Може ли някой да разчете тези грешки?
filipov
Регистриран на: Сря 12 мар 2008 18:10
Мнениеот filipov » Чет 29 юли 2010 16:16
Търся помощ за разчитането им.
Chassis Type: 1K0
Scan: 01 02 03 04 08 09 10 15 16 17 18 19 25 42 44 46 52 56 62 72
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000007862917
Coding: E98B8F2100040F0047120C000000000000097F075C000100000000000000
Shop #: WSC 01324 785 00200
Part No: 2K1 955 119 C
Component: Wischer 231107 021 0501
Coding: 00038805
Shop #: WSC 01324
Part No: 1K0 955 559 AF
Component: RLS 271107 046 0204
Coding: 00209024
Shop #: WSC 01324
2 Faults Found
02399 - Control Circuit for Terminal 30 for Interior Illumination
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00111001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 47
Mileage: 40378 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.75 V
OFF
OFF
OFF
OFF
OFF
00834 - Signal for Activation of Heated Rear Window
Freeze Frame:
Fault Status: 00101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 47
Mileage: 40378 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.80 V
OFF
ON
OFF
OFF
OFF
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 211107F1000425
Coding: EDA07F06000A028002
1 Fault Found
01304 - Radio
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 22
Reset counter: 9
Mileage: 40371 km
Time Indication: 0
Date: 2000.00.00
Time: 19:11:25
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.071 H08 1901
1 Fault Found
03075 - Parallel Parking Assistance Control Module (J791)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Mileage: 37740 km
Temperature: 30.0°C
Voltage: 13.40 V
Voltage: 13.20 V
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 8190020851030C7F2D06840570084FC6F0FC00
Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Shop #: WSC 01324
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
2 Faults Found
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 23
Time Indication: 0
00830 - Convertible Top Control Module (J256)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 7
Mileage: 40378 km
Time Indication: 0
Date: 2000.00.00
Time: 20:16:18
Address 56: Radio
Cannot be reached
ПП Егати грешната кола имам :evil:
