Мнение за VISION-800 3D . Някой пробвал ли е подобна джаджа
silent
Мнениеот silent » Вто 05 яну 2021 16:42
Мини компютър очила 3д реалност..имате ли опит с тази или други подобни ху...вини....
Това е линка за конкретния модел.
https://www.banggood.com/de/VISION-800- ... rehouse=CZ
Vlad777
King of the Road
King of the Road
Re: Мнение за VISION-800 3D . Някой пробвал ли е подобна джаджа
Мнениеот Vlad777 » Вто 05 яну 2021 17:12
Потърсих и намерих това: https://pastebin.com/p6K8pZNr
Не ме впечатлява особено след като прочетох, че резолюцията не е добра, което ще натоварва очите допълнително и че не могат да се ползват 3D апликации на него.
Vision 800 Android 4.4 Glasses
- Running full Android OS, you can go to settings and click on the Android version. You get the "Dessert Tray" easter egg.
- Comes with a 4gb microsd card already installed
- May not come with a mouse depending on who you buy it from. For best results use either a wireless, hardwired, or bluetooth mouse with a browser back button.
- The Google Now app causes the device to lock up, but if you just install and use chrome, that works best.
- The device does come with play store preinstalled, so you can download almost any kind of app onto it.
- The device does not come with an accelerometer, so you can not download even pseudo-vr apps.
- The built-in camera does not have a flash but can take 1080p video and 5 mp photos.
- The screen size is about equivilant to sitting in the back row of a movvie theater...i'll be more specific in a later review.
- There are two modes in this device...normal and 3d. In Normal, both eyes see the same thing, so its much like looking at a flat screen. In 3d, the screen is split in half and each side is stretched out to be the same aspect ratio as the original sides. Basically, each eye sees half the screen. This is useful for side-by-side 3d videos (The sd comes preloaded with 3, all in Chinese)
- It has wifi and bluetooth so you can use this device without needing another phone.
- The full size usb port can take a mouse, keyboard, or a flash drive. The mini USB port however can only work for charging the device and connecting to a computer. Also, when the device is charging, you can not use a wired USB mouse on the other port. You can use a bluetooth mouse however.
thanis
Регистриран на: Пет 21 юли 2017 9:36
Автомобил: Polo 9N
Двигател: BBY 2004
Мнениеот thanis » Вто 05 яну 2021 17:33
Колега за тези пари.... по-добре си ползвай телефона с приставка. Хубави очила за VR са скъпи. Другото е за какво мислиш да ги ползваш. Ако е за игри .... забрави от тези евтините. Най-много да ти докарат главоболие. Ако е за 3D моделиране примерно, може и да станат. Но всичко, което се предполага, че трябва да върви на 24+ FPS динамично тегава работа. Поздрави и успех !
silent
Мнениеот silent » Вто 05 яну 2021 21:21
Ми за кекешлък общо взето питам...обичам новите неща...филмчета..някои леки неангажиращи игри...не съм геймър...интернет...те такива неща нищо сериозно и нищо на всяка цена....от това което е писал влад вероятно не си струва парите...
