polo 1.2tdi 6R 2012г- егр и airbag грешки
Sweet
Регистриран на: Чет 31 яну 2019 2:22
Мнениеот Sweet » Съб 25 сеп 2021 23:25
Здравейте колеги,
след закачане на колата(polo 1.2 tdi 2012) на диагностика, в Engine модула излизат следните грешки:
Код: Избери всички
Sunday,19,September,2021,14:41:33:49356
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.12.0.1
Data version: 20201209 DS322.1
www.Ross-Tech.com
VIN: WVWZZZ6RZCY248415   License Plate:
                Address 01: Engine       Labels: 03P-906-021-CFW.clb
Control Module Part Number: 03P 906 021 B    HW: 03P 907 425
  Component and/or Version: R3 1.2l TDI   H07 9978
           Software Coding: 00114014032401080000
            Work Shop Code: WSC 51399 002 104857
              ASAM Dataset: EV_ECM12TDI03103P906021B 001041 (VW25)
                       ROD: EV_ECM12TDI03103P906021AA.rod
                      VCID: 27E8CA88FB4A7D5FFE-8072
3 Faults Found:
15536 - EGR Sensor 1
          P0405 00 [191] - Signal too Low
          MIL ON - Confirmed - Not Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Mileage: 158326 km
                    Date: 2105.14.00
                    Time: 23:48:11
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 84 °C
                    Intake air temperature: 54 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 12.234 V
                    Unlearning counter according OBD: 50
                    Sensor for engine block temperature: raw value: 84 °C
                    EGR Vacuum Regulator Solen.val.: activation-PWM rate: 0.0 %
                    EGR Solen.val.: actual value-PWM rate: 50.2 %
                    EGR valve: offset closed: 0 %
                    High press EGR actuator: actual unconditioned volt val: 0.667 V
16128 - Output for Starter Relay
          P0615 00 [088] - Open Circuit
          Intermittent - Confirmed - Not Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 161467 km
                    Date: 2105.14.31
                    Time: 08:44:52
                    Coolant temperature: 96 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 12.453 V
                    Accelerator pedal travel-Position: 0.0 %
                    Starter control: Interlock- or P/N-signal: 00000001
                    Engine status: Engine cranking
                    Terminal 87 status: On
                    Sensor for engine block temperature: raw value: 96 °C
                    Starter control: terminal 50: 00000000
                    Gear Ratio: 0
16131 - Control Circuit for Starter Relay 2
          P3049 00 [088] - Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 161467 km
                    Date: 2105.14.31
                    Time: 08:44:52
                    Gear Ratio: 0
Readiness: 1 1 0 0 0
При управление на автомобила не се усещат забивания и придърпвания.
Също така излиза грешка в airbeg модула:
Код: Избери всички
1 Fault Found:
9445417 - Key switch for deactivation of passenger-side airbag
B1020 29 [136] - Signal Implausible
MIL ON - intermittent-Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 155332 km
Date: 2021.07.26
Time: 13:02:55
След изтриване на грешката за airbag-a след минути тя се появява отново. След като завъртях ключът, който се намира в жабката,на позиция OFF, лампата за airbeg-a спря да свети. Та затова си мисля, че е проблем в това копче. А вие как мислите?
Има ли някой запознат какъв е този сензор на ерг-а?
