Дигитален скоростомер на Голф 4? - решение
s5501na
Регистриран на: Чет 20 юли 2006 19:46
Re: Дигитален скоростомер на Голф 4? - решение
Мнениеот s5501na » Съб 07 мар 2009 21:04
houzeboy написа:Аз съм със 195/95/15 и мисля, че ми показва почти вярно и на двата спидометъра.
Може би разлика километър-два, щото не може да гледаш и таблото и климатроника едновременно =щ
Поне аз не мога =щ
Колега май нещо обърка :lol:
Или караш Голф 4 кънтри? :lol:
s5501na
Мнениеот s5501na » Съб 07 мар 2009 21:17
Ето след малко ровене ви давам списък с функциите:/ако някой иска може да ги преведе/
Climatronic Trick – Climatronic Diagnostic Codes
The speedometer has a factory built-in error to show a speed faster than your actual speed. The Climatronic (automatic
climate control) system includes a number of sensors that you can access through the diagnostic mode. To see your true
speed in digital format press the following key combinations:
1. Press Fan Down, Temperature Colder, ECON at the same time.
2. Use the temperature control buttons to cycle through the various channels to Channel 16.
3. Press ECON to go back to normal. (It goes back automatically when you restart the car.)
This information was originally posted by Syncro Driver @ VWvortex forums:
There are a total of 45 diagnose channels numbered from 0 to 44. Some readouts represent a measured value and can't be
altered--for example the amount of light that the sunshine-sensor on the dashboard measures. Others represent the actual
adjustment and can be altered--for example the speed of the blower in 256 steps.
It's not possible to make permanent adjustments so don't be afraid to try it at your own Climatronic. (Stargazer's
Disclaimer: I am not responsible for any damage which may occur to your vehicle by attempting to use these techniques.)
[quote]
"The channels that I know the meaning of are:
1 Interior temperature (sensor)
3 Sunlight sensor
7 Coolant temperature sensor
9 Blower speed (adjustable)
10 Measured blower speed (sensor)
11 Defog valve (adj. 0-255)
12 Dashboard ventilation valve (adj. 0-255)
13 Recirculation valve (adj. 0-255)
14 Lower ventilation valve (adj. 0-255)
16 Speed (sensor)
Contents of 1 system error # system error
2 actual value feeler virtually # actual VALUE sensor virtual
3 actual value of interior feelers console # actual VALUE internal sensor CONSOLE
4 actual value outside temperature feeler wasserkasten # actual VALUE outside temp sensor water reservoir
5 actual value outside temperature feeler bumper # actual VALUE outside temp sensor more bumper
6 actual value blowing out feeler floor space # actual VALUE bloweroutlet sensor footspace
7 actual value blowing out feeler Mannanstroemer # actual VALUE bloweroutlet sensor dashboard
8 display CHECKS #
9 actual digital value answering potentiometer temperature flap # actual digitally VALUE feedback potentiometer temp valve
10 debit digital value temperature flap # set digitally VALUE temp valve
11 actual digital value answering potentiometer A/C flap
12 debit digital value A/C flap
13 actual digital value answering potentiometer Fuss/Def. Flap
14 debit digital value Fuss/Def. Flap
15 actual digital value answering potentiometer ram air flap
16 debit digital value ram air flap
17 driving speed (km/h) 16
18 actual value of the blower voltage (volt) 19 desired value of the blower voltage (volt)
20 actual value of the compressor/on-board voltage (volt)
21 amount of of low-voltage events (not volatile)
22 switching status of the high pressure feeler
23 number of high pressure events (volatile)
24 number of high pressure events (not volatile)
25 A/D value kickdown switch
26 A/D value hot light
27 engine speed
28 compressor number of revolutions
29 coding
30 software-Version
31 software index of
32 potentiometer error counters temperature flap of
33 potentiometer error counters A/C flap of
34 potentiometer error counters Fuss/def. Flap of
35 potentiometer error counters ram air flap
36 temperature flap impact coldly
37 temperature flap impact warmly
38 A/C flap impact closed
39 A/C flap impact openly
40 Fuss/Def. Impact Def folds.
41 Fuss/Def. Impact foot
42 ram air flap impact on
43 ram air flap impact folds to
44 operating cycle counters
45 interior temperature counted (Nine) dig
s5501na
Мнениеот s5501na » Съб 07 мар 2009 21:29
Ето и един линк с трикове за колегите с Голф 5етички:
http://uk-mkivs.net/forums/p/5475/55054.aspx#55054
VW Golf VR6
Регистриран на: Вто 28 авг 2007 18:08
Мнениеот VW Golf VR6 » Съб 07 мар 2009 21:52
Браво на колегата "s5501na" Това чаках. Поклон от мен :bowdown и ГОЛЯМО благодаря :applause:
eng.Kostadinov
Регистриран на: Сря 13 авг 2008 19:07
Мнениеот eng.Kostadinov » Съб 07 мар 2009 22:18
Здравейте колеги,
какво сте се сдърпали какво показва по точно и какво не показва по точно. Тахометъра показва с |5|% грешка. За дигиталното показание ще ви излъжа, но е около 4% дължащо се на голямата стъпка на тарировката на аналоговото табло. И както г-н Томов, или както го наричам аз - бай-Радо ще каже : Радара ще покаже най точно с колко се движите, макар че и неговата грешка не е малка mhihi .
Поздрави
s5501na
Мнениеот s5501na » Нед 05 юли 2009 13:53
Ето и превод на ф-циите благодарение на Google Translate
Climatronic Трик - Climatronic Диагностичния Кодекси
Скоростомера има фабрика вграден в грешка, да се покаже на скоростта-бързо, отколкото действителната скорост. В Climatronic (автоматична
климата контрол) Системата включва определен брой датчици, които можете да достигнете чрез диагностичните готовност. За да видите истинската ти
скорост в цифров формат, натиснете клавиша за следните комбинации:
1. Прес Фен Down, температура студена, ECON по същото време.
2. Използвайте бутоните за контрол на температурата на цикъла чрез различни канали, за да Channel 16.
3. Прес ECON да се върне към нормалното. (Тя се връща автоматично при рестартирането на автомобила.)
Тази информация беше първоначално публикувано от Syncro Driver @ VWvortex форуми:
Има общо 45 диагностицират канала номерирани от 0 до 44. Някои readouts представлява измерената стойност и не може да бъде
променени - например количеството на светлината, че слънце-датчик на табло мерки. Други представляват действителна
настройка и може да бъде променена - например скоростта на вентилатор в 256 стъпки.
Това не е възможно да се правят постоянни корекции, така че не се страхувайте да опитате на свой собствен Climatronic. (Stargazer на
Отговорности: Аз не съм отговорен за всички вреди, които могат да се появят на вашия автомобил се грижи за използването на тези техники.)
[цитат]
"В канали, които знам по смисъла на са:
1 вътрешните температура (сензор)
3 Сънлайт сензор
7 охладител температурата сензор
9 Нагнетател скорост (регулируема)
10 Измерени вентилатор скорост (сензор)
11 Defog клапан (adj. 0-255)
12 Табло вентилация клапан (adj. 0-255)
13 Рециркулация клапан (adj. 0-255)
14 Долен вентилация клапан (adj. 0-255)
16 Speed (сензор)
Съдържание на 1 система за грешка # системна грешка
2 действителната стойност пипалце почти # действителната им стойност, сензор виртуален
3 действителната стойност на интериора feelers конзола # действителната им стойност, вътрешен сензор конзола
4 действителната стойност извън температура пипалце wasserkasten # действителната им стойност, извън температурата на сензора вода резервоар
5 действителната стойност извън температура пипалце броня # действителната им стойност, извън температурата на сензора за допълнителна броня
6 действителната стойност разпенващ изложени пипалце етаж пространство # действителната стойност bloweroutlet сензор footspace
7 действителната стойност разпенващ изложени пипалце Mannanstroemer # действителната стойност bloweroutlet сензор табло
8 дисплей ПРОВЕРКИ #
9 действителната стойност цифров телефонен Потенциометър температура предкрилка # действителната им стойност, цифрово обратна Потенциометър температура клапа
10 дебитираме цифрова стойност температура предкрилка # набор цифрова стойност температура клапа
11 Край на цифровата стойност отговор Потенциометър A / C предкрилка
12 дебитираме цифровата стойност, A / C предкрилка
13 Край на цифровата стойност отговор Потенциометър суетлив / Def. Предкрилка
14 дебитираме цифрова стойност суетлив / Def. Предкрилка
15 Край на цифровата стойност отговор Потенциометър овен въздуха предкрилка
16 дебитираме цифрова стойност овен въздуха предкрилка
17 шофиране скорост (km / h) 16
18 действителната стойност на вентилатор напрежение (волт) 19 желаната стойност на вентилатор напрежение (волт)
20 действителната стойност на компресора / на борда на напрежение (волт)
Размер на 21 на ниското напрежение събития (не летливи)
22 смяна статута на високо налягане пипалце
23 броя на високо налягане събития (летливи)
24 броя на високо налягане събития (не летливи)
25 A / D стойност kickdown превключвате
26 A / D стойност топла светлина
27 обороти на двигателя
28 компресора брой обороти
29 кодиране
30-версия на софтуера
31 софтуерни индекс на
32 Потенциометър грешка броячи на температурата предкрилка
33 Потенциометър грешка броячи A / C предкрилка на
34 Потенциометър грешка броячи суетлив / DEF. Предкрилка на
35 Потенциометър грешка броячи овен въздуха предкрилка
36 температура предкрилка въздействието студено
37 температура предкрилка въздействието топло
38 A / C предкрилка въздействието затворена
39 A / C предкрилка въздействието открито
40 суетлив / Def. Влияние Def гънки.
41 суетлив / Def. Влияние крак
42 овен въздух предкрилка влияние върху
43 овен въздух предкрилка въздействието на гънки
44 операционна цикъл броячи
45 интериорни температура брои (девет) DIG
Потребители, разглеждащи този форум: Google [Bot] и 88 госта
