Passat B5.5 2000 - 115 h.p. да разчетем един Log
DoH_KuXoT
Мнениеот DoH_KuXoT » Пон 11 фев 2013 17:22
Monday,11,February,2013,12:53:59:56968
VCDS Version: Beta 12.10.2
Data version: 20121222
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ1P203951 Mileage: 150960km/93802miles
Address 01: Engine Labels: None
Part No: 06B 906 033 G
Component: 2.0L/2V SIMOS32 00HS3680
Coding: 00031
Shop #: WSC 00028
VCID: 244D4BF0B405773ECC5
WVWZZZ3BZ1P203951 VWZ7Z0A3381014
9 Faults Found:
16555 - Fuel Trim; Bank 1
P0171 - 35-00 - System Too Lean
P0171 - 35-10 - System Too Lean - Intermittent
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
16687 - Cylinder 3
P0303 - 35-10 - Misfire Detected - Intermittent
16688 - Cylinder 4
P0304 - 35-10 - Misfire Detected - Intermittent
16686 - Cylinder 2
P0302 - 35-10 - Misfire Detected - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16804 - Catalyst System; Bank 1
P0420 - 35-00 - Efficiency Below Threshold
16515 - Oxygen (Lambda) Sensor B1 S1
P0131 - 35-10 - Signal too Low - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 D
Component: ABS/ESP front D56
Coding: 04275
Shop #: WSC 00028
VCID: 346DBBB004E5E7BE5C5
1 Fault Found:
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - Intermittent
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 J
Component: CLIMATRONIC B5GP 0002
Coding: 17000
Shop #: WSC 00028
VCID: 28555FC0C82D935EE0D
1 Fault Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 C
Component: 08 AIRBAG VW6 04 0004
Coding: 12344
Shop #: WSC 00028
VCID: 37778CBC15930CA6797
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 805
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 05125
Shop #: WSC 00006
VCID: DDBBBE1457EF86F643B
No fault code found.
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: F0E5F7A0B07D1B9EF8D
1 Fault Found:
00778 - Steering Angle Sensor (G85)
49-10 - No Communications - Intermittent
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 0Z Komfortgerбt HLO 0001
Coding: 00259
Shop #: WSC 00028
VCID: 366981B81299F5AE621
Subsystem 1 - Part No: 1C1959801
Component: 0Z Tхrsteuer.FS 0001
Subsystem 2 - Part No: 1C1959802
Component: 0Z Tхrsteuer.BF 0001
Subsystem 3 - Part No: 1C0959811
Component: 0Z Tхrsteuer.HL 0001
Subsystem 4 - Part No: 1C0959812
Component: 0Z Tхrsteuer.HR 0001
2 Faults Found:
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
End ---------------------------------------------------------------------
zfa159
Автомобил: Mitsubishi Outlander + B4 Syncro
Re: Да разчетем един Log на Passat B5.5 2000 - 115h.p.
Мнениеот zfa159 » Пон 11 фев 2013 18:32
1 Fault Found:
37-00 - Faulty
Мотор за управление на клапата за направление на въздуха стъкло/крака.Реално ако тя наистина не работи,както го дава,ще духа или само на стъклото или само на краката,без значение дали си задал стъкло или крака от панела (няма отношение с духането от централните,то ще си е ок). За да се смени,се разглобява половината табло вътре,мотора е на цена между 160 и 250лв чисто нов според това с кой точно номер е (което се вади по рама и т.н.).
1 Fault Found:
Паднал ти е акумулатора или е разкачан - нищо фатално.
1 Fault Found:
Явно имаш ESP...това е датчика,който ти следи ъгъла на волана.Мисля,че беше комплект с лентовия кабел за еърбега ама не съм 100% сигурен (колегите да кажат).В случая ти дава,че въобще няма връзка с него,а не че примерно мери невярно. Ако мери невярно,има ред причини за това (обикновено волана е разместен от шлиците)...ама при теб си дава,че просто няма връзка с датчика.
За другото не мога да помогна напълно компетентно,затова няма да се обаждам :)
dlug
Регистриран на: Вто 10 юли 2007 18:19
Автомобил: Passat B5.5 2003 1.9 TDI
Двигател: AVB
Мнениеот dlug » Пон 11 фев 2013 21:24
zfa159 написа:Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
1 Fault Found:
Явно имаш ESP...това е датчика,който ти следи ъгъла на волана.Мисля,че беше комплект с лентовия кабел за еърбега ама не съм 100% сигурен (колегите да кажат)...
При В5,5 лентовият кабел е в комплект със датчика за положение на волана. За това и струва половин бъбрек. Ето в тази тема съм го разглобил, понеже си нямах работа и имах един прецакан. Грешката при мен беше лентов кабел, с други думи може да се окаже че могат от две такива кутийки да се сглоби една работеща viewtopic.php?f=6&t=345062
