Здравейте колеги някой може ли да ми помогне и разясни за следните грешки ,които ми излезнаха след сканирането
колата е Голф 4 1.9 ТДИ с код на двигателя ALH 98-99година благодаря на всички отзовали се предварително!
VCDS-Lite Version: Release 1.0
Thursday, 03 March 2016, 15:40:57:0
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,47,55,56,57,75,76
Address 01: Engine Labels: 038-906-018-AGR.LBL
Controller: 038 906 018 AN
Component: 1,9l R4 EDC G53SG 1819
Coding: 00002
Shop #: WSC 01317
2 Faults Found:
00626 - Glow Plug Indicator Light (K29)
31-10 - Open or Short to Ground - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 08: Auto HVAC Labels: 3Bx-907-044.LBL
Controller: 3B1 907 044 A
Component: CLIMATRONIC S 7.0
Coding: 01000
Shop #: WSC 01279
3 Faults Found:
00792 - A/C Pressure Switch (F129)
35-00 - -
01272 - Positioning Motor for Central Flap (V70)
01273 - Fresh Air Blower (V2)
Address 15: Airbags Labels: 1J0-909-60x-VW3.LBL
Controller: 1J0 909 609
Component: A AIRBAG VW3 SG 0001
Coding: 00065
Shop #: WSC 01317
4 Faults Found:
01217 - Side Airbag Igniter; Driver Side (N199)
32-00 - Resistance too High
01218 - Side Airbag Igniter; Passenger Side (N200)
00588 - Airbag Igniter; Driver Side (N95)
32-10 - Resistance too High - Intermittent
01281 - Airbag; Drivers Side; Disabled
05-10 - Input Open - Intermittent
Address 46: Central Conv. Labels: 1J0-959-799.LBL
Controller: 1J0 959 799 H
Component: 01 Zentral-SG Komf.0001
Coding: 04097
Shop #: WSC 01317
3 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
00931 - Locking Module for Central Locking; Rear Right (F223)
End --------------------------------------------------------------------------------------------------
Golf MK4 1.9 TDI Помогнете с малко инфо относно тези грешки от Ваг-Ком
caleb85
- Регистриран на: Нед 13 юли 2008 11:11
- Местоположение: Добрич
Последна промяна от ivostefanov на Съб 05 мар 2016 10:19, променено общо 1 път.
Причина: Единствената помощ от мен е да ти оправя заглавието според правилата. Придържай се към тях!
