Здравейте
става въпрос за любимите на всички интермитънт проблеми
след като покарам 20 мин колата забива за секунда и продължава
после по-често забива
след рестарт (гаси пали)пак 20 мин кара без проблеми и пак отначало
възможно ли е ензора за налягане на климатика да е проблема .. ?
Address 03: ABS Brakes Labels: None
Part No SW: 6Q0 907 379 AC HW: 6Q0 907 379 AC
Component: ABS 8.0 front H03 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0000142
Shop #: WSC 00788 785 00200
VCID: 7EF34BFF2AF77C7DF0-515A
2 Faults Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Address 08: Auto HVAC Labels: 6Q0-820-045-V1.clb
Part No: 6Q0 820 045
Component: Klimaanlage X0850
VCID: 6ADB77AF167FE0DD3C-513C
2 Faults Found:
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
31-10 - Open or Short to Ground - Intermittent
Address 09: Cent. Elect. Labels:. 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 F
Component: 0009 BN-SG. 2S36
Coding: 09646
Shop #: WSC 00788
VCID: 3E738BFF3A77BC7DB0-515A
2 Faults Found:
49-10 - No Communications - Intermittent
01598 - Drive Battery Voltage
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 18 AIRBAG VW51 0P 0011
Coding: 12600
Shop #: WSC 00788
VCID: 2C57B1B7DC0B3EED0E-515A
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
Part No: 6Q0 920 825 F
Component: KOMBIINSTRUMENT AGD V04
Coding: 01132
Shop #: WSC 58522
VCID: 377D9EDB154D8D3573-515A
1 Fault Found:
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: 01K1 GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 00788
VCID: 70EF65C730A31A0D72-515A
1 Fault Found:
Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb
Component: IMMOBILIZER AGD V04
Coding: 01132
Shop #: WSC 58522
VCID: 377D9EDB154D8D3573-513C
WVWZZZ9NZ9Y024275 VWZ5Z0H5121024
No fault code found.
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156
Component: LenkhilfeTRW V272
Coding: 10110
Shop #: WSC 00000
VCID: 6DD17CB32791F7E559-513C
1 Fault Found:
End-------------------------(Elapsed Time: 03:22)--------------------------
Интермитънт изключват всички модули
Потребители, разглеждащи този форум: Няма регистрирани потребители и 15 госта
