Въпрос за кутия за колона
policevidin
Регистриран на: Вто 27 ное 2007 0:33
Автомобил: VW Golf 3 Modificated
Двигател: 1.9TDI 1z+ 1996
Местоположение: Видин, GSM 0896633775
Мнениеот policevidin » Пон 23 фев 2009 20:31
Интересува ме колеги каква кутия трябва за този говорител интересува ме литража и размерите:
http://caraudio-bg.com/ts-w3001d4.htm
Product Details
Pioneer Premier TS-W3001D4 12" Champion Series PRO Subwoofer, Model TSW3001D4
The Premier TS-W3001D2/4 subwoofers are designed to produce enormously powerful music. Just take a look at its super-heavy-duty construction, all designed to handle up to 3,000 watts max. Double-stacked magnets for higher power, and a step-up radial surround for superior control and long excursions. We used a constructed cast-aluminum basket for this sub. Add in our patented IMPP cone and you've got a monster sub that can handle whatever you want to throw at it — including Pioneer's new breed of SPL amplifiers like the PRS-D3000SPL.
Features:
Woofer Cone Material: Interlaced Carbon Fiber/Glass Fiber Reinforced
Surround: Wide-Roll, 3-Layer Fiber Woven Aramid Radial with Honeycomb Cloth
Voice Coil: Dual 4-Layer, Long Voice Coil
Voice Coil Wire: Copper
Voice Coil Bobbin: Phenol Resin Coated Glass Cloth
Projected Pole Yoke with Vented Pole
Magnet Construction: Double Stacked (110oz)
Basket Design: Aluminum Die-Cast Rigid Chassis
Gasket: 1-Piece Rubber
Wire Terminals: Integrated Single-Sided Silver Compression Terminals
Specifications:
Watts MAX. Music Power: 3000 Watts
Watts Nominal Power Handling: 1000 Watts
Frequency Response: 18 Hz to 700 Hz
Sensitivity: 89 dB
Ohm Rating: 2 ohm or 4 ohm
Recommended Enclosure: 0.50 ~ 1.0 Cubic Feet
death
rollin
Регистриран на: Пон 23 апр 2007 21:27
Местоположение: Първомай
Re: Въпрос за кутия за колона
Мнениеот rollin » Пон 23 фев 2009 21:14
Слушал съм такъв в 50 литра кутия с удължен инвертор и свиреше много добре...., но в повече предполагам ще свири още по добре вече в зависимост от това дали имаш свободно място, а и разликата няма да е голяма :wink:
policevidin
Мнениеот policevidin » Пон 23 фев 2009 21:32
Кутиите са си цяла наука в аудио инсталациите ако питаш мен кутията в 40% ако не и повече от СПЛ "конфигурацията" оригинално и даван кутия с нормални размери 28-32 литра максимални 42 а мин. 18литра.
но същевременно по магазините има масово кутии за този говорител по 37литра.
аз за момента съм с около 50 и не ми харесва как дъни може и по ниско. :banghead:
rollin
Мнениеот rollin » Пон 23 фев 2009 22:11
policevidin написа:Кутиите са си цяла наука в аудио инсталациите ако питаш мен кутията в 40% ако не и повече от СПЛ "конфигурацията" оригинално и даван кутия с нормални размери 28-32 литра максимални 42 а мин. 18литра.
Щом търсиш ниско слизане работата е ясна....
Правиш една 80литрова с прав порт и мисля, че ще постигнеш целите си.
Ето какво представлява
Моята каса е такава
Днеска я замервахме и направи 135db (говоритела е Lanzar OPTI1232D) , а пик-а и е на 40 херца
policevidin
Мнениеот policevidin » Пон 23 фев 2009 22:24
Аз чакам ето тази да стане готова:
http://www.snimka.bg/photo.php?photo_id=10733366
а с този усилвател щте постигна ли нещо: говоря за db
SONY
rollin
Мнениеот rollin » Пон 23 фев 2009 23:47
policevidin написа:Аз чакам ето тази да стане готова:
SONY
хах с тоя усилвател ще гъделичкаш пайнера по петичката само и едва ли ще ти хареса как свири, защото на 2 ома я извади 300вата я не :Mr Green Fun
Ако ти трябва нещо читаво за тоя пайнер, имам за продан един монобкок на Кенууд
viewtopic.php?f=46&t=127173
radi_nrj
Двигател: AEL ALH
Мнениеот radi_nrj » Вто 24 фев 2009 9:22
rollin написа:
SONY
Тоя Kenwood + 3001-та и задната чистачка няма да може да бърше :Mr Green Fun :Mr Green Fun :Mr Green Fun
policevidin
Мнениеот policevidin » Вто 24 фев 2009 10:54
radi_nrj написа:
rollin написа:
SONY
знам колегаа, знам че Сонито не мойе да я разклати но за сега нямам възможност за друго иначе това искам да си взема: Pioneer
живот и здраве и до там ще стигна death
rollin
Мнениеот rollin » Вто 24 фев 2009 17:16
за съфорумци правя от 5 до 10 процента отстъпка(става въпрос за новата техника) така, че ако решиш да взимаш може да измислим нещо :wink:
policevidin
Мнениеот policevidin » Вто 24 фев 2009 17:50
rollin написа:за съфорумци правя от 5 до 10 процента отстъпка(става въпрос за новата техника) така, че ако решиш да взимаш може да измислим нещо :wink:
:bowdown :bowdown задълйително щте се чуем
