В петък пуснах Туарега ми за продажба. Веднага се залепи един Норвежец, който след кратка кореспонденция иска да я купи веднага. Иска да я плати с Пейпал и шипингова фирма да се занимава с оправяне на документи и транспорт до него.
Притеснява ме че съм чел подобни измами в БМВ форума, но те бяха за придобиване на лични данни, а тук случая не е такъв.
Какво мислите по случая?
Ето част от кореспонденцията:
Hi,
Thanks for your mail..I reside in Norway.I'm satisfied with the condition of the car and i do believe you that the condition of the car is exactly what you stated to me...I will agree to you sum of ******Euro for the car,since i am interested in the immediate purchasing...
Do you have a PayPal account for the Payment? I will be paying you through PayPal online money transfer.
Do you still have the original owner receipt that you show that you are rightful owner of the car .I would appreciate if you could send me some Video clips of the car in order for me to confirm its present condition (if available) through Youtube, since i won't be be able to see the car in person.I wish to come and view this car at your place but am out of Bulgaria at the moment....Am a marine engineer busy sailing,am in a ship right now at Tilbury...
I will be making use of a shipping company to have the car picked up in your home address or your nearest port and have it delivered to me after the money is cleared in your PayPal account.Further arrangements will be made with you in concerns to the pick up once you have receive the money..Awaiting your response soon..
Warm Regards,
Mr Carson
P.S:With the issue of a copy of my identification, documents,transferring the name of ownership and signing of all paperworks will be done by the shipper on my behalf so you don't have to worry about that...
Измама при продажба на кола или нормална практика???
- Muncho
- Регистриран на: Чет 07 юли 2005 15:29
Re: Измама при прдажба на кола или нормална практика???
Според мен е измама.. но ако ти се занимава можеш да го попиташ коя е шип(б)инг компанията.. тогава вече ще стане ясно на 99%.
- stefan4o
- Автомобил: VW Jetta
- Двигател: PN 1990
Ползвам пейпал доста време. Честно казано не вярвам някой да успее точно тях да ги измами, респ. да повлече и теб. Защото при оборот над х долара се иска потвърждение на акаунта и се изискват следните документи : валидна шоф.книжка или паспорт (копиран от двете страни), потвърждение от банката, че картата в акаунта ти е твоята и името, което фигурира там е точно твоето, фактура за платена сметка на постоянен адрес, посочен в профила на пейпал.
Може и наистина някой да опитва да те измами по някакъв начин, но пейпал не показва лични данни - той разполага само с твоя и-мейл адрес и нищо повече. Според мен посъбери още мнения и чак тогава направи такава крачка. Не знам каква е сумата на колата, но имай впредвид, че когато той ти преведе парите, една част от тях е за комисионна. Т.е. ако искаш на колата да кажем условно 25 000$, той ще ти ги преведе и вероятно ще посочи опцията от тях да удържат сума за комисионна, която е при мен на 100$ 4.27. Не знам дали при по-големите суми е същата, но ако е така излиза, че от 25 000$ ти реално ще получиш 23932$
Според мен е редно да се вземе и друго впредвид, с което НЕ твърдя, че това не може е измама. Преди години цените на новите коли примерно в Германия и България бяха доста различни, дори фрапиращи (така беше при Мерцедес, понеже съм ги проверявал в оф.представител). Може това да е причината някой да иска да придобие кола, закупена от България, за да му излезе по-тънко. В момента не съм сигурен, след като сме всички в ЕС дали все още е така. Сред нас има колеги, които работят в оф.представители нека и те се изкажат, понеже аз говоря за година да кажем 2000, сега е възможно нещата да не стоят точно така.
Последна промяна от stefan4o на Нед 08 май 2011 11:25, променено общо 1 път.
- my heart iS iCe
Колега, да беше само ти, да кажеш че не е измама, ма то цяла България е залята с такива писма!
Според мен си е чиста измама, но ако ти се рискува пробвай, после сподели!
Северняк да вземе 2-ра ръка и то скъпичка и то точно от частно лице от Източна Европа,нещо само като го чуя,не ми се вярва да е чисто
В представителствата там е пълно с такива нови рефърбиш джипки
Туарегът като гледам е чистак нов,тук ще го грабнат
ПП От КарЛсон който живееше на покрива
- Ivailo
- Регистриран на: Пет 27 апр 2007 15:21
- Автомобил: VW Golf mk3
- Двигател: AAZ
- Местоположение: София/Видин
Все си мисля, че като вземе колата ще пусне един диспут, че "Item is not as described" и в един момент ще осъмнеш хем без кола, хем без пари...
Аз не бих рискувал.
Аз не бих рискувал.
В карайна сметка теб те интересува да си вземеш парите за колата...което при всички положения ще стане преди да си му я пратил....
Трябва ти верифатнат пейпал защото няма да можеш да получиш толкова голяма сума в обикновен пейпал...
Искай му депозит преди да се занимаваш с каквото и да е!
Давай смело...
До колегата по горе-Виждал ли си цените на колите там?
Давай смело...
tdi90 turbo
- Регистриран на: Пон 23 авг 2010 19:32
- Местоположение: Харманли-Осло
аз преди време харесах един мотоциклет в гърция,свързахме се с продавача,всичко наред,вика пращаш парите и изпращам мотора,той в атина викам тръгвам за атина дай ми адрес,и дотам бяха преговорите.даже не си вдигна телефона вече,така че смятам че това при теб е 100% измама
- stefan4o
- Двигател: PN 1990
Само дето пропускаш малката разлика, че ти си бил в ролята на купувач... Ако темата на колегата беше "искам да купя Туарег от Норвегия" тогава и съветите към него щяха да са други.
- Matematiks
- Регистриран на: Вто 27 ное 2007 17:29
ping23 написа:В карайна сметка теб те интересува да си вземеш парите за колата...което при всички положения ще стане преди да си му я пратил....
Давай смело...
Имай предвид че регистрацията на кола в Норвегия-внос от друга държава струва към 8000 евро!!!!Инак цените наистина са доста скъпички
.И все пак си мисля,че ще се появи някой линк към ПейПал скоро,е така между другото в комуникацията!Колите там са скъпи доста като нови!На кола от 15К евро разликата е около 4-5 отгоре сравнено с тук
Обяснимо е при положение че за нощен пазач плащат 30 евро на час
НЕ ОТВАРЯЙ НИКАКЪВ ВУНШЕН ЛИНК КОЙТО ТИ ИЗПРАТИ!
Всъщност щом ще повери докиментацията за оправяне на Транспортната компания,кажи му да им даде и КЕША
и си капитан .Иначе продължи да видим какво ще стане,поствай тука ако имаш питанки-70 иляди глави мислят по добре от една
П.П. абе тия що са се с некви мноо лесни Фамилии-
нещо мирише кораво тая сделка , пък може и да бъркам
- versace
- Регистриран на: Чет 08 дек 2005 19:57
- Автомобил: Ex Touareg present Mercedes ML
- Двигател: 320 CDI 224 Hp
Понеже и аз от самото начало съм скептично настроен, му отговорих че искам плащането да се направи от фирмата, която ще оправя документите и транспорт. Може да ги упълномощи за това. Или лично да дойде в БГ с кеша.
Чакам го да отговори и пак ще пиша какво става.
Принципно ако парите влязат в карта регната в пейпал аз веднага мога да ги изтегля и не виждам тогава как може да ме измами?!
- Matematiks
Не е толкова лесно колкото си мислиш
специално с ПейПал.То с обикновенна Виза може да се направи Чардж Бек на трансакцията до 6 месеца,какво остава за ПП
Просто му кажи:Парата у ръката-да върви играта
това Ти е най-чистата работа
това Ти е най-чистата работа- versace
Matematiks написа:Не е толкова лесно колкото си мислишспециално с ПейПал.То с обикновенна Виза може да се направи Чардж Бек на трансакцията до 6 месеца,какво остава за ПП
Когато към пейпал е вързана дебитна карта и аз кеширам на каса в банката получената сума и имам основание за получаване на сумата (в случая договор за продажба на колата) никой не може да ми направи чардж бек. Тук въобще не мисля за пейпал с кредитна карта.
- Matematiks
Много са тънки тия ралти да знаеш,не случайно Изрелеца ти казава това!
Ще ти кажа и друго-в нито едно онлайн казино или покер където съм работил не може да се плаща с ПП и то не защото не могат да се споразумеят с тях
