за компютър в колата вместо ЦД
- DragoGT
- 1/8 перничанин
- Регистриран на: Вто 08 юни 2004 18:31
монитора е сменен с по-добър
този сега е 800х600 и е 16:9 онзи беше 640х480
вярно по-скъпо малко ми излезна но си заслужава
(madcap ето да го видиш...
7" TFT LCD touchscreen for car PC.
- Mount Type: Dashboard or Headrest
- PAL/NTSC
- Resolution 720x400 to 1280x1024
- 16:9 aspect ratio
- Video Input: XGA/VGA input (15 pin D-SUB), USB or RS232 interface
- 2 RCA video inputs, 1 audio input
- Built-in Speaker
- Display brightness (with touchscreen): 280cd/ m²
- Power Consumption: < 9W
- Includes: Remote control, USB cable, VGA cable, AV cable, Dashboard Mounting bracket, Headrest Mounting bracket + screws, Stylus, CD with touchscreen drivers, Operation manual
- 1 year warranty
The VM7000 7" TFT LCD Touchscreen monitor is one of the most versatile vehicle monitors for your Car PC. It features a sharp 800x600 VGA screen, allowing you to run regular car PC programs as well as specialized car PC software. With the built-in touchscreen monitor, you can use your fingers instead of a mouse for input. The VM700 displays not only computer video , but with the RCA inputs, you can also display video from DVD players, VCRs and other devices. Headrest Mount
Includes a CD with touchscreen drivers for Windows, MacOS, DOS and Linux.
SPECIFICATIONS
- PAL/NTSC
- Operating Voltage: 11-16V DC (max: 1A)
- Input Current: 0.7A
- Grounding System: car battery negative pole
- Operating Temperature: -20 to 70°C
- Viewing Angle: 65° from the bottom / 40° from the top/ +/-65° horizontally
DIMENSIONS
- 7.1" x 4.7" x 1" / 181 x 120 x 25(mm)
(L x W x H)
- Display Area: 6" x 3.4" / 154mm x 87 mm
- Weight (monitor only): 0.95 lbs (0.43 kg)
- Total Package Weight: 4 lbs (1.8 kg)
- idkedikov
- Регистриран на: Вто 27 сеп 2005 15:49
- Автомобил: VW Passat 3bg
- Двигател: AVF
DragoGT написа:GPS поръчан - Holux GPSlim236 Wireless GPS Receiver
Product Description:
SiRF Star III chispet
Serial interface for optional serial cables
Antenna jack for connecting with optional external antenna
Features:
Application: Vehicle tracking & Location base services, PDA/Notebook, Car and Marine Navigation.
20 parallel satellite-tracking channels for fast acquisition and reacquisition.
Dual function (Bluetooth GPS+ G-mouse)
Compatible with Bluetooth Serial Port Profile (SPP) completely.
Built-in rechargeable Lithium ion battery without external power supply for at least 10 hours operation.
Built-in 850mAh rechargeable battery for memory and RTC backup and for fast Time To First Fix (TTFF).
Support NMEA0183 v2.2 data protocol or SiRF binary code.
FLASH based program memory. New software revisions upgradeable through serial interface.
Provide expand terminal and can contact to other system without Bluetooth device.
Колко пари ти излезна GPS-a
ехааааа.... това е страхотно
