здравейте колеги, моля за малко помощ и консултация ако може.
проблемът ми е следния. имам сеат алхамбра но двигателя е същия като на шаран 1.9 ТДИ 110 коня. онзи ден опитах да запаля но много трудно, бая си въртеше. закачих го на ваг ком и ми даде следните грешки:
Mileage: 189060km/117476miles
Address 25: Immobilizer Labels: 7M0-953-257.lbl
Part No: 7M0 953 257 R
Component: IMMO VWZ3Z0W0042386 V68
Coding: 09600
Shop #: WSC 80149
VCID: 458B4FCD5FBAC71
1 Fault Found:
00750 - Warning Lamp
31-10 - Open or Short to Ground - Intermittent
Address 01: Engine Labels: Redir Fail!
Part No: 028 906 021 GT
Component: 1,9l R4 EDC 00SG 1906
Coding: 00002
Shop #: WSC 00020
VCID: 67D7A5450576F51
3 Faults Found:
65535 - Internal Control Module Memory Error
35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
00553 - Mass Air Flow Sensor (G70)
31-00 - Open or Short to Ground
Readiness: N/A
Address 09: Cent. Elect. Labels: None
Part No: 7M0 962 258 E
Component: Multifunkt.Einheit 0001
Coding: 16385
Shop #: WSC 00020
VCID: 3973333D2342B31
No fault code found.
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 603 AA
Component: AIRBAG VW3 - V04
Coding: 16705
Shop #: WSC 00020
VCID: 68D5A6790868FA9
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
32-10 - Resistance too High - Intermittent
Address 17: Instruments Labels: 7Mx-919-xxx-17.lbl
Part No: 7M1 919 863 F
Component: Kombiinstrument 066a
Coding: 00024
Shop #: WSC 11111
VCID: 3F875D253D669D1
End ---------------------------------------------------------------------
Wednesday,25,September,2013,18:28:12:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 7M - Seat Alhambra I
Scan: 25 01 02 03 08 09 15 16 17 18 19 22 29 35 36 37 39 45 55 56
76
Coding: 09600
Shop #: WSC 80149
1 Fault Found:
Coding: 00002
Shop #: WSC 00020
3 Faults Found:
P1570 - 35-00 -
Readiness: N/A
Coding: 16385
Shop #: WSC 00020
Coding: 16705
Shop #: WSC 00020
1 Fault Found:
Coding: 00024
Shop #: WSC 11111
Address 15: DTCs cleared
Address 01: DTCs clearedFriday,27,September,2013,11:58:12:32264
изчистих ги и вече неиска да запали.
шаран 1.9 ТДИ 110 коня не иска да пали
- djniki
- Регистриран на: Вто 29 яну 2008 14:49
- Автомобил: Passat
- Двигател: AVF 2001
- Местоположение: Пазарджик
Последна промяна от IvanMan на Пет 27 сеп 2013 18:13, променено общо 1 път.
Причина: Редактирах заглавието!
- passatfen
- Регистриран на: Чет 12 ное 2009 21:22
- Автомобил: Vw Golf Mk7
- Двигател: CLHA++
- Местоположение: Antwerpen
Re: неиска да пали ! ! !
Една от грешките е че имобилайзера блокира ЕКУ...мисля , че това е главната причина..нека по опитните колеги да се включат
- milmar
- Двигател: 1Z and CBDC
Мен би ме уплашила повече тази:
Звучи в превод като нов компот, дано не съм прав
.- °niksi°
- Бай Брадър
- Регистриран на: Вто 08 юни 2004 11:28
Re: шаран 1.9 ТДИ 110 коня не иска да пали
Не ти пали най-вероятно от разбита шпонка на коляновия вал.
От имото ще пали и гасне след секунда.
Но нито от дебитомера, нито от грешката за компа ще откаже да пали.
65535 ще се махне като отвориш компютъра и си оправиш спуканото вакумно маркуче вътре.
Нафта има ли, да не е дръпнало въздух, но аз залагам на зъбното колело и избягала центровка.
А колегата отгоре не е прав, не го слушай, нищо че звучи така грешката.
Потребители, разглеждащи този форум: KoloezdachaKj и 80 госта
