нещо за доброто "старо" GOLF RALLYE
brabus
R-циклопедист на VW
R-циклопедист на VW
Двигател: 1991 2003
Мнениеот brabus » Пет 10 дек 2004 13:38
Engine: Aba 2ltr tall block, 2157cc (86mm x 92,8) balanced and blueprinted motor. Accralite forged pistons, arrow forged conrods, steel forged crankshaft. Custom corrado g60 head ported and polished. Larger exhaust valves with ported and polished heads. Intake flows 170cfm and exhaust flows 130cfm (stock 16v head flows 165cfm intake and 121cfm exhaust) this 8v motor has more low-end torque and more high-end power while outflowing a stock 16v motor. ABT drilled camshaft 278 degrees, 4 Porsche 993 turbo stage-2 tuned fuel injectors 720cc and one extra sierra cosworth rs500 475cc. Bosch ECU and one parallel connected as well. O-ring wire with custom copper gasket. 9,0:1 comp. HKS custom-made ball bearing turbocharger 0,82 /r Turbine housing (4bolt outlet), 0,70 a/r Compressor housing, water-cooled Center, 56 Trim Compressor Wheel (t04s), 55lbs/min Comp Flow Max, 84 Trim Turbine Wheel. 2 blow off valves by Turbosmart, custom big intercooler, malpassi fuel system, NOS 100-shot stage nitrous kit, custom made racing clutch with stainless steel plate 4mm and 6 pieces of metal. Autotech Lightweight flywheel. ARP head Studs, ARP main stud kit.
Exhaust: Custom made downpipe, stainless exhaust pipe 82mm from manifold to end with two tail pipes.
Transmission: custom made from the16v model with Quaife limited slip differential.
Suspension: Koni racing system, electrical, fully adjusted from the car's interior.
Wheels: Bk 238 Black Chrome 7,5 X 17 Tires: 215/40/17 bridgestone S02
Brakes: Frond: Big Porsche 4-pot red calipers with Brembo 333mm drilled disks. Rear: 305mm Brembo drilled disks.
Other info: 513 hp @ 50,1 kgr. of torque with 2,3 bar steady pressure and 2,5 bar overboost. The dyno showed a top speed of 313 km/h and 3,7 sec 0-100. The car, before the modifications took place and before it was painted, was reinforced at all major points in order to become more rigid and to be able to withstand the increased performance.
:twisted: :twisted: :twisted:
Dic
Регистриран на: Съб 26 юни 2004 19:41
Автомобил: Seat Leon 1M
Двигател: ARL
Мнениеот Dic » Пет 10 дек 2004 16:42
Искам..............искам ........ искам я тази кола!!! bowdown bowdown bowdown
ickata
Регистриран на: Пон 08 ное 2004 9:34
Мнениеот ickata » Пет 10 дек 2004 17:32
ЕБАСИ !!!! bowdown bowdown bowdown bowdown bowdown bowdown bowdown
gti
Регистриран на: Вто 08 юни 2004 10:47
Автомобил: MK4 R32
Двигател: BFH 2003
Re: нещо за доброто "старо" GOLF RALLYE
Мнениеот gti » Пет 10 дек 2004 17:49
brabus написа:top speed of 313 km/h and 3,7 sec 0-100.
Той бил много бавен бе :lol: :lol: :lol:
ПП:Но това не е истинско рали
Sisq0
Регистриран на: Пон 06 сеп 2004 2:36
Мнениеот Sisq0 » Пет 10 дек 2004 21:27
Ах красота :(
~None~
Регистриран на: Вто 15 юни 2004 14:03
Местоположение: EU
Мнениеот ~None~ » Пет 10 дек 2004 22:51
Закарай един такъв на Божурище и дървените глави там веднага ще му намерят кусур.. ;)
°niksi°
Бай Брадър
Мнениеот °niksi° » Пет 10 дек 2004 23:34
~None~ написа:Закарай един такъв на Божурище и дървените глави там веднага ще му намерят кусур.. ;)
Юли много си прав тука.
Иначе Голфа е трепач.
StreetThug16V
Регистриран на: Нед 24 окт 2004 7:11
Мнениеот StreetThug16V » Пет 17 дек 2004 3:02
Ебати тупаницата!
DragoGT
1/8 перничанин
1/8 перничанин
Регистриран на: Вто 08 юни 2004 18:31
Мнениеот DragoGT » Пет 17 дек 2004 9:19
божкеееее :shock: eyecrazy bowdown
inoi
Регистриран на: Пон 14 юни 2004 8:03
Автомобил: VW Golf III
Двигател: AFT 1996
Мнениеот inoi » Пет 17 дек 2004 9:46
Брабусе в тебе няма и капка милост :? Това е Shocked bowdown Shocked eyecrazy :banghead: Не може да се спи бе човек.
GTivan
Регистриран на: Пон 11 окт 2004 9:34
Мнениеот GTivan » Пет 17 дек 2004 23:17
НЯМАМ ДУМИ :shock:
nuno
Регистриран на: Съб 27 ное 2004 21:39
Мнениеот nuno » Съб 18 дек 2004 20:39
Не4ка кажат после на бялото черно.
aga
Регистриран на: Съб 27 ное 2004 2:38
Мнениеот aga » Пон 20 дек 2004 12:34
eyecrazy eyecrazy no comment!!!!
дано дядо коледа ни дава по една такава!
страхотна е за 3.7 сек 100
Ivcho
Регистриран на: Пет 10 сеп 2004 16:14
Мнениеот Ivcho » Пон 20 дек 2004 17:47
Ей колеги едно еи такова Голфче се разкарва из София с цвят червен и е голяма мания. Онази вечер беше пред технополис в Младост. Имам и снимка даже ще я кача тези дни.
Черноглав
Регистриран на: Сря 09 юни 2004 13:07
Мнениеот Черноглав » Пон 20 дек 2004 20:23
Dic написа:Искам..............искам ........ искам я тази кола!!! bowdown bowdown bowdown
и като я вземеш, кой ше я зарежда?? сигурно е поне 20/100... да не говорим за нитрото... че и то не е без пари..
айде моля ви се.. това е само за по едно кръгче.. :twisted:
точно това е - за събота неделя
то какво да не би и ферари енцо да е кола да ходиш с нея на работа..
