Добра ли е тази цена за това:
musura
Сър
Местоположение: Голям Поровец
Мнениеот musura » Вто 09 сеп 2008 18:54
SBC 408 STROKER w/ AFR CNC PORTED HEADS
530 HP / 520 FtLbs
Memberprice: € 2500
T and L Engine Development stuffs over 25 years of NASCAR experience and success under your hood. We are a NASCAR race engine facility that has recently developed a variety of custom stroker engines for your street vehicle. Each engine is DYNO TESTED and backed by a 12 MONTH, 12,000 MILE WARRANTY.
408 Chevy A-3
• 4340 Forged steel crankshaft - 4.000" stroke
• 4340 Forged H-beam rods
• Forged pistons
• Moly file fit rings
• 350 GM 4 bolt block painted color of your choice
• Dura-bond cam bearings
• Block plug kit
• Oil filter adapter
• Hydraulic roller camshaft
• True double roller timing set
• Custom gasket set
• Chrome timing cover
• Professional products balancer
• Balancer bolt
• Melling oil pump
• Melling oil pump drive shaft
• Melling oil pump pickup
• Hydraulic roller lifters
• AFR CNC ported aluminum heads
• ARP Head bolts
• 7/16 screw in rocker studs
• Comp cam push rods and guide plates
• Aluminum full roller rocker arms
• Edelbrock RPM Air Gap manifold
• Chrome valve covers
• Chrome oil pan
• Autolite spark plugs
• Oil filter
• New 12pt bolt kit
Labor
• All parts hand cleaned
• Block sonic checked for thickness
• Block pressure tested @40 psi
• Block stroker clearanced
• Block square decked w/BHJ fixturing
• Aligned hone mains
• Bored and honed w/torque plates
• All clearances checked to the nearest .0001”
• Rotating assembly balanced
• Engine blueprinted w/specs sheet on file
• Engine fully assembled and dressed to customer specifications
• DYNO TESTED
• DVD of dyno session supplied to customer
• 1 Year 12,000 mile WARRANTY
ANDREYO
Местоположение: DUB SQUAD
Мнениеот ANDREYO » Вто 09 сеп 2008 19:06
Ми според мен да но с ква горивна система ?карб? но бая голем требе,а и зависи закво ти трябва?
The_Machine
Мнениеот The_Machine » Вто 09 сеп 2008 19:27
После де ще дириш колектори, карб и Т.Н. за такоз прасе...
Инак едно Холи ще му дойде мноого хранително :-D
Vizor
Изгубена душа
Автомобил: Subaru Forester XT
Мнениеот Vizor » Вто 09 сеп 2008 19:57
Всичко се прави.. колектори молектори.. ама с ко ще го храниш това ? карб? инжектори ?! :)
Stenly
Регистриран на: Пет 29 апр 2005 23:22
Местоположение: София VW Golf mk1 1600GTI EG
Мнениеот Stenly » Вто 09 сеп 2008 22:05
В щатите тея мотори обичат много да ги турбинират и в много случай и над 1000 се покачват конете. Иначе оригиналната горивна с-ма за тоя мускул си е карбураторна.
group®
Темерут
Автомобил: Passat B8 Alltrack
Двигател: DFCA
Мнениеот group® » Вто 09 сеп 2008 22:26
А аз се чудя скоростна кутия от къде ще му се намери :roll:
vaskoto1
майстор Падна ли ми!
Мнениеот vaskoto1 » Вто 09 сеп 2008 22:34
умен човек беше казал:
Умен човек написа:Speed costs money. How fast would you want to go?
yoda :012:
Върни се в “Силов тунинг”
