спецификации 500.00----05 175 А2
W1978
Регистриран на: Вто 17 апр 2012 17:16
Автомобил: passat
Двигател: AFN
Местоположение: karluvu
Мнениеот W1978 » Сря 03 апр 2013 22:40
Volkswagen Oil Specifications
Volkswagen introduced its own specifications in mid '90s. Since then this classification system is the starting point for selecting the technically suitable products for all vehicles manufactured by the VW group (Volkswagen, Audi, Seat, Skoda).
Check out our new article providing in-depth explanation to all VW motor oil specifications!
Volkswagen Motor Oil Specifications
VW 500.00
Volkswagen specification for multigrade engine oils for gasoline engines with SAE 5W-X/10W-X viscosity. This is an "old" oil specification and is applicable to engines built before model year 2000 (up to August 1999). Oils with an approval made post March 1997 were given an alternative, later VW specification.
VW 501.01
Conventional motor oils suitable for some VW engines built before MY 2000. This is an “old” oil specification and is applicable to engines built before model year 2000 (up to August 1999). Oils with an approval made post March 1997 were given an alternative, later VW specification.
VW 502.00
Oil for gasoline engines. Successor of VW 501.01 and VW 500.00 specification. Recommended for those which are subject to arduous conditions. It must not be used for any engines with variable service intervals or any which are referred to under other specifications.
VW 503.00
Long-life gasoline engine oil for VW cars with WIV (system for longer service intervals). Also meets ACEA A1, SAE 0W-30 or 5W-30 specification.
VW 503.01
This specification is specifically for Audi RS4, Audi TT, S3 and Audi A8 6.0 V12 models with outputs of more than 180bhp, running with variable service intervals (30,000km or 2 years). Now superceeded by the VW 504.00 specification.
VW 504.00
The VW 504 00 specification superceedes the VW 503 00 and VW 503.01 specifications. VW 504 00 oils are suitable for engines meeting the demands of Euro IV emissions standards.
VW 505.00
Passenger car diesel engine oil specification, minimum performance level CCMC PD-2. Lists viscosities SAE 5W-50, 10W-50/60, 15W-40/50, 20W-40/50 requiring 13% max. evaporation loss and SAE 5W-30/40, 10W-30/40 requiring 15% max. evaporation loss.
VW 505.01
Special engine oil for VW turbodiesel engines with pump-injector-unit and for the V8 Commonrail turbodiesel engines. Meets ACEA B4 SAE 5W-40 specification.
VW 506.00
These oils are suitable for diesel engines with extended service intervals of up to 50,000km / 2 years. Not for use on engines with a single injector pump. Oil change is indicated by the electronic service indicator. Viscosity is SAE 0W30.
VW 506.01
These oils are especially for "Pumpe-Düse" (unit injector or "PD" engines) running on extended service intervals (30,000 - 50,000km / 24 months). Oil change is indicated by the electronic service indicator.
VW 507.00
Low SAPS oils suitable for Euro 4 engines and almost all VAG diesel engines from 2000 onwards with extended service intervals, unitary injector pumps and also Pumpe-Düse ("PD") engines. Excludes V10, R5 engines and VW Commercial vehicles without fitted DPF (diesel particulate filters) – these must use a 506 01 specification oil.
VW 508.00
This standard is not yet released. It will probably require a low SAPS oil with energy conserving properties.
Volkswagen Gear Oil Specifications
VW G 009 317
Gear oil for mechanical and automatic 6 gear transmissions.
VW G 052 145 A2
Special synthetic gear oil with SAE 75W90 viscosity for front and rear differentials, including limited slip differentials.
VW G 052 162 A2
Special ATF with viscosity modifier. Suitable for 4 and 5 gear ZF automatic transmissions. Not suitable for 6 gear transmissions.
VW G 052 171
SAE 70W75 viscosity gear oil.
VW G 052 171 A2
Special gear oil designed for the manual transmissions of cars with transverse engines.
VW G 052 175
Special working fluid for Haldex clutches. Developed by Haldex and Statoil.
VW G 052 178
Gear oil with SAE 75W viscosity.
VW G 052 180 A2
Special gear oil for Audi Multitronic transmissions.
VW G 052 190 A2
Special VW gear oil for Multitronic CVT transmissions.
VW G 052 726
Monograde gear oil with SAE 75W viscosity.
VW G 052 798
VW G 052 911
Audi specification for transmissions used with longitudinal engine configurations. Products meeting this specification are of SAE 75W90 viscosity and also meet API GL-5 criteria.
VW G 052 990
Special ATF for automatic transmissions combined with differentials.
VW G 055 005
Special ATF for VW automatic transmissions and transaxles.
VW G 055 145
Transmission oil with 3% Sturaco additive.
VW G 055 162
VW G 055 175 A2
:love.vwclub
W1978
Автомобил: passat
Двигател: AFN
Re: спецификации 500.00----05 175 А2
Мнениеот W1978 » Сря 03 апр 2013 22:42
и ако някои мойе да го преведе
:beer
joro1977
Регистриран на: Съб 12 мар 2011 23:54
Мнениеот joro1977 » Чет 04 апр 2013 8:03
Volkswagen петрола Спецификации
Volkswagen внедри свои спецификации в средата на 90-те години. Оттогава тази система на класифициране е отправна точка за избор на технически подходящи продукти за всички превозни средства, произведени от групата на Volkswagen (Volkswagen, Audi, Seat, Skoda).
Вижте нашия нов член, предвиждащ по-задълбочено обяснение на всички спецификации на VW моторно масло!
Volkswagen моторно масло Спецификации
VW 500.00
Volkswagen спецификация за всесезонни моторни масла за бензинови двигатели с вискозитет SAE 5W-X/10W-X. Това е "стар" масло спецификация и се прилага за двигатели, построени преди моделна година 2000 (до август 1999). Масла със спецификация на одобрение публикация Март 1997 беше дадена алтернатива, по-късно VW.
VW 501.01
Конвенционални моторни масла, подходящи за някои двигатели на VW, построени преди MY 2000ния Това е "стар" масло спецификация и се прилага за двигатели, построени преди моделна година 2000 (до август 1999). Масла със спецификация на одобрение публикация Март 1997 беше дадена алтернатива, по-късно VW.
VW 502.00
Масло за бензинови двигатели. Наследник на спецификация VW 501.01 и VW 500.00. Препоръчва се за тези, които са обект на тежки условия. Това не трябва да се използва за всички двигатели с променливи сервизни интервали или всички, които са посочени от други спецификации, за да се разбере.
VW 503.00
Дълъг живот масло бензинов двигател за автомобили VW с WIV (система за по-дълги интервали на обслужване). Така че спецификацията отговаря на ACEA A1, SAE 0W-30 или 5W-30.
VW 503.01
Тази спецификация е специално за Audi RS4, Audi TT, S3 и Audi A8 6.0 V12 модели с мощност от повече от 180bhp, работещи с променливи сервизни интервали (30000 км или 2 години). Сега superceeded спецификация VW 504.00.
VW 504.00
Спецификация VW 504 00 superceedes на VW 503 00 и VW 503.01 спецификации. VW 504 00 масла са подходящи за двигатели, които отговарят на изискванията на емисии Euro IV стандарти.
VW 505.00
Лек автомобил Спецификацията на дизеловото гориво на маслото в двигателя, минимално ниво на изпълнение CCMC PD-2. Канали вискозитет SAE 5W-50, 10W-50/60, 15W-40/50, 20W-40/50 Изискването до 13%. изпаряването загуба и SAE 5W-30/40, 10W-30/40 Изискването 15% макс. изпаряването загуба.
VW 505.01
Специално моторно масло за VW турбодизелови двигатели с помпа-инжектор дял и за V8 комън рейл турбодизелови двигатели. Отговаря на ACEA B4 спецификация SAE 5W-40.
VW 506.00
Тези масла са подходящи за дизелови двигатели с удължени сервизни интервали до 50,000 км / 2 години. Не и за използването на двигатели с една помпа инжектор. Смяна на маслото е посочено с електронен индикатор услуга. Вискозитет SAE 0W30.
VW 506.01
Тези масла са специално за "помпа-дюза" (единица инжектор или "PD" двигатели) работи на удължени сервизни интервали (30.000 до 50.000 km / 24 месеца). Смяна на маслото е посочено с електронен индикатор услуга.
VW 507.00
Low SAPS масла, подходящи за Евро 4 двигатели и почти всички VAG дизелови двигатели от 2000 г. с удължени сервизни интервали, единна инжекторни помпи и по този начин помпа дюза (PD) двигатели. Изключва V10, R5 двигатели и VW Товарни автомобили без монтиран DPF (дизелови филтри за прахови частици) - те трябва да използват 506 01 спецификация масло.
VW 508.00
Този стандарт все още не е освободен. Това вероятно ще наложи нисък SAPS масло с енергийни опазване свойства.
Volkswagen трансмисионно масло Спецификации
VW G 317 009
Трансмисионно масло за механични и автоматична 6 зъбни трансмисии.
VW G 052 сто четиредесет и пет милиона A2
Специална синтетично трансмисионно масло с вискозитет SAE 75W90 за предни и задни диференциали, включително ограничени диференциали приплъзване.
VW G 052 сто шейсет и два милиона A2
Специална ATF с вискозитет модификатор. Подходящ е за 4 и 5 предавки ZF автоматични трансмисии. Не е подходящ за 6 зъбни трансмисии.
VW G 171 052
Вискозитет SAE 70W75 предавка.
VW G 052 171 A2
Специално трансмисионно масло за ръчни скоростни кутии на автомобили с напречни двигатели.
VW G 175 052
Специален работен флуид за Haldex лапи. Разработено от Haldex и Statoil.
VW G 178 052
Gear масло с вискозитет SAE 75.
VW G 052 180 A2
Специално трансмисионно масло за трансмисии Audi Multitronic.
VW G 052 190 A2
Специална VW трансмисионно масло за трансмисията Multitronic ППО.
VW G 726 052
Сезонно съоръжение масло с вискозитет SAE 75.
VW G 798 052
VW G деветстотин и единадесет 052
Audi спецификация за предавания, които се използват с надлъжни конфигурации на двигателя. Продукти, отговарящи на тази спецификация са на вискозитет SAE 75W90 и по този начин отговаря на API GL-5 критерия.
VW G 990 052
Специална ATF за автоматични трансмисии, съчетани с диференциали.
VW G 005 055
Специална ATF за автоматични трансмисии и трансмисията на VW.
VW G 145 055
Трансмисионно масло с добавка 3% Sturaco.
VW G 162 055
VW G 055 175 A2
DimitarLavov
Регистриран на: Съб 27 окт 2018 0:47
Мнениеот DimitarLavov » Чет 13 дек 2018 17:47
G 055 175 A2 и G 052 175 A1 еднакви ли са като вискозитет и състав или разликата е само, че едното е 1 л. другото 275мл.?
Потребители, разглеждащи този форум: a_iliew и 58 госта
