Пасат 5.5 грешки при диагностика
darkavenger
Регистриран на: Пет 12 апр 2013 15:45
Мнениеот darkavenger » Пет 12 апр 2013 15:58
Friday,12,April,2013,15:06:52:47688
VCDS Version: Release 11.11.4
Address 01: Engine Labels: 038-906-019-AVB.lbl
Control Module Part Number: 038 906 019 EA
Component and/or Version: 1,9l R4 EDC 0000SG 1263
Software Coding: 00002
Work Shop Code: WSC 05311
Additional Info: WVWZZZ3BZ1E222105 VWZ7Z0A3382792
VCID: 5AB7116BC51F79D32D7
3 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-00 -
18027 - Glow Plug Relay (J52)
P1619 - 35-10 - Open or Short to Ground - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
Readiness: 0 0 X X X
Data version: 20120807
Friday,12,April,2013,15:14:06:47688
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ1E222105 Mileage: 181630km/112859miles
Part No: 038 906 019 EA
Component: 1,9l R4 EDC 0000SG 1263
Coding: 00002
Shop #: WSC 05311
3 Faults Found:
P1654 - 35-00 -
P1570 - 35-00 -
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 D
Component: ABS/ESP front D56
Coding: 04255
Shop #: WSC 05311
VCID: 346B9FD3073B6FA3D7B
No fault code found.
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0003
Coding: 17000
Shop #: WSC 05311
VCID: 264F759BC1E70D3359F
6 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
35-10 - - - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
01272 - Positioning Motor for Central Flap (V70)
01273 - Fresh Air Blower (V2)
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01198 - Comfort Data Bus; Incorrect Software Version
35-00 - -
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 B
Component: 0A AIRBAG VW5 04 0006
Coding: 12353
Shop #: WSC 05311
VCID: 366FA5DB11477DB3E9F
1 Fault Found:
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 829 AX
Component: KOMBI+WEGFAHRSP VDO V08
Coding: 00105
Shop #: WSC 00050
VCID: 7CFB77F36FEB67E35FB
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00379
VCID: F0E3D3C3B3A39383733
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 0J Komfortgerát HLO 0002
Coding: 00259
Shop #: WSC 05311
Subsystem 1 - Part No: 1C1959801
Component: 0J Tõrsteuer.FS 0001
Subsystem 2 - Part No: 1C1959802
Component: 01 Tõrsteuer.BF KLO 0004
Subsystem 3 - Part No: 1C0959811
Component: 0J Tõrsteuer.HL 0001
Subsystem 4 - Part No: 1C0959812
Component: 0J Tõrsteuer.HR 0001
4 Faults Found:
01134 - Alarm Horn (H12)
25-10 - Unknown Switch Condition - Intermittent
01330 - Central Control Module for Central Convenience (J393)
37-00 - Faulty
00932 - Electric Window Motor; Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
End ---------------------------------------------------------------------
18062 - Please check DTC Memory of Instrument Cluster P1654 - 35-00 - за тази грешка не мога да намеря информация.
01198 - Comfort Data Bus; Incorrect Software Version 35-00 - - някаква идея на какво се дължи това
грешката за Air bag на какво се дължи ...
Друг проблем който имам е ,че подавам контакт и таблото не "пали" - съответно върти и не пали. Когато поразмърдам ключа едва тогава таблото светва и мога да запаля - предполагам че има проблем в ключалката ... нещо често срещано ли или аз съм изключение ?
dlug
Регистриран на: Вто 10 юли 2007 18:19
Автомобил: Passat B5.5 2003 1.9 TDI
Двигател: AVB
Re: грешки при диагностика на Пасат 5.5
Мнениеот dlug » Съб 13 апр 2013 13:34
darkavenger написа:...
за еърбега това не ти ли помага
http://wiki.ross-tech.com/wiki/index.php/00532
За паленето-най-вероятно клеморед
darkavenger
Re: Пасат 5.5 грешки при диагностика
Мнениеот darkavenger » Пон 15 апр 2013 12:30
паленето се оправи ... ходих на електричар и смени нещо по самата "ключалка" - имало нагоряло/износено ....
интересни са ми грешките за airbag-a и комфорт модула. Съмняваме че е имало удар и са омагьосали airbag контролера, а комфорт модула - стъклата не ми се свалят/вдигат от дистанционното със задържане на бутона заключване/отключване - почвам да си мисля че не работи или го няма ... къде се намира физически - на ауди а4 е в багажника ...
dlug
Двигател: AVB
Мнениеот dlug » Пон 15 апр 2013 16:01
Стъклата не се свалят/вдигат при задържане на бутон от дистанционното. Трябва да задържиш ключа в положение отключено/заключено и тпгава стъклата би трябвало да се свалят/вдигнат. За да работи от бутона трябва да се активира допълнително. Има хора които го правят (например http://www.vwclub.bg/forum/viewtopic.php?f=45&t=340525)
darkavenger
Мнениеот darkavenger » Чет 18 апр 2013 7:16
за комфорт модула разбрах ... мислех че може да стане с VCDS-COM, но явно трябва друг софтуер. Както и да е за прозорците, но той ми записва грешка, а и airback-a също .
dlug
Двигател: AVB
Мнениеот dlug » Чет 18 апр 2013 11:48
Понеже двамата си говорим...пак аз да питам. Записва ти грешка в еърбега, това разбрахме...какво очакваш повече да ти кажем? Провери ли възможните причини за записването на тази грешка? (има ги в по-горното мнение) Ако не си какво точно да направим тук? Ако си-какъв е резултата?
Имаш ли някакви проблеми с работата на комфорт модула? Разбрахме че имаш грешки, вече си ги прочел, изчисти ги и виж какво ще запише пак. Като запише грешка виж възможните причини и ги провери
