Търся каталог с данни за Голф
golf_tuning
Регистриран на: Пон 29 ное 2004 13:48
Мнениеот golf_tuning » Чет 12 яну 2006 23:02
peshoxx написа:
golf_tuning написа:Ето данни от една програмка
1991 Volkswagen Golf 1.8 GL
Bodywork
Type: 4/5S HBK
Number of doors: 5
Dimensions
Wheelbase: 2475 mm 97.44 in
Track front: 1470 mm 57.87 in
Track rear: 1460 mm 57.48 in
Length: 4020 mm 158.26 in
Width: 1690 mm 66.53 in
Kerb weight: 1084 kg 2389.80 lb
Weight distribution F/R: 62 %
Fuel capacity: 55 l 14.52 US gal
Aerodynamics
Drag coefficient: 0.3
Frontal area: 2.03
Cx: 0.61
Engine
Volkswagen
Type: S-4
SOHC
8 valves total
2 valves per cylinder
Main bearings: 5
Bore x stroke: 81.00mm × 86.40mm
Bore / stroke ratio: 0.94
Displacement: 1781 cc 108.68 cu in
Compression: 10.00:1
Fuel system: Bo Monomotronic fuel inj.
Aspiration: Normal
Max. output: 91.3 PS (90.0 bhp) (67.1 kW)@5500 rpm
Max. torque: 145.0 Nm (107 lbft) (14.8 kgm)@2500 rpm
Coolant: Water
Specific output: 50.5 bhp/litre
Specific torque: 81.41 Nm/litre
Performance
0-60mph: 12.7 s
Quarter mile: 19.20s
Kilometre: 35.10s
Top speed: 172 km/h
Power to weight: 83.03 bhp/ton
Chasis
Engine location: Front
Engine alignment: Transverse
Steering: rack & pinion PAS
Turns lock-to-lock: 3.200
Turning circle: 10.70 m
Suspension front: I.MS.CS.ARB.
Suspension rear: TB.TA.CS.
Brakes: Di/Dr
Transmission: 5M
Drive: FWD
Top gear ratio: 0.85
Final drive ratio: 3.67
Performance
0-60mph: 12.7 s
Kilometre: 35.10s
Top speed: 172 km/h
Интересни данни !! :shock Имам чувството 1че моята с 90 коня е самолет!!! На тези да не им е била развалена колата??? :D Моята дава 17.7-18.1 на 400м.,а от 0-100 е много по-бърза. :D
КОлега що пишеш глупости!? като самолет била gruebel
Ти с кво си я мерил? ся не ми казваи с 4асовник
negodnika
Регистриран на: Пон 14 юни 2004 10:13
Автомобил: Golf MK II GTI+GL
Двигател: PB+EZ
Мнениеот negodnika » Пет 13 яну 2006 20:40
peshoxx написа:
Bodywork
Type: 4/5S HBK
Number of doors: 5
Dimensions
Aerodynamics
Frontal area: 2.03
Cx: 0.61
Engine
Volkswagen
Type: S-4
SOHC
8 valves total
Main bearings: 5
Aspiration: Normal
Coolant: Water
Performance
0-60mph: 12.7 s
Kilometre: 35.10s
Top speed: 172 km/h
Chasis
Brakes: Di/Dr
Transmission: 5M
Drive: FWD
Performance
0-60mph: 12.7 s
Kilometre: 35.10s
Top speed: 172 km/h
И според мен е доста по-бърз 1и8ка дават различни данни някъде я дават 10.6до 100 и според мен това е реалното време моя е 1.6 и падам доста лошо от 1.8 :(
golf_tuning
Мнениеот golf_tuning » Пет 13 яну 2006 22:57
negodnika написа:И според мен е доста по-бърз 1и8ка дават различни данни някъде я дават 10.6до 100 и според мен това е реалното време моя е 1.6 и падам доста лошо от 1.8 :(
Незнам само защо се занимавате да им обяснявате на "онези" от "онзи форум" нядявам се 4атнеш за какво имам предвид :wink:
peshoxx
Регистриран на: Вто 01 фев 2005 1:11
Мнениеот peshoxx » Съб 14 яну 2006 0:03
golf_tuning написа:
peshoxx написа:
Bodywork
Type: 4/5S HBK
Number of doors: 5
Dimensions
Aerodynamics
Frontal area: 2.03
Cx: 0.61
Engine
Volkswagen
Type: S-4
SOHC
8 valves total
Main bearings: 5
Aspiration: Normal
Coolant: Water
Performance
0-60mph: 12.7 s
Kilometre: 35.10s
Top speed: 172 km/h
Chasis
Brakes: Di/Dr
Transmission: 5M
Drive: FWD
Performance
0-60mph: 12.7 s
Kilometre: 35.10s
Top speed: 172 km/h
Извинявай колега,но не знам ти с какъв двигател си.Моя си върви доста добре! bleh1 По принцип съм се пускал на пистата в Калояново до Пловдив.Вярно,за сега нямаше измервателна уредба,но времето се засичаше от собственика на пистата с хронометър.Мисля,че разликата не е толкова голяма ,пък и всеки път съм горе-долу в едни граници на времето.За сравнение ще ти кажа,че Голф2 1.8i с 22 коня повече,ме бие само с една кола разстояние на 400м.Така,че си прецени. :D Голф3 2.0 115 коня също съм бил на 400м.
Joe
Регистриран на: Вто 08 юни 2004 17:53
Мнениеот Joe » Нед 15 яну 2006 15:28
Извинявам се за офтопика, но ме дразни начина ви на писане...
пирмер: http://forum.vwclub.bg/viewtopic.php?t=11939
