Масло TITAN?
Madj0
Регистриран на: Пон 10 апр 2006 13:51
Re: Масло TITAN???
Мнениеот Madj0 » Пон 23 фев 2009 18:30
Fuchs Titan XTR 10w/40 Oil 5 litres
High Performance Semi-Synthetic Engine Oil
TITAN XTR 10W/40 is based on synthesised hydrocarbon technology combined with the latest and highest performance inhibitors available. Detergent, dispersant, oxidation and corrosion inhibitors are incorporated to give excellent performance in modern
gasoline and diesel engines. TITAN XTR 10W/40 offers outstanding performance and durability in today’s high performance engines, both naturally aspirated and turbocharged.
Extreme thermal stability and resistance to deposit formation make TITAN XTR 10W/40 oils suitable for the most severe turbocharged diesel applications in modern light commercial vehicles and in the latest gasoline engines fitted to modern passenger cars.
· SAE 10W/40
· CCMC G5 D4 PD-2
· ACEA A3, B3, B4
· API SL/SJ/CF
· DB 227.5
· VW 500.00 505.00
· US Military MIL-L-46152D
· General Motors GM 6049M
· Registered with MG Rover
· Outstanding thermal stability reduces deposit and sludge formation.
· Excellent low temperature fluidity gives rapid oil circulation on cold start.
· Excellent oil consumption control.
· Superb anti-wear performance protects moving parts and prolongs engine life.
· Gives a reserve of performance even in the highest powered turbocharged gasoline and diesel engines.
· Catalytic converter compatible.
evn
Регистриран на: Пон 23 фев 2009 8:53
Re: Масло TITAN???
Мнениеот evn » Пон 23 фев 2009 18:44
Направо ме учудваш с тази информация, трябва да има повече такива хора.ПОЗДРАВЛЕНИЯ :applause: .Е значи това е с графитна добавка а ?
дзвера
Регистриран на: Сря 07 ное 2007 9:21
Автомобил: ford escape
Местоположение: отвъд голямата локва
Re: Масло TITAN???
Мнениеот дзвера » Пон 23 фев 2009 20:21
аз на моя голфи 3 1.8 75 магарета му сипах ТИТАН в ск. кутия 75W90 и няма грижи 8-9 месеца от тогава
edisonov
Регистриран на: Пет 17 авг 2007 18:21
Автомобил: VW Golf 8 Variant
Двигател: 2025
Re: Масло TITAN???
Мнениеот edisonov » Вто 24 фев 2009 10:34
Ползвам Титан 10-40 вече трета смяна и за сега съм доволен. Поняга го похапва малко но само когато карам по дълго време с обороти около и над 5 хиляди. В резултат на такива по екстремни натоварвания съм доливал максимум половин литър за 10 хил.км. А и цената му е прилична още повече, че го взимам и с отстъпка.
evn
Re: Масло TITAN???
Мнениеот evn » Вто 24 фев 2009 11:20
Проверих за въпросното масло и така то е FUCHS TITAN CFE MC SAE 10W-40,ACEA E3/B3/A3;API CG-4/SJ.Дават го за леки и товарни автомобили.Както писах вече, притеснява ме че не отговаря на vw НОРМИТЕ.В магазина ме уверяват че отговаряло, и го ползвали доста хора вече,направо незнам :banghead:.Мислите ли че няма да има проблем ако използвам това.Колата ми golf iv 1.9 TDI- 110к.с.?????
morfei1
Re: Масло TITAN???
Мнениеот morfei1 » Вто 24 фев 2009 14:52
@evn, незнам въпросният модел масло, кои спецификации на VW покрива, но знам, че официалния представител на Fuchs за България е Aуто+ и според техния каталог маслото ти е Fuchs TITAN SUPERSYN PLUS SAE 5W-40, което е пълно синтетично. Аз карам моята точно с такъв модел, който също покрива стандарта на VW за PD мотори 505.01. Въпросното масло покрива и стандарта за твоя двигател 505.00. Fuchs TITAN SUPERSYN PLUS SAE 5W-40 High Performance, Fuel Economy Motor Oil
Ако решиш да заложиш и ти на това масло, си го купи от Ауто+, а не от някой прекупвач или някакъв псевдо представител. После да няма, ма вие казахте че е хубаво, пък виж к'во стана :wink: .
evn
Re: Масло TITAN???
Мнениеот evn » Вто 24 фев 2009 16:46
Мисля че мойта е малко старичка за 5W-40, в смисъл произведена е 1999г., и се опасявам че ще го гори, защото е много рядко, НО да мога да пробвам и с него.А за относно покупката,ДА абсолщютно от АУТО+ ще е.
evn
Re: Масло TITAN???
Мнениеот evn » Сря 25 фев 2009 16:24
Сега пък от форума на http://www.avtoexpert.net/,споделиха, че FUCHS TITAN CFE MC SAE 10W-40, не било за моята кола, препоръчват ми Fuchs Titan Syn MC 10w-40 ( VW 505.00 ).Колеги някой пробвал ли е въобще това масло с молибдена (FUCHS TITAN CFE MC SAE 10W-40)????
Madj0
Re: Масло TITAN???
Мнениеот Madj0 » Сря 25 фев 2009 16:34
Лелеле колега още ли не смени маслото ... За мен марката е добра ...ама не съм рекламно лице да те убеждавам...... като гледам колко избираш маслото си представям колко си избирал колата
evn
Re: Масло TITAN???
Мнениеот evn » Сря 25 фев 2009 20:20
А бе колега аз отдавна съм заложил на марката, но ти май не четеш добре.Питам конкректно за това масло с М О Л И Б Д Е Н О В А Т А Д О Б А В К А???!!!!!!!!
StS
Регистриран на: Нед 02 юли 2006 1:02
Автомобил: Golf VI
Re: Масло TITAN???
Мнениеот StS » Пет 27 фев 2009 19:30
Колеги може ли някой да ме ориентира за следното нещо, както знаем има много масла и марки, но нека всеки да представи класация според качеството на маслото, примерно 10в40 - следното:
Най- доброто е:
1. Q8
2. Motul, и т.н предполагам ме разбирате, кой е най-добрия производител или поне първите 5 кой са? Защото и до сега не знам примерно кой е най-добрия производител на масла, както Мерцедес при колите като цяло.
evn
Re: Масло TITAN???
Мнениеот evn » Сря 08 апр 2009 14:43
Е айде бе колеги никой ли не е карал с графитената добавка на FUCHS TITAN?????
GodLike
Регистриран на: Чет 19 яну 2006 9:27
Автомобил: VW Touran
Двигател: CRKB 7DSG Highline
Re: Масло TITAN???
Мнениеот GodLike » Сря 08 апр 2009 20:43
Аз карах преди стария ми голф 3 1.9D с такова масло. Мисля, че се водеше Titan CFE 10W40. Мотора работеше по-тихо, но мисля че не отговяря на стандарта 505.01 или нещо такова беше за ТДИ моторите. Не си написал на каква кола мислищ да го слагаш :idea:
theraven
Двигател: SDI
Re: Масло TITAN???
Мнениеот theraven » Сря 08 апр 2009 22:01
Преди няколко дни сложих Fuchs TITAN SuperSyn Plus 5W40 пълна синтетика на мойта помпа дюза. Преди това бях с Кастрол ТХТ уж оригинално от официален сервиз. След смяната ефекта от маслото е супер осезаем. Колата утихна, почна да работи по-спокойно, форсира се по-леко... Абе маслото си е супер, препоръчвам го на всеки, който си гледка колицата. :drunk
morfei1
Re: Масло TITAN???
Мнениеот morfei1 » Сря 08 апр 2009 22:18
@theraven, ефекта при мен беше абсолютно същия. И аз в началото бях с TXT, но на 7300км го махнах. Фукса е вече на 11700км. и нямам никакви намерения да го сменям преди 15000км. За тези километри съм долял 300грама. направи ми впечатление, че ако юркам колицата над 140км. за дълъг период от време примерно Пловдив - София закован на 160км. си "хапва" малко масълце. Иначе с нормално каране 100 ~ 140км. няма ядове и не го пипа.
