Реших да си взема телефон до към 350-360лв. , но предпочитам да е Нокия, не съм фен на самсунг и сони-ериксон. Харесал съм 6230i , E50 5500 Sport, 6300 ,като можеби най се колебая за 6230i, защото другите нямат нищо по-съществено а им искат с по 50-80 лв повече.
П.С. Ако някой скоро е вземал може ли да ми каже предлагат ли хендс-фрий и Карта-Памет в комплекта към цената или.. ?
Коя Нокия ще ми препоръчате..
- maistora_1
- Регистриран на: Пон 01 авг 2005 2:57
- LILO&STICH
- ябълката на раздора
- maistora_1
- maistora_1
случайно попаднах на инфо за батериите на нокиа и за съжаление е50 и 6230 попадат в черната графа...
ето и инфото:
Product Advisory: Nokia BL-5C battery
Dear Nokia Customer,
This is a product advisory for the Nokia-branded BL-5C battery manufactured by Matsushita Battery Industrial Co. Ltd. of Japan between December 2005 and November 2006. This product advisory does not apply to any other Nokia battery.
Nokia has identified that in very rare cases the affected batteries could potentially experience over heating initiated by a short circuit while charging, causing the battery to dislodge. Nokia is working closely with relevant local authorities to investigate this situation.
Nokia has several suppliers for BL-5C batteries that have collectively produced more than 300 million BL-5C batteries. This advisory applies only to the 46 million batteries manufactured by Matsushita between December 2005 and November 2006. There have been approximately 100 incidents of over heating reported globally. No serious injuries or property damage have been reported.
Consumers with a BL-5C battery subject to this advisory should note that all of the approximately 100 incidents have occurred while charging the battery. According to Nokia's knowledge this issue does not affect any other use of the mobile device. Concerned consumers may want to monitor a mobile device while charging that contains a BL-5C battery subject to this product advisory.
While the occurence in the BL-5C batteries produced by Matsushita in the time-period specified is very rare, for consumers wishing to do so, Nokia and Matsushita offer to replace for free any BL-5C battery subject to this product advisory.
The BL-5C batteries which are subject to the product advisory were used with the following Nokia models or separately as accessories:
Nokia 1100, Nokia 1100c, Nokia 1101, Nokia 1108, Nokia 1110, Nokia 1112, Nokia 1255, Nokia 1315, Nokia 1600, Nokia 2112, Nokia 2118, Nokia 2255, Nokia 2272, Nokia 2275, Nokia 2300, Nokia 2300c, Nokia 2310, Nokia 2355, Nokia 2600, Nokia 2610, Nokia 2610b, Nokia 2626, Nokia 3100, Nokia 3105, Nokia 3120, Nokia 3125, Nokia 6030, Nokia 6085, Nokia 6086, Nokia 6108, Nokia 6175i, Nokia 6178i, Nokia 6230, Nokia 6230i, Nokia 6270, Nokia 6600, Nokia 6620, Nokia 6630, Nokia 6631, Nokia 6670, Nokia 6680, Nokia 6681, Nokia 6682, Nokia 6820, Nokia 6822, Nokia 7610, Nokia N70, Nokia N71, Nokia N72, Nokia N91, Nokia E50, Nokia E60
This product advisory applies also to the following accessories:
Nokia Wireless GPS Module LD-1W, Nokia Wireless GPS Module LD-3W
“Nokia” and “BL-5C” are printed on the front of the battery. On the back of the battery, the Nokia mark appears at the top, and the battery identification number (consisting of 26 characters) is found at the bottom. If the battery identification number does not contain 26 characters, it is not subject to this product advisory.
If you are interested to know if your battery is part of this product advisory, please follow the two steps below:
1) Switch off your mobile device and check the battery model. If your battery is not a BL-5C model, you are not included in this product advisory and your product will not be replaced.
2) If your battery is a BL-5C model, remove the battery and check the 26-character identification number from the back of the battery. Enter the identification number in the field below and you will be advised if your battery may be replaced.
http://batteryreplacement.nokia.com/batteryreplacement/en/
ето и инфото:
- LILO&STICH
- Veso101
- Регистриран на: Съб 22 яну 2005 22:55
- Местоположение: Несебър
LILO&STICH написа:и кво сега майсторе,батериите ли са вредни
Your battery is not among those manufactured by Matsushita between December 2005 and November 2006 and your battery will not be replaced.
Thank you for checking your battery.
Смех![]()
Аве Митак, нещо не схванах, явно от влагата ми е омекнал мозъка.
Вредни са я, като ти гръмне до ухото!
- maistora_1
малко сменихме темата на колегат, но ми струва нужно да се знае:
14 август 2007
Най-големият производител на мобилни телефони в света също не остана пощаден от проблеми с дефектни батерии. Nokia направи официално изявление, че определен брой батерии BL-5C, произведени от японската компания Matsushita Battery Industrial в периода от декември 2005 до ноември 2006 година, могат да прегреят по време на зареждане следствие на късо съединение. Nokia има няколко доставчици на BL-5C батерии, които по всяка вероятност са осигурили на компанията повече от 300 милиона броя. Проблемните бройки са 46 милиона, като от тях в световен мащаб са регистрирани около 100 случая на прегряване. Компанията предлага замяна, ако батерията ви BL-5C е някоя от тези 46 милиона. Може да проверите дали това е така, като въведете специалния код, намиращ се на гърба на елемента, на този адрес: www.nokia.com/batteryreplacement . Ще получите новата батерия на посочения от вас адрес, като се задължавате в същия плик да върнете на Nokia старата.
24 август 2007
Както е известно, проблемните батерии, които от Nokia в момента изтеглят от пазара и подменят, са произведени от Matsushita Battery Industrial. Според постигнатото споразумение Matsushita ще покрие всички директни разходи, свързани с подмяната. От информация в списание Forbes става ясно, че инцидентите може да струват доста скъпо на японската компания, тъй като според изчисленията на Nokia рисковите батерии са 46 милиона. Ако средната цена на една батерия е 26 долара, общата стойност за подмяна на батериите ще бъде 1,2 милиарда долара. Лошата новина е, че сумата представлява 28% от прогнозната оперативна печалба на Matsushita за фискалната 2008 г. и е пет пъти по-висока от годишната печалба на компанията от бизнеса с батерии за изминалата фискална година, приключила в края на март. Подмяната на батериите за Nokia ще бъде и най-голямата до момента. Междувременно от Matsushita Electric Industrial заявиха, че цялата операция вероятно ще струва на компанията доста по-малка сума - между 86 и 172 милиона долара. Не забравяйте, че може да проверите дали батерията ви от типа BL-5C попада в дефектната партида, като посетите този адрес и следвате указанията: www.nokia.com/batteryreplacement
14 август 2007
24 август 2007
