Един напълно завършен проект ... Поне 200+ кончета в този 2332cc красавец.
За повече инфо - http://www.bergmannvw.net
2332cc Complete new engine with ceramic coated heater boxes and Dee Engineering Inc. (Bugpack) Mondo Exhaust, external oil cooler kit, KEP CLUTCH STAGE II, primer oil pump and slightly modified chrome stock enclosure tin. This Bernie Bergmann engine was ordered by Troy and Juliet Hughes Kansas City, MO 64154. Mr. Hughes provided the custom engine paint and will install it in a 1973 Ghia. Just look at the huge space between the carbs/manifolds and the fan housing. Notice the spherical bearings supporting the carbs linkage cross bar. Equipped with HYDRAULIC LIFTERS means Mr. Hughes will never, never, never, have to adjust the valves again. This engine will be a real performer and a pleasure to drive. Very little maintenance, just change oil and filter, keep an eye on the fan belt tension and install new sparkplugs every 30,000 miles.
2332cc от bergmannvw
