VW touran 1.9 tdi 105 ps
Miraclem
Регистриран на: Нед 14 мар 2021 9:51
Автомобил: Golf 7
Двигател: 2 0TDI DSG
Местоположение: Ямбол
Мнениеот Miraclem » Пон 05 юли 2021 20:24
Имам проблем с доста грешки ..
Някой може ли да помогне - какво трябва да се сменя
п.с перката на климатика не се пуска, климатика вдига налягане и компа го изключва ..
Код: Избери всички
Monday,05,July,2021,08:47:46:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0
Data version: 20200331 DS317.0
www.Ross-Tech.com
Dealer/Shop Name: Consult Lozanov ltd
VIN: WVGZZZ1TZ4W043251   License Plate
Mileage: 191190km-118799mi   Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ4W043251   Mileage: 191190km-118799miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 016 A    HW: 028 101 073 1
   Component: R4 1,9L EDC G200SG  5185
   Revision: 12345678    Serial number: VWZ7Z0C8082227
   Coding: 0000072
   Shop #: WSC 10339 219 52019
   VCID: 21495083F8C9E38E24-8074
2 Faults Found:
18358 - Radiator Fan (V7)
            P1950 - 000 - Movement Restricted / Jammed - Intermittent
             Freeze Frame:
                    RPM: 756 /min
                    Torque: 100.0 Nm
                    Speed: 6.0 km/h
                    Load: 0.0 %
                    Voltage: 13.53 V
                    Bin. Bits: 00001100
                    Temperature: 54.9°C
                    Duty Cycle: 9.6 %
18356 - Control Module 2 for Cooling Fan
            P1948 - 000 - Output Short Circuit - Intermittent
             Freeze Frame:
                    RPM: 1827 /min
                    Torque: 16.0 Nm
                    Speed: 31.0 km/h
                    Load: 0.0 %
                    Voltage: 13.60 V
                    Bin. Bits: 00001100
                    Temperature: 70.2°C
                    Duty Cycle: 86.1 %
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 D
   Component: ESP FRONT MK60      0102
   Coding: 0053958
   Shop #: WSC 01324 785 00200
   VCID: 3365AACB5235611EC6-8066
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 K
   Component: ClimatronicPQ35 061 0201
   Shop #: WSC 00000 000 00000
   VCID: 2F6DA6BBBE1D45FEA2-807A
1 Fault Found:
00229 - Refrigerant Pressure
            001 - Upper Limit Exceeded - Intermittent
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 G    HW: 1K0 937 049 G*
   Component: PQ35 BordnetzSG 1.0 0501
   Revision: 12345678    Serial number: 00000000143577
   Coding: 09890F000004100000120C000000000000
   Subsystem 1 - Part No: 1T0 955 119 A  Labels: 1TX-955-119.CLB
   Component: Wischer WWS A-MPV   0101
   Coding: 16711700
   Shop #: WSC 00000
1 Fault Found:
01064 - Terminal 58d; Interior Dimming
            012 - Electrical Fault in Circuit
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605     HW: 1T0 909 605
   Component: 04 AIRBAG VW62 0102 2112
   Coding: 0012340
   VCID: 72EB6FCF6DAF28160D-8026
2 Faults Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
            001 - Upper Limit Exceeded - MIL ON
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
            008 - Implausible Signal - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 009 0030
   Coding: 0000042
   VCID: 306FA5C7A3235A06BB-8064
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1T0 920 860 C
   Component: KOMBIINSTRUMENT VDD 1714
   Coding: 0003101
   Shop #: WSC 00011 888 06946
   VCID: 3169A0C3A829530EB4-8064
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 1K0 815 071 C
   Component: Zuheizer            0707
   Revision:        C    Serial number: 09006207
   Coding: 0000011
   VCID: 25414493ECE10FAE58-8070
5 Faults Found:
00664 - Fuel gauge
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Error Code: 26210
                    Text: 00.00.00
                    Clock: 07:11
02085 - Incorrect Control Module Installed
            000 - - - Intermittent
             Freeze Frame:
                    Raw, Form. N/A: 000 000 000
01444 - Under-Voltage Shut-Off (Automatic)
             Freeze Frame:
00003 - Control Module
            014 - Defective
             Freeze Frame:
01411 - Temperature Sensor (G18)
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Error Code: 53119
                    Text: 00.00.00
                    Clock: 13:50
                        Malfunction
                    Temperature: 205.0°C
                    Temperature: 59.0°C
Address 19: CAN Gateway        Labels:. 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 210010371481EB
   Coding: 3D3F1340078002
   VCID: 275D4E9B96ED1DBE6A-8072
1 Fault Found:
00469 - Infotainment Databus in Single Wire Operation
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 123
                    Mileage: 183691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:47:19
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO                1714
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1T0 959 701
   Component: Tuersteuergeraet 09 0111
   Coding: 0000116
   VCID: 74E769D717BB26261F-8020
Address 44: Steering Assist        Labels: 1Kx-909-143-GEN1.clb
   Part No: 1K1 909 143 L
   Component: EPS_ZFLS Kl.0       0402
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 C
   Component:    KSG              0201
   Coding: 00E802087F2D8404084F0100
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Coding: 0000116
   VCID: 75E154D31CC13F2E28-8020
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 D
   Component: Radio BNO           0216
   Coding: 0020200
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 B
   Component: Tuersteuergeraet 05 0107
   Coding: 0000048
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 B
   Coding: 0000048
End-------------------------(Elapsed Time: 01:45)--------------------------
Потребители, разглеждащи този форум: Няма регистрирани потребители и 7 госта
