Привет колеги. Имам следния проблем на ABS-а:
Address 03: ABS Brakes Labels: 1H0-907-379.lbl
Control Module Part Number: 1H0 907 379 D
Component and/or Version: ABS TEVES 04
Software Coding:
Work Shop Code:
VCID: 3065614050F
4 Faults Found:
00259 - ABS Inlet Valve; Front Right (N99)
35-00 - -
00267 - ABS Outlet Valve; Front Right (N100)
35-00 - -
00276 - ABS Outlet Valve; Left Rear (N136)
35-00 - -
00532 - Supply Voltage B+
35-00 - -
Ако някой може да помогне ще съм му много благодарен.
PASSAT B4 1.6 74kW 1995г. проблем с ABS
