Здравейте колеги нов съм тук.Наскоро си купих Голф 4 1.9 tdi 110hp Италиянка,лично съм доволен от количката.Вчера я закачихме на диагностика със един познат,излязоха няколко грешки.Дали някой ще може да ми ги преведе?
Sunday,05,August,2018,12:49:21:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
http://www.Ross-Tech.com
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 012 L
Component: 1,9l R4 EDC 0000SG 2812
Coding: 00002
Shop #: WSC 01317
VCID: 193E16268302F2890E-4A3A
3 Faults Found
17964 - Charge Pressure Control
P1556 - 35-10 - Negative Deviation - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
17664 - Engine Coolant Temp Sensor (G62)
P1256 - 35-10 - Open or Short to Plus - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: None
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03304
Shop #: WSC 01317
VCID: 3E74E5BA3AECF5B1DB-4A9C
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 02 AIRBAG VW5 0003
Coding: 12338
Shop #: WSC 01317
VCID: 3566FA960FDA36E90A-4A3A
1 Fault Found
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 801 E
Component: KOMBI+WEGFAHRS. BOO V23
Coding: 01142
Shop #: WSC 80545
VCID: 244037D2B440BF61AD-5000
Subsystem 1 - Part No: Ident
Component: Nr. WEGFAHRS.:VWZ6Z0X1144709
Ident.-Nr. WEGFAHRS.:VWZ6Z0X1144709
1 Fault Found
01176 - Key
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01317
VCID: 70E80B82303853C119-5072
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 Q
Component: ґц4C Zentr4C Zentral-S
VCID: 4C90BF727C50572145-4A3A
Subsystem 1 - Part No: 1J1959801C
Component: 4C Tхrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 4C Tхrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 4C Tхrsteuerger. HL0002H
Subsystem 4 - Part No: 1J4
Component: 1J4951J4959812C 4C Tхrsteuer
2 Faults Found
00913 - Window Regulator Switch; Front Right Driver (E81)
27-10 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
End-------------------------(Elapsed Time: 05:57)--------------------------
Голф 4 1.9 tdi 110hp грешки?
october
- Регистриран на: Нед 01 окт 2017 10:05
- Двигател: ваг ком
- Местоположение: Стз + Плд
Re: Голф 4 1.9 tdi 110hp грешки?
вероятно са стари грешки.... изтрии ги и ако някоя се появи пак тогава пиши.
Потребители, разглеждащи този форум: licho58 и 71 госта
