Нови попълнения в моето Кар Аудио
sashobas
Щастлив голфаджия
Регистриран на: Пет 01 сеп 2006 23:00
Местоположение: Търговище
Мнениеот sashobas » Вто 12 фев 2008 21:44
Според мен ламера си знае работата.Той е проверил нещата със сигурност.
los_tigros
Мнениеот los_tigros » Сря 13 фев 2008 9:23
Дай малко характеристики за Кикерчето.
lamer4e
Регистриран на: Пон 09 яну 2006 8:14
Мнениеот lamer4e » Сря 13 фев 2008 9:35
Kicker Solo-Baric
Unique Square Cone Design New Enhanced BAM (Basket and Motor) Assembly Double-Stitched Santoprene Rubber Surround Heavy Duty Nickel-Plated Spring Terminals Advanced SoloKön™ Composite Cone Integrated Rear Cone Brace with Continuous Contact Perimeter Weld Dual Ultra-Length Voice Coils for Sustaining Enormous Cone Excursion High-Temp Polymide Film Voice Coil Former Improves Sonic and Conductive Properties and Prevents Thermal-Electrical Meltdown Low Profile, High Strength Steel Basket Perimeter Venting Cooling System Impregnated Cotton Spider Sleeved High Power Tinsel Leads Extended, Bumped, and Vented UniPlate Pole Piece Optional Patented KICKER Grille Mounting Depth: 6 3/4\" (17.1cm) Subwoofer Specifications Size: 12 inch Rec. Sealed Box Dims: 0.88 - 2.00 cu.ft. Rec. Ported Box Dims: 1.75 - 3.25 cu.ft. Free Air Usage: not recommended Sensitivity: 87.9 dB Frequency Response: 20-100 Recommended RMS Power: 600W Peak Power Handling: 1200W Impedance: dual 4 ohms subwoofer wiring options The new KICKER Solo-Baric L5 subwoofer is slammed with performance features borrowed from its big brother L7, the square cone woofer that revolutionized the high performance subwoofer category. The KICKER L5 uses a square cone to give you the most possible cone area for a given size baffle - 16% to 20% more cone area. This means that an L5 will play louder than a conventional round woofer of the same size since it moves more air. It\'s like buying one size subwoofer and getting the output of the next bigger size. This new L5 series cone utilizes SoloKön™, an ultra high performance composite, which remains rigid, minimizes cone flex, and lowers harmonic distortion. The SoloKön cone consists of a unique one-piece, aluminum vapor deposit material that moves as a light weight piston, exhibiting power and control. The rear cone brace integrates into the SoloKön cone with a continuous contact perimeter weld, which offers unmatched strength and resistance to deformation under pressure. The Solo-Baric L5 subwoofer features extra-length dual voice coils and a huge motor structure with KICKER’s black-plated Uniplate construction which combines backplate and extended pole piece for maximum magnetic efficiency with minimal misalignment. These new L5’s also feature an enhanced BAM (Basket And Motor) assembly that utilizes a high strength steel basket with a low-profile open design, providing a solid foundation for the precision aligned motor assembly. All models have dual voice coils for ultimate wiring flexibility - 2-ohm DVC models let you run a single 1 or 4-ohm load, 4-ohm DVC models allow 2-ohm or 8-ohm operation.
lamer4e
Мнениеот lamer4e » Чет 28 фев 2008 20:38
следващото нещо ще е е тоз красавец
не е кой знае какво но съм го чувал на 2 Л5-ци как бута кочината
Audio System TWISTER F2-500 Edelstahl 2 - Kanal Verstärker
TWISTER F2-500 MK III
· 2x 230 Watt RMS @ 4 Ohm Stereo
· 1x 1180 Watt RMS @ 2 Ohm Mono
· Stufenlos regelbare Hoch-/Tiefpässe
· Gehäuse in gebürstetem Edelstahl
· 1 Ohm stabil
Revolution ist das neue Schlagwort für analoge Verstärker.
Die Audio System Endstufen sind bei gleichen Außenmaßen und Einbauformen in ein noch nie da gewesenes Preis/Leistungsverhältnis vorgestoßen.
- Gehäuse in gebürstetem Edelstahl
- 1 Ohm Stabilität (außer F6-380)
- Temperaturabhängiger Lüfter ""Thermospeed""
- Modernster Aufbau in SMD Technik
- Schutzschaltung ""G.P.S.""(Global Protection System) - Frequenzgang bis zu 175.000 Hz (F4-600)
- Sehr einbau- und servicefreundlich
Getestet von der Zeitschrift autohifi in Heft April/Mai 2006
Spitzenklasse mit 63 Punkten
- Top- Sound
- satte Leistung
-günstiger Preis
Mehr Leistung, besserer Klang- die neue F2-500 III kann mehr als ihre Vorgängerin.
lamer4e
Мнениеот lamer4e » Нед 09 мар 2008 16:33
След последното модване на касата която е около 110 литра съм доста очарован от този говорител има и няколко недостатака но няма перфектни неща :)
lamer4e
Мнениеот lamer4e » Вто 25 мар 2008 8:53
След дълги колебания вече съм с ново стапало 8)
или иначе казано ето това
# Mono Block Subwoofer Amplifier
# 1 Ohm Stable
# MOSFET Power Supply
# PWM (Pulse-Width-Modulated) System
# Double Sided Epoxy PCB Circuit Board
# Gold Plated RCA Inputs
# Custom Terminal Block for Speaker Connections
# Thermal, Overload & Short Protection
# Remote Bass Control
# Soft Turn On/Off
# 500 Watts RMS Power into 4 Ohms
# 800 Watts RMS Power into 2 Ohms
# 1000 Watts RMS Power into 1.3 Ohms
# 1300 Watts Max Power into 1.3 Ohms
# THD @ 1Watt/4 Ohm: 0.1%
# S/N Ratio: 90dB
# Frequency Response: 15Hz - 150Hz (+/-3dB)
# Damping Factor @ 20Hz/4 Ohms: 400
# Variable Low Pass Filter: 50Hz-150Hz, 24dB/Octave
# Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave
# Variable Bass Boost: 0 to +18dB
# Phase Shift Control: 0 to 180
# Input Sensitivity: 200mV ~ 8V
# Input Impedance: 10k Ohm
# Line Output Impedance: 100 Ohm
# Fuse Rating: 30A x 4
# Dimensions: 10.08'' (W) x 2.12'' (H) x 14.96'' (L)
Golfer_pz
Регистриран на: Чет 15 май 2008 14:47
Местоположение: Chicago, Illinois
Re: Нови попълнения в моето Кар Аудио
Мнениеот Golfer_pz » Сря 25 мар 2009 20:58
Ламер, я ми кажи колко струва един такъв кикер, че нещо не мога да намеря, а викам да си зема един :roll:
rollin
Регистриран на: Пон 23 апр 2007 21:27
Местоположение: Първомай
Re:
Мнениеот rollin » Чет 26 мар 2009 11:07
lamer4e написа:След дълги колебания вече съм с ново стапало 8)
Добре, че си се отказал от Аудиосистема..., а що се отнася до усилвателите на Ланзар, нещо много ги плючт(дефектирали често)...
Аз познавам доста хора упарени от усилватели на Ланзар....Коцето също изрева май...защо не го поразпита на срещата в Пловдив...?
passat123
Мнениеот passat123 » Чет 26 мар 2009 14:46
Честито за усилвателчето бива си го а и хубави отзиви съм чувал за фирмата ! :applause:
lamer4e
Re: Re:
Мнениеот lamer4e » Чет 26 мар 2009 16:37
rollin написа:
lamer4e написа:..............
да но това се отнася за Опти 2000Д със 1400д до сега не съм чул някой да се оплаче :да:
а колкото до тая тема трябва да хвана да я раздвижа малко за сега замислям още 1 Кикер 12л54 за да мога да позвам оптито пълноценно death
По последно замерване на СПЛ диска на емма 135.7 ДБ и на мое парче 142 ДБ от което съм доста доволен :Mr Green Fun
Последна промяна от lamer4e на Чет 26 мар 2009 16:46, променено общо 2 пъти.
lamer4e
Мнениеот lamer4e » Чет 26 мар 2009 16:42
Golfer_pz написа:Ламер, я ми кажи колко струва един такъв кикер, че нещо не мога да намеря, а викам да си зема един :roll:
ами в момента мисля че се продава един 15 л7 и цената му беще доста добра
Golfer_pz
Мнениеот Golfer_pz » Чет 26 мар 2009 19:46
lamer4e написа:
е за мойта кола 15'' ме е голям,иначе какви пари е и къде се продава? :| за това питам за S12l5 като твоя :roll: ако нещо ми пиши на ЛС да ми кажеш... Все пак се познаваме :mrgreen: :beer
Turbo_XD
Регистриран на: Пон 13 фев 2012 19:59
Местоположение: вкъщи
Мнениеот Turbo_XD » Нед 20 май 2012 13:04
Колега какво стана с темата от доста одавна не си писал в нея
