Неприятен проблем с шрифтовете на Windows
FELIPE
Регистриран на: Нед 24 апр 2005 19:51
Автомобил: VW Bora 2002
Двигател: ASZ
Местоположение: Асеновград
Мнениеот FELIPE » Нед 02 май 2010 8:15
Преди време бях инсталирал играта Left4Dead,вчера я деинсталирах,но се оказа,че при деинсталация прецаква шрифтовете.
Код: Избери всички
There has been reports of when removing an illegitimate installation of Left 4 Dead (i.e. pirated) the registry containing information of certain fonts gets corrupted/deleted.
The fonts affected are the following:
Tahoma
Courier New
Verdana
Arial
Arial Narrow
Arial Bold
Lucida Console
Trebuched MS
Times New Roman
Marlett
(note: this list may or may not be entirely complete)
The reason your fonts get bold/italic is that your normal versions of these fonts has been corrupted in (well, deleted from) the registry and Windows automatically falls back to the closest in the same family, if any, and therefore your text goes bold or italic - since these weren't effected.
To fix this, you will have to either restore your Windows to a prior state before uninstalling Left 4 Dead, or manually restore your register.
To restore your register you can do the following:
Note: editing the registry is highly risky and may lead to a corrupt/non-functional system. Do this at your own risk.
1. Click "Start" and then "Run"
2. Type regedit.exe and press Run/OK
3. First of all, backup your current registry by going to File -> Export and save it to a safe place, preferably an external thumb drive or something accessible.
4. Navigate through the folder tree to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Wi… NT\CurrentVersion\Fonts
5. Here, you'll need to add a string variable for each font in the list above with the correct font-file in your C:\Windows\Fonts folder. If the variable already exists, check that the filename is correct. An example is the following (in string name -> value):
Tahoma (TrueType) -> tahoma.ttf
Courier New (TrueType) -> cour.ttf
Verdana (TrueType) -> verdana.ttf
Arial (TrueType) -> arial.ttf
Arial Narrow (TrueType) -> arialn.ttf
Arial Bold (TrueType) -> arialbd.ttf
Lucida Console (TrueType) -> lucon.ttf
Trebuched MS (TrueType) -> trebuc.ttf
Times New Roman (TrueType) -> times.ttf
Marlett (TrueType) -> marlett.ttf
6. Exit the register editor and reboot your computer to be sure that the changes has been made. You should now have your normal fonts back.
Ако е възможно някой да ми каже откъде мога да сваля прецаканите шрифтове,най-вече tahoma,какво точно означава"Here, you'll need to add a string variable for each font in the list above with the correct font-file in your C:\Windows\Fonts folder. If the variable already exists, check that the filename is correct. An example is the following (in string name -> value):" и защо след въвеждането на команда regedit в run при мен нищо не се получава,все едно нищо не съм написал.
Знам,че е малко нахално,но не мога да се справя и всяка помощ ще е добре дошла... :bowdown
vwfena
Регистриран на: Пон 04 апр 2005 0:14
Автомобил: VW passat
Двигател: PB 1991
Местоположение: Елин Пелин
Re: Неприятен проблем с шрифтовете на Windows
Мнениеот vwfena » Нед 02 май 2010 15:15
Прикачил съм ти всички шрифтове без Marlett. Разархивираш ги и ги копираш в C:\Windows\founts и си готов.:)
http://dox.bg/files/dw?a=72fedd3724
FELIPE
Двигател: ASZ
Мнениеот FELIPE » Нед 02 май 2010 17:21
Не се получава :banghead:,копирам ги рестартирам и пак същата работа,явно трябва да се редактират регистрите,ама при мен regedit не работи,явно има някаква защита,която не знам как се маха ,да @ба и играта,как може да затрива фонтовете...засега временно съм решил проблема, като я инсталирах отново,но само като я погледна и ми се вдига кръвното :D .
vwfena
Двигател: PB 1991
Мнениеот vwfena » Нед 02 май 2010 17:38
Защо не опиташ след като я деинсталираш да почистиш регистрите с ccleaner или някоя друга подобна и след това провери дали са си така шрифтовете и ако липсват копирай тези които ти пратих.
