На колко пари ви "стъпват" колите годишно с покупка, ремонти
joro_kem
Двигател: AXR DFFA
Re: На колко пари ви "стъпват" колите годишно с покупка, рем
Мнениеот joro_kem » Сря 07 май 2014 21:36
шкода октавия I tour 1.9 74 kW 2008 комби - закупена от ЕТ на 28 км за 30 000 лв.
Consumption:
6,60 l/100km 128.205 km and 8.467 l
CO2 emission: 174 g/km 128.205 km and 22.353 kg
Tires:
Summer 6.58 l/100km 82.021 km and 5.394 l
Winter 6.65 l/100km 46.184 km and 3.073 l
Driving style:
Moderate 6.14 l/100km 5.281 km and 324 l
Normal 6.60 l/100km 114.750 km and 7.570 l
Fast 7.00 l/100km 8.174 km and 572 l
Routes:
Motor-way 6.41 l/100km 72.910 km and 4.673 l
City 6.61 l/100km 117.514 km and 7.772 l
Country roads 6.52 l/100km 105.091 km and 6.850 l
Extras:
A/C 6.27 l/100km 20.580 km and 1.290 l
Fuelsort:
Diesel 6.60 l/100km 128.205 km and 8.467 l
Fuel costs: 15,34 BGN/100km 128.205 km and 19.661 BGN
Change tires 1.052,90
15.11.2013 123.200 2 new Debica Frigo 2 195/65/15 + service 179,60
20.03.2013 110.006 winter Debica Frigo II -> summer Conti Premium Contact 2 (total 9030 km for the season) 19,60
31.10.2012 100.970 Conti Super Contact2 -> Debica Frigo2 17,70
15.03.2012 84.250 summer tyres on 20,00
14.10.2011 76.720 winter tyres Debica Frigo 2 18,00
20.03.2011 62.700 4 new summer tires 195x65x15 91h - Continental premium contact 2, DOT 0911 375,00
09.10.2010 52.500 summer Matador -> winter Debica 20,00
22.03.2010 41.300 winter -> summer (DEBICA -> MATADOR) 16,00
29.10.2009 35.280 Tires change (summer->winter) 16,00
30.03.2009 20.620 original summer tyres MATADOR 195/65/15 16,00
19.11.2008 11.644 winter tyres DEBICA FRIGO2 195/65/15 355,00
Change oil 1.701,19
20.06.2013 114.400 Castrol Magnatec Diesel 5W40 fully synt 4 l 55 BGL Mahle oil fuel and air filters and change 74 BGL 129,00
05.03.2013 108.820 transmission oil change (1.75 l) Castrol Syntrans Transaxle 75W-90. 2x24 BGL+5 BGL 53,00
11.10.2012 99.404 power steering fluid - VAG original 1l. 24 BGL / labour 6 BGL 30,00
11.10.2012 99.404 Castrol Magnatec 5W40 4l.-55 BGL/oil-fuel-air-a/c filters Mahle-86 BGL/labour-12 BGL 153,00
28.02.2012 83.290 Castrol 5W40 505.01 B4. total 4 l. oil, fuel, air, pollen filters; general inspection. 144,00
21.06.2011 68.000 engine oil Castrol 5W40 505.01 B4, oil, air, fuel and pollen filters 212,00
19.10.2010 53.330 Castrol Magnatec 5W40 505.01 5 l.; oil, fuel, air, a/c filters Mahle; next: 68300 km or 19.10.11 170,00
07.01.2010 38.350 oil: castrol 5W40 505.01 - 4l / oil filter / air filter / a/c filter / 45 k km inspection 226,85
26.05.2009 23.290 oil / oil filter / fuel filter / air filter / a/c filter / 30 k km inspection 330,00
09.09.2008 8.268 oil / oil filter / air filter / a/c filter / 15 k km inspection 253,34
Maintenance 582,70
05.03.2013 108.820 new front brake disks TRW - 140 BGL + new front brake pads TRW - 60 BGL + 40 BGL 240,00
11.10.2012 99.404 rear disk pads TRW - 54.70 BGN / labour - 30 BGN 84,70
07.06.2012 90.850 A/C maintenance. 30 ml Freon added (of 650 ml total), 20 ml a/c compressor oil added. 20,00
22.06.2011 68.040 a/c freon and oil check - 630 g available, 70 g added + fresh oil 25,00
21.06.2011 68.000 brake fluid change Jurid 40,00
21.06.2011 68.000 rear shock absorbers dust protectors and pads Sachs on both sides 40,00
20.01.2011 59.260 front brake pads PAGID (60 лв.) and front disks repair 80,00
14.05.2010 43.880 a/c pollen filter with active particles 29,00
26.05.2009 23.390 tire balance 24,00
Accessories 422,00
22.01.2013 105.530 front wipers set Bosch Aerotwin 40,00
20.03.2009 20.300 bosch aero twin front wiper blades (set) 46,00
28.02.2009 23.706 navigation system PRESTIGIO GEOVISION 150 269,00
27.05.2008 255 floor mats 67,00
Miscellaneous 69,25
11.05.2012 89.761 driver seat tapestry repair 30,00
11.03.2009 19.274 navi kit mount / change light bulb H4 31,25
28.01.2009 16.280 light bulb H4 8,00
Repair 0,00
26.08.2008 7.280 water pump - guarantee replacement 0,00
Johnsword
Автомобил: Passat B3
Двигател: 1.8 RP1991
Местоположение: Монтана Баце
Мнениеот Johnsword » Пон 02 юни 2014 21:35
Гориво-1200 лева годишно,средно 100 лева на месец,с пестеливо каране
Данъци и такси-250 лева(малолитражна,данък,гражданска,винетка,преглед)
Консумативи-до 200 Лева, масло, филтри, ремъци ако се сменяват, чистачки :Mr Green Fun
Ремонти- Тази година бая.. над 350 лева, предното окачване е изцяло сменено освен пружините. Отзад ме чака изцяло нови, тампони, дискове, без амортисьори и пружини.
Общо около 2000 лева за тази година!Най-грубо пресметнато-толкова струва Пасата ни.
Последна промяна от Johnsword на Пон 18 яну 2016 17:24, променено общо 2 пъти.
НарКол
Регистриран на: Чет 31 мар 2011 8:00
Автомобил: Polo Classic
Двигател: AFT
Мнениеот НарКол » Вто 17 юни 2014 11:55
Много! :exclaim
Преди 3, 1/2 години Полото ми струваше 3000 лв. сега струва 2500 като през тия години съм дал >2500 лв за ремонти, гражданска, прегледи, масла и т.н. Демек, ако нямах кола, щях да спестя едни 3000 лв без да смятаме горивото.
Сменил съм 4 амортисьора, дискове, клеморед, акумулатор, термостат, ламбда сонда, кора под двигателя, тампони на носачите, тампони на двигателя, перка охлаждане, свещи, кабели, тройник, уплътнение на капака на клапаните, ремъци, ролки, съединител, тапи на пода, панел на таблото, скоростен лост, сенник, бензинопровод, ауспух, жило ръчна спирачка и др.
Не знам дали от възрастта (17 г), но май доста кекава излезе тая 3-та серия „народни коли“!
:gruebel
mupk0
Автомобил: Mercedes Benz S202
Двигател: C200 Kompressor
Мнениеот mupk0 » Сря 18 юни 2014 17:24
Водя си нещо като сметка засега и аз :D
КАТ+Екотакси: 400 лв
Данък : 260лв
ГО : 180лв
ГИ : 1100лв
Обслужване : 280лв
Климатик : 70лв
От Януари до Март : 660лв бензин
от Март до сега : 700лв газ + 60лв бензин
Ремонти няма освен освежаване на климатичната уредба и някви дребни работи за 50лв да кажем.
Автомивки : 20лв месечно(грубо 2-3 посещения или 4/5 на такива от типа 5 минути)
Грубо : 3840 лв до момента :D
Мерцедес S202 C200K
Последна промяна от mupk0 на Чет 26 юни 2014 18:42, променено общо 1 път.
dimovip
Регистриран на: Вто 18 авг 2009 19:16
Двигател: ADR
Мнениеот dimovip » Сря 18 юни 2014 19:59
Сериозно ли е да смятам колко давам за кола, която ми върши работа и без нея не мога?По добре ще е да сметна колко ще загубя ако я нямам.Иначе....
Груби сметки 350 лв гориво месечно СРЕДНО
около 100лв месечно за други разходи по колата (сервиз и ароматизатори, автомивки, гумаджии и т.н.)
Покупна цена няма да обявявам, граждански и прегледи и касно няма да слагам, понеже тва си е за всяка кола нормално.Иначе казано около 5500 годишно само гориво и майстори за това което не мога или нямам време да си оправя.Колко бих загубил....много повече на годишна база.
stoyan0304
Регистриран на: Чет 21 ное 2013 21:35
Мнениеот stoyan0304 » Чет 19 юни 2014 14:04
Passat 1.8 газ/бензин, 90 коня.
Бартер + 100 лева горница използвани при регистрацията.
период 20.11.2013г.-19.06.2014г. = 212 дни
Вложени пари за ремонти, граждански и всякакви глупости каквото се сетите без горивото към днешна дата = 1248,87лв.
разходи за гориво:
20.76 литра бензин по 2.56 = 53.14 лева
518.43 литра газ пропан бутан = 640.99 лева
тотал към днешна дата: 1943 лева
изминати километри от 20.11.2013 до днес 4687 км.
цена на километър пробег към днешна дата 0.41 лева.
dimovip
Двигател: ADR
Мнениеот dimovip » Чет 19 юни 2014 20:13
Най на "далавера" е тоя дето си купи кола и стои в гаража.... калкулира само едно овехтяване.Не е критерий колко даваш за колата, а колко я караш.Логично и нормално е като караш повече да ти "стъпва" повече.
slaveiko67
Автомобил: Golf 3 GT TDI
Двигател: AFN 96g
Местоположение: Montana
Мнениеот slaveiko67 » Чет 17 юли 2014 16:43
Голф 2...Тд,JR мотор...ежедневка...:
Закупуване,от колега от :love.vwclub -1200лв.
Пъвоначално обслужване-ремъци,ролки,масло,антифриз- около 300лв.
Последващо:
Дневни светлини-20лв.
Ново/втора употреба/кожено табло,от колега-40лв.
Седалки ог Корадо-около 180лв.
Смяна водна помпа/моя от АБф/-20лв
Къстъм барче с уреди VDO...ала-бала-около 150лв.
Предни амове/мои от АБФ/...50лв.
Джанти-15",малко ретро,с некви гуми-около 200лв.
Втора смяна на масла и консумативи/филтри/-около 100лв.
Гориво...при разход 7/100-предимно градско,за около 10к.км.при 2,50лв. за литър нафта...1750лв. :banghead малее,много бе!!! :drunk ....
Дотука с ...разходите/може и да съм изпуснал нещо,но е незначително или поне аз така мисля/.
И почвам с приходите/от икономии на гориво-от алтернативни горива на нафтата-олио,масло,гас,мас и др./---около 800лв.-Който иска да ги смята...
Скоростна кутия-търкаляща се в багажника-минус 50лв.:mhihiДано е доволен колегата,който я купи от мен/ама ме няма у Некоректни търговци заради нея/???
Като сметнем и некой разлики от продажбите/тънки/ от тази тема--http://www.vwclub.bg/forum/viewtopic.php?f=45&t=395600
Работата отива към изплащане на колата,а тя е отлична/верно,не е Голф 5,6,7/има ли 8?/ да се не излагам :Mr Green Fun Но на мен си ми върши идеална работа.
С това мнение ще си навлеча много негативни отзиви,но не ми дреме...Моля да не се разписваме излишно и да трупаме мнения!
Ако има въпроси и неяснотии...на Л.С. :beer
VWGT
Мнениеот VWGT » Пет 18 юли 2014 11:37
само ако стои на улицата, колата ми "харчи" 235лв на месец.
ако я карам сумата е 350-400 лв на месец, според пробега.
Закупуването и ремонтите извън стандартното годишно обслужване не съм ги броил.
Разбира се в тези сметки не влизат и прилежащите аксесоари към колата, като само за тази година съм набил пари в автобокс, две детски седалки, сенници, автомивки и всякакви други подобни джунжурии, които ако нямах колата, нямаще да ги купувам :)
dobrin
Чингис хан
Мнениеот dobrin » Пет 18 юли 2014 11:51
Голф 5 GT sport 2.0 TDI 170ps DSG ми струва около 55 стотинки на километър към днешна дата. Имам обаче по-големи разходи, които с времето ще се разхвърлят на по-голям пробег, като пълно обслужване на двигателя - ремъци и ролки, масло скоростна кутия, нови зимни и летни гуми, боядисване, окачване и т.н. Та сигурно разходът на км ще падне до около 40 ст. на километър реално. Това включва гориво, застраховки, масла, филтри, някои дребни ремонти, винетки и т.н., на практика почти всичко. На предния ми автомобил - Пасат Б6 2.0 TDI пак беше около 40 ст., като там правих хибридна турбина, сменях от двумасов на едномасов маховик и т.н.
Вълчан
Регистриран на: Нед 17 мар 2013 20:11
Автомобил: Mazda 5
Мнениеот Вълчан » Чет 31 юли 2014 14:12
Така......
VW-UP...на 1 год и 3 месеца.Това са суми за нов автомобил излизащ от Порше.Спечелен на Феста 2013год
Регистрация и номера аптечка и стелки----350лв
Годишно каско---------800лв
Застраховка гражд.----165лв
Данък------------------25лв
Гаранцион. обслужване-250лв
9000км пробег х5.5л на 100км смесено..около 500л по 2.5лв...1250лв
Автомивки 3 пъти на месец ..сам си я мия...15лв х 12 мес....180лв
Общи разходи за една година приблизително.....3020 лв за щастието да управляваш нов автомобил малък клас. :beer
ping23
Регистриран на: Пет 27 мар 2009 17:17
Мнениеот ping23 » Чет 31 юли 2014 14:52
Интересна тема :)
Поло 6н2 1.4тди
Гориво 3600лв на година
Консумативи 3х200 600лв
гражданска 170лв
винтка 65лв
данък около 60лв мисля беше
и средно за ремонти 400лв
4900лв май ще минавам на :a116
vladovelin
Регистриран на: Чет 27 дек 2007 11:18
Автомобил: Golf3 GTI
Двигател: 2E 1994
Мнениеот vladovelin » Съб 02 авг 2014 17:08
Golf3 GTI 2E 1994 год.
Гражданска отговорност 240
Данък 94,50
Винетка 67
ГТП 30
Гараж 600
До тук са 1031,50
следват бензин,масло , гуми ,части, ремонти, автомивка...два фиша от КАТ...
Удоволствието цена няма!!!!
bojilov11
Регистриран на: Чет 09 сеп 2010 17:27
Мнениеот bojilov11 » Чет 07 авг 2014 15:55
VW Golf 4, 1998г., 1.9 tdi, AHF.
По съвсем груби спомени, за малко повече от 3 години, или около 70 хиляди километра:
1. Закупуване - 5500лв.
2. Регистрация и екотакса- 200лв.
3. Гражданска + каско + винетка- 700лв.
4. Първоначално обслужване + дребни ремонти по колата 600лв.
5. Гражданска още 2 пъти до момента 350лв.
6. Още един брой застраховка Автокаско- 300лв.
7. Смяна на съединител и скоростна кутия - около 700лв. (скоростите бяха 2ра употреба за 300лв.)
8. Смяна на дискове и накладки- 300лв.
9. Смяна на паразитна и обтяжна ролка и пистов ремък (след скъсването му) - около 150лв.
10. Ремонти по стартер заради проблем с топлото палене- 150лв.
11. Смяна на механизми на ел. стъкла след неколкократни ремонти- минимум 250лв.
12. Ремонти по ходовата част ( от нея съм най- доволен)- не повече от 200лв.
13. 6 смени на масла и филтри ( по около 100лв. всеки път )6х100= 600лв.
14. 4 нови зимни гуми 15''- BF Goodrich- 420лв.
15. 4 летни гуми 16'' втора употреба- 200лв.
16. Боядисване на детайли- 300лв.
17. Мъченията на Самоковски майстори да ми оправят климатроника ( генерално без траен резултат през годините )- 300лв.
18. Акумулатор- 150лв.
19. Клапан на турбо (не знам точно кой) и работа- 100лв.
20. Автомивки и други дребни разходи за трите години ( крушки, течност чистачки и т.н.) поне 200лв.
21. Накрая, но не на последно място при точно 66 хиляди километра изминати се получава следният разход на гориво: приемаме, че 100 км. се изминават с 6 литра дизелово гориво ( зимата, градско в София категорично съм достигал до 9/ 100, но километрите ги трупам предимно извънградско, без климатик хаха :newsm66 , така, че 6/100 е реално), така се получава, че 1000км. ги изминавам с 60 литра, 66.60= 3960л., приблизително 4000л. гориво. Често съм зареждал на 2.25-2.30 лв. за литър, но и по бензиностанциите често е била 2.65- 2.70, така че приемаме усреднена цена от 2.50 лв. за литър, получава се: 4000л. по 2.50лв. за литър = 10000лв.
Категорично мога да кажа, че съм забравил разходи от порядъка на поне 500лв. Предстои ми смяна на масло, пълно обслужване на автомобила, както и ремонт на климатроника при доказан клубен майстор. Имам крещяща нужда и от 4 нови летни гуми- 205х55х16. Постарах се да съм изчерпателен, за да могат хора, на които им предстои покупка на автомобил, такива, които никога не са се старали да си правят сметката или искат да подменят стария си автомобил с по- нов да добият реална представа. Не мисля, че за целия период ми се е случила фрапатна повреда, като изключим пръснатата на парчета скоростна кутия и климатроника, общо 600лв. (съединителят не го считам, тъй като е консуматив). И в крайна сметка, удоволствието да имам VW Golf 4 за 3 години и 2 мес. ми е струвало 21670лв.
Мисля, че е редно към графата разходи да се добави и ''обезценяване на автомобила'', което в моя случай ще е поне 2000лв. Често сам не съм си вярвал като съм правил тази сметка. Поздрави на всички!
moimoimoi
Мнениеот moimoimoi » Чет 07 авг 2014 17:42
не е важно колко идва на година
по важно е цената на километър колко е
нормално е ако сравним две еднакви коли но с разлика от 100000 км пробег тази с по големия пробег да е с по ниска цена за киломентър
скоро правя една година откакто карам едно поло и за една година или 18000км всички разходи заедно с покупката му идват 2500 лева което е 13.8 стотинки на километър
а ако не смятам покупката на колата идва на 11 стотинки
скоро гледах едно бмв760ил и при него сметката излизаше 3 лева на километър :horror
