Потъмняване на стопове - Passat B3 /eng./
izzo
Регистриран на: Съб 19 юни 2004 7:06
Автомобил: 96 Puntamera
Двигател: diesel
Местоположение: Kвартала на обречените
Мнениеот izzo » Вто 29 юни 2004 10:06
sorry ama dokato namerq razdela postvam na sto mesta ve4e...
so.......my next cheap-ass mod =) nice alternative for pricy smoked tails!
first i wanted crystal clear taillights, but those seem to be hard to find
about the B3 then i decided smoked...now, biggest question that i did a lot
of reading on - IZZ IT LEGIT???well, hell... depends on where u live and
what u want. basically, as long as when u hit brakes the car behind sees
you from a good distance, U COOL! so - let's go...
what i bought [after checking local auto stores n being denied] is:
1. 10oz canister of VHT Nite Shades window tint spray.... approx $10 [eBay]
http://cgi.ebay.com/ebaymotors...WN:IT
2. a canister of clear coat - $3 [walmart]
[do not by ENAMEL one - leaves white resedue!] left from my door sill mod...
3. some steel wool - $3-4 [lowes] as well left from the door sill mod...
first try to spray a lil bit somewhere on a plastic surface with both the
tint and the clear coat to see how it works and what distance should u have
between the spray and the object, very important is NOT to overspray!
i experimented on my trash can =) worked as a training =)
then take off your tail lights... it is a snap, only three bolts
hold the left and right tails, but i removed as well the lights that have
the white reverse light - they are on the trunk hood, note:
those are on three bolts each too, u DO NOT need to remove the plastic cover
that holds your licence plate but I DID just to clean it and as well
i put one clear coat layer on it just to match the rest after that,
it is holded by two screws from the inside - u need to remove the fabric
cover inside the screws are underneath it AND two big a$$ screws which are under
the licence plate so u will have to take that off.
then wash the tail light lenses WELL and let them DRY well.
i as well scrubbed them a little bit with steel wool - removes all $hit.
now is good time to try and with a piece of cloth to clean the reflectors inside,
it is not that easy cuz these DO NOT disassemble u need to reach through
the small bulb holes. after all that is cleaned and dry, i masked the black plastic
frame with masking tape cuz i did not want tint on it, just wanted to paint
the lenses. if u r patient enough u might put some strips on the lenses
and paint over them and remove the strips after that making yo tails look
even mo' cool but i did not do that, whatever.
i put a coat of VHT tint once and let it dry, fortunately it does real quick-
like fifteen minutes or less. then applied another one for a total of TWO,
not more tint layers. tell u why, cuz when i put the tinted lights on the car,
it looks even DARKER cuz car is white! and i do not want some fool to rear end
me cuz he did not see my braking light!!!
then i removed the masking tape and applied two layer of thick clear coat
all over and again let it dry. meanwhile vacuumed car, did not want to try
putting the taillights too soon and have my fingerprints there!
when, total of two-three hours later, installation back is a pleasure,
and here is how it looks like:
later 2nite we went 2 see 'white chicks' and gathered in applebees,
and i had my friend vasillalov to sit in my car and try turn signals
and brakes and rear light so i can ensure myself that tint was not WAY too much..
well, it was not, so i can sleep well now, not worried that when i go
to inspect my car next year sum jerk will make me strip all the nice black tint down =)
here is how it looks now:
hope u like it as i do!! and after that i freshen a lil bit the side trim
with mother$ back2black so now it looks great as well,
i just smile when lookin' @ da passator ;)
izzo
Двигател: diesel
Мнениеот izzo » Пет 21 яну 2005 17:10
bump
tubleron
Регистриран на: Чет 03 фев 2011 10:34
Автомобил: Golf 3 1.8 75ks
Двигател: AAM 1992
Re: Потъмняване на стопове - Passat B3 /eng./
Мнениеот tubleron » Пон 12 мар 2012 15:58
:да:
vladtod®
Автомобил: Passat
Мнениеот vladtod® » Пон 12 мар 2012 19:48
До скоро се считаше ,че най-старата изкопана тема е от 2006 ,но ти си най-добрия иманяр. mhihi
tubleron
Двигател: AAM 1992
Мнениеот tubleron » Пон 12 мар 2012 20:01
vladtod® написа:До скоро се считаше ,че най-старата изкопана тема е от 2006 ,но ти си най-добрия иманяр. mhihi
Друго бях писал,ама като видях датата и ..... го промених на :да:
toshara
Автомобил: MK2 Golf
Двигател: GTI PB 1990
Местоположение: Провадия
Мнениеот toshara » Пон 12 мар 2012 21:15
Извинявам се за офф-а,ама ми е интересно,ква ли е първата тема в форума :roll: :drunk
веселин
Автомобил: SkodaFabia 1 sedan
Двигател: BNM 1.4 TDI-PD 2007
Мнениеот веселин » Нед 25 мар 2012 22:15
toshara написа:Извинявам се за офф-а,ама ми е интересно,ква ли е първата тема в форума :roll: :drunk
Ето тази
viewtopic.php?f=5&t=12
К.Одаджийски
Автомобил: Saab 9-3 SS ARC
Двигател: B207L
Мнениеот К.Одаджийски » Нед 25 мар 2012 22:49
веселин написа:
Ето тази
Когато и мастърите са писали на шльокавица scare
stativ jelqzkov
Регистриран на: Сря 23 ное 2011 2:59
Местоположение: earth
Мнениеот stativ jelqzkov » Вто 27 мар 2012 3:21
тук... не ги затъмняват така, ами слагат нещо като ситна мрежа в/у стопа и се пръска отгоре. Резултата е че повърхтноста на стопа е покрита на 50% с финни точки и като се гледа от далече се вижда като цяло покритие/нещо като рекламните лепенки по реисовете дето са на дупчици като гледаш от вътре на реиса се вижда добре навун, а като гледаш от вън на реиса се вижда само рекламата :)/
izzo
Двигател: diesel
Мнениеот izzo » Пет 30 мар 2012 21:57
К.Одаджийски написа:
веселин написа:
toshara написа:Когато и мастърите са писали на шльокавица scare
Млад бех и прост :d
