Торент проблем....
Probing Your Port 57412
The GRC server is attempting to establish a TCP
connection to Port 57412 of your computer located
at Internet at IP address 85.196.***.**:
Total elapsed testing time: 5.029 seconds
Port
Status - Protocol and Application
57412 - Stealth
Unknown Protocol for this port
Unknown Application for this port
Пробвах netsh int ip reset ip_reset.txt
с благодарности на pipi_to
като че ли се вдигна скороста,
от 136 пиъра са кънектнати 17 и от там скороста съкс....
а и продължава да ми е скрит ш***ния порт...
Дайте някакви други препоръки......
Това показа run->cmd->ipconfig/all
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek RTL8139/810x Family Fast
Physical Address. . . . . . . . . : 00-**-1E-17-78-**
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 0.0.0.0
Subnet Mask . . . . . . . . . . . : 0.0.0.0
Default Gateway . . . . . . . . . :
DHCP Server . . . . . . . . . . . : 255.255.***.***
NetBIOS over Tcpip. . . . . . . . : Disabled
PPP Adapter BGLan:
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-**-**-00-00-00
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 85.196.***.**
Subnet Mask . . . . . . . . . . . : 255.255.***.***
Default Gateway . . . . . . . . . : 85.196.***.**
Ако трябва още инфо питайте.....
Потребители, разглеждащи този форум: Няма регистрирани потребители и 80 госта
