Здравейте,
Днес докато си карах ми изпищя таблото и почна да мига лампата за ръчната и светнаха лампите за ABS и ESP в жълто.
Пуснах една диагностика и ето го пълния резултат:
Address 01: Engine Labels: 06B-906-018-AWT.lbl
Part No: 4B0 906 018 DC
Component: 1.8L R4/5VT G 0001
Coding: 11501
Shop #: WSC 05311
VCID: 65C10493FF61CFAE80-5178
WVWZZZ3BZ2E098507 VWZ7Z0A3857623
3 Faults Found:
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 35-10 - System too Lean - Intermittent
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
P1103 - 35-10 - Performance too Low - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 1328
Coding: 04275
Shop #: WSC 05311
VCID: 25414493BFE10FAE40-5178
1 Fault Found:
00301 - ABS Return Flow Pump (V39)
35-00 - -
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 J
Component: CLIMATRONIC B5GP 0003
Coding: 17000
Shop #: WSC 05311
VCID: 285F4DA7C8F312C67B-5178
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 B
Component: 0A AIRBAG VW51 04 01
Coding: 12353
Shop #: WSC 05311
VCID: 23455A8BB1D5F19E2E-513C
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 B
Component: Lenkradelektronik 0002
Coding: 00008
Shop #: WSC 05311
VCID: 306FA5C7F0235A06A3-5248
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 846
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 23125
Shop #: WSC 00006
VCID: 62CB1F8FEE4FB89665-513C
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05314
VCID: 70EF65C730A31A06E3-513C
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 0J Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 05311
VCID: 366393DF12477436F9-4B32
Subsystem 1 - Part No: 1C1959801
Component: 0J Tõrsteuer.FS KLO 0003
Subsystem 2 - Part No: 1C1959802
Component: 0J Tõrsteuer.BF KLO 0002
Subsystem 3 - Part No: 1C0959811
Component: 0J Tõrsteuer.HL KLO 0002
Subsystem 4 - Part No: 1C0959812
Component: 0J Tõrsteuer.HR KLO 0002
2 Faults Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
00931 - Locking Module for Central Locking; Rear Right (F223)
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 186 E
Component: Radio BNO 0006
Coding: 05401
Shop #: WSC 05311
VCID: 275D4E9BC5ED1DBE72-4B18
2 Faults Found:
00852 - Loudspeaker(s); Front
36-00 - Open Circuit
00853 - Loudspeaker(s); Rear
End-------------------------(Elapsed Time: 04:31)--------------------------
Като вариант за отстраняване на проблема мисля да почна по описаното тук:
http://wiki.ross-tech.com/wiki/index.php/00301
Изтрих грешките, но пак се появиха.
Някакви съвети от вас за тази конкретно, а и за другите грешки(по-скоро за ламбда сондата и датчика температура).
Благодаря на отзовалите се.
Passat 5.5 1.8T AWT 00301 - ABS Return Flow Pump (V39)
Zdravko Zankov
- Местоположение: Враца
Re: Passat 5.5 1.8T AWT 00301 - ABS Return Flow Pump (V39)
Подозирам, че трябва да смениш блока на ABS системата. Другите грешки не са фатални. Сондата явно е умряла. Виж и волтажа, трябва да играе енергично.
- Drakezoid
- Регистриран на: Съб 22 юни 2019 18:55
- Автомобил: Passat B5_5
- Двигател: 1_8Т AWT 2002
Явно проблема е обсъждан многократно и аз избързах с темата.
Ще изровя някой да оправи тия жички на ABS контролния модул.
Тоя път няма да експериментирам сам.
Поздрави и мерси.
UPD: Свързах се се Влади и се оказа, че на моя пасат ABS модула не е от тези с проблемната алуминиева жичка. Според него нещо се прецаква в самия чип.
След две седмици изведнъж проблема изчезна и повече не се е появявал. Аз залагам на лоша връзка и нещо свързано със влагата във въздуха. Като му дойде времето пролетта ще го гледам.
Поздрави и мерси.
