Що е то волан във F1...
zmej
Регистриран на: Вто 08 юни 2004 15:35
Автомобил: Audi 8D5 Quattro
Двигател: AJL
Мнениеот zmej » Пет 26 май 2006 14:11
Ей го волана: Изображение
Описание на бутончетата - не съм го превел, някой ако иска, да превежда, но така или иначе се разбира:
www.formula1.com написа:+1 and +10 (green, far left and far right)
Used in conjunction with the MSG OK button (marked with a cross, right) to flick through car function menus, allowing the driver to override certain functions in the case of malfunction. The MSG OK button changes the respective menu of each of the two buttons.
PLS (yellow, with P, left)
Activates the pit-lane speed limiter when entering the pits.
PTT (red, left)
Pit radio button. Used to call the pit crew via radio communication.
DRINKS (grey, left)
Provides drinking fluid to the driver. Operates an electric pump to bring the liquid from a reservoir in the cockpit through a tube to the driver’s mouth.
TC OFF (blue, left)
Switches off the traction control. Mainly used during the formation lap to allow the driver to spin the rear wheels and generate heat in the tyres. Also used when exiting the driver’s pit position, allowing wheelspin, which deposits rubber on the tarmac, providing more grip during pit stops.
A and B (black/purple, black, left)
Used to change the traction control setting ,for hi revs and low revs. The various positions enable the driver to find the correct level of traction control interevention. The optimum level changes due to numerous variables, including the level of grip provided by the tarmac, the track temperature, the amount of rubber deposited on the track etc.
Lower left switch (with positions 2 through 8)
This presets the lowest gear for each corner, allowing the driver to change down through the gearbox quickly, without fear of selecting too low a gear.
C, D and E (black/red, black/white, black/blue, along base of wheel)
These switches adjust the car’s differential setting. These depend on various factors related to the overall set up of the car, the fuel load variation, low gear revs and high gears revs.
F (black/green, bottom right)
This button - a very important one - operates and changes the engine braking settings. As the race progresses and the car’s brakes become gradually less efficient, it is useful to be able to increase the amount of engine braking action.
G (black/yellow, right)
This button sets the rev limit for the engine - the highest revs it can reach in each gear before changing up. A higher setting allows the driver to extract more performance; a lower setting puts less stress on the engine.
H (black/orange, right)
This switch changes specific traction control and differential settings in accordance with the tyres being used - grooved, intermediate or wet - to account for the different levels of grip provided by each type.
R (red, right)
Allows the driver to select neutral and reverse gear.
OT (yellow, right)
The overtaking button. This temporarily increases the engine’s maximum rev limit when extra power is needed for a short period. When the button is released the rev limit returns to its default setting.
Оригиналът е на: http://www.formula1.com/race/news/4419/757.html
CellNet ™
Sheriff
Регистриран на: Съб 07 авг 2004 19:45
Местоположение: Golf Capital of the World
Мнениеот CellNet ™ » Пет 26 май 2006 16:03
да си ги карат болидите, аз не ща mhihi
XpacTa
Регистриран на: Сря 11 авг 2004 16:03
Мнениеот XpacTa » Пет 26 май 2006 17:39
Хмм - може да си сложа едно manettino на волана
само че ще го ползвам да сменям между газ и бензин.
madcap
Кенанския лъв
Автомобил: 1990 VW Golf 2
Двигател: APP turbo
Местоположение: Хасково
Мнениеот madcap » Пет 26 май 2006 18:04
Ха ха , на пилота кога му остава време да гледа пистата, те за туй се блъскат постоянно :roll:
maks
Регистриран на: Чет 03 фев 2005 17:18
Мнениеот maks » Пет 26 май 2006 18:05
С такъв волан ако оцелим пътя съм герой.
w_smith
Автомобил: Golf 3_Volvo XC70
Мнениеот w_smith » Пет 26 май 2006 19:53
С такъв волан и скорости 250+ ако уцелиш пътя си господ!
LiX
Регистриран на: Съб 26 фев 2005 17:07
Мнениеот LiX » Пет 26 май 2006 20:51
Абе той Монтоя както си кара така с 250 си махна огледалото па вие за някъв волан се притеснявате :D Сигурно и със затворени очи знаят кое къде е :drive
Tod
Регистриран на: Нед 19 мар 2006 17:32
Мнениеот Tod » Съб 27 май 2006 12:53
LiX написа:Абе той Монтоя както си кара така с 250 си махна огледалото па вие за някъв волан се притеснявате :D Сигурно и със затворени очи знаят кое къде е :drive
Някой от нас да не би да си гледа краката като сменя предавките :D
leavon
Регистриран на: Съб 29 яну 2005 15:50
Мнениеот leavon » Съб 27 май 2006 15:52
Тия мигачи нямат май?
Tod
Мнениеот Tod » Нед 28 май 2006 8:57
Материал от http://sportni.bg/
Последна промяна от Tod на Нед 28 май 2006 10:39, променено общо 2 пъти.
Geleto
Регистриран на: Сря 25 яну 2006 10:12
Автомобил: Passat B4
Двигател: 1.8 MI 1994
Мнениеот Geleto » Нед 28 май 2006 9:20
Моята жена си гледа .......... :evil:
Tod
Мнениеот Tod » Нед 28 май 2006 10:20
Geleto написа:
:D Шегаджия си ти ...
Ludia
Most Wanted
Регистриран на: Пон 09 яну 2006 16:57
Мнениеот Ludia » Нед 28 май 2006 10:28
leavon написа:Тия мигачи нямат май?
да, и клаксон нямат.. :shock :shock :lol: :lol: :lol:
wili98
Щраусолог
Мнениеот wili98 » Нед 28 май 2006 10:28
Geleto написа:
Щот са убави..
Наще кво да ги гледаме..
криви и космати ;)
Li4o
Аватар:
Регистриран на: Вто 31 авг 2004 18:34
Re: Що е то волан във F1...
Мнениеот Li4o » Нед 28 май 2006 11:10
zmej написа:.....
DRINKS (grey, left)
От тоя бутон и аз разбирам... mhihi :lol:
