Здравейте,
Колеги пасатора днес успя да запали чак от четвъртия път.
Записа грешка за "16706 - Engine Speed Sensor (G28) P0322 - 35-00 - No Signal", което предполагам е датчик колянов вал.
Направи ми впечатление, че на загрят автомобил и работа на празен ход държи 1200 оборота.
При шофиране с по-високи обороти и ускорение прекъсва.
Някакви идеи освен смяна на датчика?
Ето лога:
Address 01: Engine Labels: 06B-906-018-AWT.lbl
Part No: 4B0 906 018 DC
Component: 1.8L R4/5VT G 0001
Coding: 11501
Shop #: WSC 05311
VCID: 65C10493FF61CFAC90-5178
WVWZZZ3BZ2E098507 VWZ7Z0A3857623
1 Fault Found:
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 1328
Coding: 04275
Shop #: WSC 05311
VCID: 25414493BFE10FAC50-515A
No fault code found.
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 J
Component: CLIMATRONIC B5GP 0003
Coding: 17000
Shop #: WSC 05311
VCID: 285F4DA7C8F312C46B-5196
1 Fault Found:
01272 - Positioning Motor for Central Flap (V70)
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 B
Component: 0A AIRBAG VW51 04 01
Coding: 12353
Shop #: WSC 05311
VCID: 23455A8BB1D5F19C3E-513C
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 B
Component: Lenkradelektronik 0002
Coding: 00008
Shop #: WSC 05311
VCID: 306FA5C7F0235A04B3-5248
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 846
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 23125
Shop #: WSC 00006
VCID: 62CB1F8FEE4FB89475-513C
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05314
VCID: 70EF65C730A31A04F3-513C
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 0J Komfortgerбt HLO 0003
Coding: 00259
Shop #: WSC 05311
VCID: 366393DF12477434E9-4B32
Subsystem 1 - Part No: 1C1959801
Component: 0J Tхrsteuer.FS KLO 0003
Subsystem 2 - Part No: 1C1959802
Component: 0J Tхrsteuer.BF KLO 0002
Subsystem 3 - Part No: 1C0959811
Component: 0J Tхrsteuer.HL KLO 0002
Subsystem 4 - Part No: 1C0959812
Component: 0J Tхrsteuer.HR KLO 0002
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 186 E
Component: Radio BNO 0006
Coding: 05401
Shop #: WSC 05311
VCID: 275D4E9BC5ED1DBC62-4B00
3 Faults Found:
00668 - Supply Voltage Terminal 30
00852 - Loudspeaker(s); Front
36-10 - Open Circuit - Intermittent
00853 - Loudspeaker(s); Rear
36-00 - Open Circuit
End---------------------(Elapsed Time: 04:33, udsna)-----------------------
Passat B5.5 1.8T AWT проблем с палене
- Drakezoid
- Регистриран на: Съб 22 юни 2019 18:55
- Автомобил: Passat B5_5
- Двигател: 1_8Т AWT 2002
Re: Passat B5.5 1.8T AWT проблем с палене
Проблема се разреши след смяна на въпросния датчик. Като, че ли колата стана една идея по-отзивчива и на празен ход почти не претрисва.
Моля ако модератора сметне темата за полезна да я остави. В противен случай моля да я изтрие.
