на ваг ком ми показва грешка
Address 08: Auto HVAC Labels: 1J1-907-044.LBL
Part No: 1J1 907 044
Component: CLIMATRONIC S 4.0
Coding: 02000
Shop #: WSC 05314
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
35-10 - - - Intermittent
как мога да го оправа ?
Проблем с пасат Б5 АФН
- van4ooo
- Регистриран на: Нед 13 юли 2008 19:16
Re: Проблем с пасат Б5 АФН
Използвай www.google.bg
Possible Causes
Ignition Switch faulty
Wiring between Instrument Cluster (J285) and Climatronic Control (J255) faulty
Instrument Cluster (J285) faulty
Possible Solutions
Check Ignition Switch
Check Wiring between Instrument Cluster (J285) and Climatronic Control (J255)
Check Instrument Cluster (J285)
Check Climatronic Control (J255)
Possible Causes
Possible Solutions
