Кажете какво масло да сложа на Голф-а. Досега е каран с BP Visco 7000 Longlife II 0W30. От къде мога да си купя пак такова, ама да е истинско. Гледам че представител на BP е "МОТОБУЛ ООД". Някои да се е сблъсквал с тях.
Иначе от Порше БГ ми предлагат някакъв Castrol.
Масло за TDI - PD 100 коня
- mladvampirTDI
- Регистриран на: Пет 11 мар 2005 11:12
- Местоположение: Sale, UK
- brabus
- R-циклопедист на VW
- Регистриран на: Вто 08 юни 2004 8:17
- Автомобил: Golf II GTI PB A4 Avant 1.8 TQ
- Двигател: 1991 2003
8100 E-Tech lite 0W30
Gasoline and Diesel engine oil
100% Synthetic – Ester Based
TYPE OF USE
Engine oil for "Fuel economy and extended drain intervals" especially designed for powerful and recent engines, powered by turbo Diesel direct injection or gasoline engines, designed to use low friction and low HTHS (High Temperature High Shear) viscosity oil.
Suitable for all type of engine, in particular for Renault gasoline, Peugeot and Citroen gasoline and diesel Hdi engines or when a "Fuel economy" lubricant is required (ACEA A1/B5 and A5/B5 Standards), suitable for catalytic converters.
These oils may be unsuitable for use in some engines. Refer to the owner manual or handbook if in doubt.
PERFORMANCE
STANDARDS ACEA A5 / B5
APPROVALS API SL / CF
OPEL GM-LL-A-025 (Gasoline)
* The new performance ACEA A5/B5 requests fuel economy and low emission performance for powerful engines.
The ester synthetic bases and specific anti-friction additivation result in significantly increasing the oil film resistance, reducing friction in the engine, maintaining the oil pressure, and generally decreasing the operating temperature.
* The new standard API SL is more stringent than API SJ in terms of ageing resistance (average drain interval increased), requires anti-oxydation properties that maintain a constant viscosity avoiding sluge and deposits in the crankcase, anti-wear properties and dispersent power
* Easy start in polar conditions.
Anti-oxidation, Anti-wear, Anti-corrosion, Anti-foam properties.
RECOMMENDATION
Drain interval : according to manufacturers’ recommendations and tune to your own use.
MOTUL 8100 E-tech Lite 0W-30 can be mixed with synthetic or mineral oils.
- mladvampirTDI
- imedarov
- Регистриран на: Чет 17 мар 2005 9:26
- Автомобил: Passat B8
Мойта машинка е TDI PD 115 коня и я карам с Casrol GTD 505 01.
В книжката пише да се кара с масло отговарящо на стандарта VW 505 01.
Много съм доволен от масалцето само дето е 20 кинта литара. Има го в Супер дизел и в Мотобул (по патя за Панчарево с/у Ивеко).
Колата има борд компютър и иска да се сменява маслото на 15 000км но в Сакар ауто казаха да го сменявам на 7500 заради лошата нафта в БГ.
- mladvampirTDI
- imedarov
Дай mail да ти пусна VW approved oils в pdf формат
Има го в www.erwin-hotline.de но иска регистрация
