EGR, ако се почисти дали ще стане номера? Ще се пробва, то е ясно:)
miroplovdiv
Регистриран на: Пон 23 авг 2010 17:52
Местоположение: plovdiv
Мнениеот miroplovdiv » Чет 12 юли 2018 21:31
здравейте и от мен, наскоро си купих Б6 в Англия. всичко й е 6 но показателите за растояние и разход са в мили. след продължително четене в нета разбрах, че могат да се променят чрез вагком. закупих си кабел от ибей и си свалих vcds-lite от сайта. Проблема е че при закачане ми намира port-a но когато отида на 17 instruments ми излиза че порта не е намерен, и така не мога да променя нищо. Някой с някакви идеи.
Потребители, разглеждащи този форум: Няма регистрирани потребители и 5 госта
