Здравейте,
Прочетох двете статии на сайта свъразани с настройка на бордовия компютър
"Как можете да си направите дигитален оборотомера на вашия Golf 3." и
"Volkswagen Golf 3/Vento ERROR CODES".
Също така намерих още малко информация тук, но все пак някой знае ли още нещо което може да се настройва и как точно?
Настройка на Car Computer-а
- izzo
- Регистриран на: Съб 19 юни 2004 7:06
- Автомобил: 96 Puntamera
- Двигател: diesel
- Местоположение: Kвартала на обречените
Speedometers have a factory built-in percentage error to show a speed
faster than your actual speed.
The Climatronic (climate control) system has diagnostic codes that
you can access by the pressing of certain buttons on the Climate
Control console.
One of these codes shows your actual speed of travel without this
built-in percentage error!
These codes are accessed by one of the following procedure's..
_______________________________________________________________
A/- To access the actual speed display, start your car and then on
your climate control panel press and hold-in the recirculation
button. Then at the same time, press the upward pointing arrow button
above the recirculation button.
Your climate control screen will change to a different mode displaying 1c.
Use your temperature control + button to display code 17c. This is
the actual speed display feature.
Press the recirculation button again to activate the code and to
display it's reading.
To revert your Climate Control to normal mode, simply press the
Economy button or switch off the ignition.
________________________________________________________________
B/- To access the actual speed code on some VW's (Passat’s etc) the
following method applies....
Hold-in Fan Down, Temperature Colder, ECON all at the same time. Use
the + / - temperature control buttons to view the various codes. Code
16 (sometimes 17) is the speed code.
Code 16 displays the speed you are travelling at on your centre
screen in km/hr. This enables you to compare your speedometer reading
relevant to your actual speed.
(In most cases this display can be changed to display mph. 1st you
need to change the display to read degrees Fahrenheit. Try pressing
ECON and AUTO at the same time, or holding ECON for 3 seconds, All
models may be slightly different. Your hand book will tell you
exactly how to do this.
_________________________________________________________________
http://www.audiworld.com/tech/int5.shtml lists many other relevant
code number applications, some however may differ from car model to
model.
Control console.
model.
- brabus
- R-циклопедист на VW
- Регистриран на: Вто 08 юни 2004 8:17
- Автомобил: Golf II GTI PB A4 Avant 1.8 TQ
- Двигател: 1991 2003
WDW написа:За това специално не съм го пробвал,но не бъди толкова сигурен,че като загасиш и всичко ще е наред !!! След като веднъж данните са въведени във флаша и после може да си гасиш колкото си искаш - те ще си стоят там !!! Така,че внимателно с ти я работи !!!
E би ли ми обяснил точно какво ще въведеш във Флаша, че почвам да се нервя
Това да ни ти четец- записвачка за чипове.
Това е сервизен режим, в който просто може да видиш различни стойности (ако знаеш какво означават, защото някои са служебни кодове)
И как си мислиш, че може да въведеш нещо?
