Схема бушони-Голф4
eliantonova
- Регистриран на: Сря 29 сеп 2010 20:07
- Местоположение: rakovski
Схема бушони-Голф4
Здравейте, колеги! Някой можели да ми каже как се разчита схемата на бушоните? Благодаря!
- baivan
- Регистриран на: Вто 06 фев 2007 13:49
- Автомобил: Vento
- Двигател: 1.8T
- Местоположение: Разлог
Re: Схема бушони-Голф4
Fuses:
1 - Washer nozzle heaters, glove compartment light, memory seat control module 10A
2 - Turn signal lights 10A
3 - Fog light relay, instrument panel light dimmer switch 5A
4 - License plate light 5A
5 - Comfort system 7.5A
6 - Central locking system 5A
7 - Back-up lights, speedomter vehicle speed sensor 10A
8 - Open
9 - ABS 5A
10 - Engine control module (ECM), gasoline 10A - Engine control module (ECM), diesel 5A
11 - Instrument cluster, shift lock 5A
12 - Data link connector (DLC) power supply 7.5A
13 - Brake lights 10A
14 - Interior lights, central locking system 10A
15 - Instrument cluster, automatic transmission 5A
16 - A/C-clutch, after-run coolant pump 10A
17 - Open
18 - Right headlight, high beam 10A
19 - Left headlight, high beam 10A
20 - Right headlight, low beam 15A
21 - Left headlight, low beam 15A
22 - Parking & sidemarker lights, right 5A
23 - Parking & sidemarker lights, left 5A
24 - Windshield and rear window washer pump, winshield wiper motor 20A
25 - Fresh air blower, cimatronic, air conditioning 25A
26 - Rear window defogger 25A
27 - Motor for rear windshield wiper 15A
28 - Fuel pump (FP) 15A
29 - Engine control module (ECM), gasoline 15A - Engine control module (ECM), diesel 10A
30 - Sunroof 20A
31 - Automatic transmission 20A
32 - Engine control, injectors, gasoline 10A - Engine control module (ECM), diesel 15A
33 - Headlight washer system 20A
34 - Engine control elements 10A
35 - 12V power outlet (in luggage compartment) 30A
36 - Fog lights 15A
37 - Terminal (86S) on radio, instrument cluster 10A
38 - Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid 15A
39 - Emergency flasher system 15A
40 - Dual horn 20A
41 - Cigarette lighter 15A
42 - Radio system 25A
43 - Engine control elements 10A
44 - Heated seats 15A
eliantonova
Благодаря,колега!
- GREEN_lADY
- Регистриран на: Нед 11 май 2008 21:02
Полезна тема !
barutchiev
- Регистриран на: Пет 29 май 2015 18:12
- Автомобил: VW BORA
- Двигател: AUS 2000
Здравейте съфорумци.Знам,че има на доста места снимки на предпазителите ни,но на повечето места са на английски,а не всеки си ги превежда.Реших да кача една снимка от книгата за експлоатация,ремонт и поддръжка на Голф 4/Бора/Джета. Мисля,че е бях качвал и в някоя друга тема пак,но тази е по-специфична и може да помогне на някой.Съжалявам за качеството,но е от телефон,а нямам скенер
ПП.Най-добре се вижда,като се отвори линка за споделяне на снимки и се избере "Изтегляне на оригинала". Тогава вече лесно се зумва,че шрифта е доста дребен
Потребители, разглеждащи този форум: Google [Bot] и 80 госта
