Mой приятел има проблем с голфа. Колата отказа да пали и се оказа след диагностика че е датчик на коляновия вал- engine speed sensor. Датчика е подменен и колата пали вече, но няма мощност повече от 140 не вдига на пълна газ на 5та. След диагностика изчистихме грешката на датчика и не се появи повече, но излизат други грешки които не се трият. Прилагам по долу резултата от диагностиката.
VCDS Version: Release 11.11.4
Data version: 20120807
Tuesday,02,October,2012,10:52:55:47516
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 140390km/87234miles
Address 01: Engine Labels: 06A-906-018-AQY.lbl
Part No: 06A 906 018 CS
Component: 2.0l R4/2V MOTR HS V05
Coding: 00000
Shop #: WSC 31414
VCID: 75ED62D74CC136AB205
6 Faults Found:
16706 - Engine Speed Sensor (G28)
P0322 - 35-10 - No Signal - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16688 - Cylinder 4
P0304 - 35-10 - Misfire Detected - Intermittent
16688 - Cylinder 4
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 H
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
Shop #: WSC 31414
VCID: 366FA5DB11477DB3E9F
2 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
35-00 - -
04-10 - Mechanical Malfunction - Intermittent
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 609
Component: A AIRBAG VW3 SG 0002
Coding: 00065
Shop #: WSC 31414
VCID: ECDBC7B39F8B77634FB
5 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
32-00 - Resistance too High
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00589 - Airbag Igniter 1; Passenger Side (N131)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
00595 - Crash Data Stored
35-00 - -
Address 17: Instruments Labels: 1J0-919-xxx-17.lbl
Part No: 1J0 919 881 B
Component: KOMBI+WEGFAHRS. MM0 V17
Coding: 00142
Shop #: WSC 38016
VCID: 316596C7F8295A8BBCD
Subsystem 1 - Part No: Ident
Component: Nr. WEGFAHRS.:VWZ6Z0W0632125
Ident.-Nr. WEGFAHRS.:VWZ6Z0W0632125
No fault code found.
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 4E Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 31414
VCID: 840B8F13971B9F23A7B
Subsystem 1 - Part No: 1J1959801C
Component: 4E Torsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 4E Torsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 4E Torsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 4E Torsteuerger. HR0002r
3 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
End ---------------------------------------------------------------------
Малко проблеми с голф 4
- mania
- Регистриран на: Съб 27 яну 2007 11:52
Re: Малко проблеми с голф 4
Пропуснал си да кажеш за какъв мотор говорим. Колко е вдигала преди това? Ако е 1.4, мисля, че някъде до толкова си може. (Разсъждавам по логика, 1.6 на един приятел вдига малко над 160, а е технически изправен).
владислав
- Регистриран на: Чет 05 мар 2009 10:58
- Автомобил: VW T Roc
- Двигател: DXD TSI 2025
Не е 1,4 а 2.0 кубика, колега има грешка за 4-ти цилиндър, ако е на отделни бубини разменете с тази на 3-та и вижте дали няма да даде грешка на 3-ти. Ако на 3 цилиндъра вдига 160, представям си на 4-ри.
Между другото гърмял е пасажерският еърбег, може грешките да ги пишете в google.bg и там ще намерите вариантите за отстраняване.
apolon
- Регистриран на: Пет 15 окт 2010 6:14
- Автомобил: BORA 1.6 16V
- Двигател: AUS 2000
- Местоположение: Razgrad
Твърде много грешки за нормален автомобил.Май колата не сте я водили на доктор откак се е родила.Е време е за там или за моргата.
- blade84
- Регистриран на: Чет 05 май 2011 17:36
- Автомобил: Vento
- Двигател: AAZ
- Местоположение: Lom
apolon написа:Твърде много грешки за нормален автомобил.Май колата не сте я водили на доктор откак се е родила.Е време е за там или за моргата.
Колата е на реалните км които пише горе, но момчето претърпя сериозна катастрофа с нея и сега се опитваме да я оправим, иначе е на крака и върви. Мотора е 2.0 бензин. Бобината е една и няма как да разменяме. Иначе колата гори малко масло и има неспокоен празен ход. Не зная откъде да тръгна, дали да сваля свещите и да ги прегледам за масло, или да почна проверка на бубината. На малките предавки се реже добре и има мощност но не вдига повече от 140 на 5та. Иначе някой ако знае колко трябва да е предверението на празен ход и на кой канал да гледам на VCDS, да го проверим и него.
lubopa4kata
- Регистриран на: Съб 29 май 2010 10:39
- Местоположение: lom
na geni golf4eto!
ceko84
- Регистриран на: Нед 13 юли 2008 23:09
- Автомобил: Passat B5 AFN Synhro
- Местоположение: Видин
Мойта е 1.4 16V и съм вдигал 170.повече не може,но 170 ги вдига.Едва ли ила голф 4 който да не може да развие 170 км.ч та било то и SDI-тоmania написа:Пропуснал си да кажеш за какъв мотор говорим. Колко е вдигала преди това? Ако е 1.4, мисля, че някъде до толкова си може. (Разсъждавам по логика, 1.6 на един приятел вдига малко над 160, а е технически изправен).
- zografski
- Регистриран на: Сря 25 мар 2009 18:10
- Автомобил: Golf IV V6 4Motion
- Двигател: AUE 2001
- Местоположение: Sofia
Тук не става въпрос за скорост! Компа е натрупал прекалено много грешки, когато всичко по колата се оправи и грешките се изтрият без да се появят на ново колата ще вдига и 220км/ч. или колкото е написано в техническите характеристики като макс. скорост. Първо започнете да оправяте 1 по 1 грешките и малко по малко до финал!
6 Faults Found:
16688 - Cylinder 4
16688 - Cylinder 4
Това трябва да са ти грешките който трябва да оправиш първо, оправиш ли тях колата ще лети като пушка!
3 Faults Found:
35-00 - -
Това са второстепенни грешки които са свързани с интериора.
6 Faults Found:
16688 - Cylinder 4
16688 - Cylinder 4
3 Faults Found:
35-00 - -
аз с тая кола сам правил 245 вие казвате 4е пове4е от 170 не може просто ако знае некои не6то по вароса да сподели а не само глупости да се ръсат,и па4ка незнам от на4алото на форума да пи6е пежо.
lubopa4kata
fastgo написа:аз с тая кола сам правил 245 вие казвате 4е пове4е от 170 не може просто ако знае некои не6то по вароса да сподели а не само глупости да се ръсат,и па4ка незнам от на4алото на форума да пи6е пежо.
245!Re: Малко проблеми с голф 4
е люби ние с тебе с тия 2 литрови кенефи май загазихме яко само дето о6те мотора ми не е отварям ама ни6то не се знае,4е видиме кво 4е каже дедото ако е оправил твойта зна4и и моита 4е може да кръпне
- RO$$KO
- Регистриран на: Пон 31 авг 2009 15:04
- Автомобил: VW MK6 GTI
- Двигател: TSI EA888 2009
lubopa4kata написа:fastgo написа:аз с тая кола сам правил 245 вие казвате 4е пове4е от 170 не може просто ако знае некои не6то по вароса да сподели а не само глупости да се ръсат,и па4ка незнам от на4алото на форума да пи6е пежо.
245!
Ако колата не е правена или километража не е верен или това е чиста лажа!!!
кое е лажа колега като я оправа 6те те поканя да те повозя малко.и нее пипана колата
- RO$$KO
Тази кола без да е пипана няма как да дигне 245 освен ако няма някакав зверски наклон в бг за които незнам
http://www.auto-data.net/bg/?f=showCar&car_id=8679
http://vw.testdrive.bg/modification/425 ... 115Hp.html
Ако ти деиствително не лажеш значи километража ти не е верен.
по твоита логика моита кола VW MK4 V6 2.8 204h.p Трябва да вдига 300+ км
lubopa4kata
fastgo написа:е люби ние с тебе с тия 2 литрови кенефи май загазихме яко само дето о6те мотора ми не е отварям ама ни6то не се знае,4е видиме кво 4е каже дедото ако е оправил твойта зна4и и моита 4е може да кръпне![]()
2.0 115h ne e lo6 motor,ma kapitulira li e mn lo6o,pri audito garnituri,pri tebe mn po lo6i ne6ta,ma moje da se opravi vsi4ko
