Някой да иска да ми купи това?? (Моля ви, моля ви....
prj57
Регистриран на: Вто 08 юни 2004 12:04
Местоположение: София, Лондон
Мнениеот prj57 » Вто 07 дек 2004 14:32
Той с шейна или с автовоз ще идва тая година......
brabus
R-циклопедист на VW
R-циклопедист на VW
Двигател: 1991 2003
Мнениеот brabus » Вто 07 дек 2004 16:14
Посвещава се на prj57
Engine: 2ltr 8v block with 16v 1.8 kr head, Custom billet cams 336'' / 328'', ferrea custom titanium valves,mechanical rocker arms, triple cam springs, je custom pistons, titanium pauter rods, ARP main stud kit,ARP head stud kit,custom 4340 main bearings caps, custom 4340 billet crank. Setrab oil cooler.
Comp ratio: 11,2:1
Turbonetics turbo Y2k custom order Bbearing Qtrim (120lbs~ 1200hp capable) , 8 x 720cc fuel injetors, custom intake, custom fuel rails, custom 4 to 1 exsaust steel manifold, turbonetics racegate,aeromotive 2 x fuel regulators, 3 x bosch fuel pumps, Haltech E6x managment, msd dis2 ignition, msd 4 x coils, custom 120mm steel exsaust pipe, turbonetics godzila bov, custom intercooler 82cm x 44cm x 8cm. Custom fuel cell.
Transmition: 4wd system from syncro passat with custom internals and gemini parts.
Wheels: custom order 7 x 19'' work vsxx 5x100.
Tires: Pirreli pzero 215/35/19
Brakes: frond 405mm(16'') drilled custom discs with porsche gt3 leman 6piston calipers. Rear 355mm(14'') drilled discs with porsche 4pot calipers.
Suspension: Proflex
ЕДНО МАЛКО КУЛЪРЧЕ!!!!!!!!!!!
Потребители, разглеждащи този форум: Няма регистрирани потребители и 141 госта
