Здравейте колеги от две седмици баща ми е собственик на Пасат Б4 1997 година 1.9tdi 110к.c. Всичко по колата работи но трип компютъра изписва FAIL. Неделя закачих колата към компютъра и резултата е следния:
VAG-COM Version: Release 311.2-N
Chassis Type: 35 - VW Passat B4
Scan: 01,02,03,08,15,25
Address 01 -------------------------------------------------------
Controller: 028 906 021 DT
Component: 1.9l R4 EDC 00SG 0826
Coding: 00002
Shop #: WSC 05314
2 Faults Found:
00741 - Brake Pedal Monitoring
27-00 - Implausible Signal
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111
Component: ABS 5.3 FRONT D11
Coding: 0273004132
Shop #: BB 24303
No fault code found.
Address 08 -------------------------------------------------------
Controller: 1J1 907 044
Component: CLIMATRONIC S 4.0
Coding: 02000
Shop #: WSC 05314
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 3B0 919 860 D
Component: B5-KOMBIINSTR. M73 V02
Coding: 00140
Shop #: WSC 00698
IMMO-IDENTNR: VWZ5Z0T9021162
Address 46 -------------------------------------------------------
Controller: 3B0 959 799 A
Component: Zentral-SG Komfort V41
Coding: 04097
Shop #: WSC 05311
8 Faults Found:
01329 - Convenience System Data Bus in Emergency Mode
35-00 - -
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
01330 - Central Control Module for Central Convenience (J393)
49-10 - No Communications - Intermittent
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
00930 - Locking Module for Central Locking: Rear Left (F222)
00931 - Locking Module for Central Locking: Rear Right (F223)
End -------------------------------------------------------
Изчистих грешките и останаха само две:
P1570 - 35-00 - -
35-00 - -
Възможно ли е да изписва FAIL заради грешка 17978 и как мога да реша проблема ? Имам съмнения че имобилайзера е заобиколен по някакъв начин , но съм отворен за всякакви предложения .
Б5 трип компютъра ми изписва FAIL
bascho
- Регистриран на: Нед 27 яну 2008 13:16
- Автомобил: bmw
- Двигател: 1982
- Местоположение: Usa
Re: Б4 трип компютъра ми изписва FAIL
Четох , че е възможно да е бушон . Не светеха заден десен габарит и стоп. Днес ги смених и проверих всички предпазители в купето и всички са здрави но надписа fail си стои. Когато колата не е на контакт трип компютъра се вижда. Но в момента , в който дам контак изписва fail. Не , че има хиляди отговори но ако някой има идеи да сподели
- pas1.8mi
- Автомобил: Passat B5
- Двигател: 1.8T AEB 1999
Няма да е лошо да хвърлиш едно око на комфорт модула!
bascho
- Автомобил: bmw
- Двигател: 1982
Къде се намира и за какво да го огледам ?
- pas1.8mi
Ако си сигурен,че коментираме Б4,ще се наложи да отвориш корите на вратите и да изключиш буксите от модулите за проба.
П.П B4!
Ако коментираме B5,модула е един, и е под мокета,в краката на шофъорското място!
П.П B4!
bascho
- Автомобил: bmw
- Двигател: 1982
Да колега благодаря за пояснението заглавието на темата беше пасат 4 но модераторите не са го харесали и са го променили. Става въпрос за пасат като този на долната снимка Б5. Идеята ти е да изключа всички букси от комфорт модула и да видя дали няма да изчезне надписа.
- pas1.8mi
Точно така! Изключи двете букси от комфорта и тествай пак с ВАГ-ком!
bascho
- Автомобил: bmw
- Двигател: 1982
Ще пробвам тази събота или неделя и ще пиша какво е станало.
gal4o666
- Регистриран на: Сря 26 окт 2011 23:35
- Местоположение: varna200
Re: Б5 трип компютъра ми изписва FAIL
Здравей колега покарай колата малко и виж как ще е при мен се оправи сама, не бързай да ходиш по "майстори"
- kris11
- Автомобил: VW Sharan 7M8
ОФФ : Aко е със задни ел.стъкла модула е с букси.
Хубаво е да отвориш модула и да го огледаш, както и проводниците и буксите за следи от наводняване,корозия, зеленясване. Слабо място е там.
