Спецификация на T1 турбо мотори-2165cc/240hp и 2275cc/280hp
nik1302
Регистриран на: Нед 01 мар 2009 11:17
Местоположение: Varna
Мнениеот nik1302 » Вто 18 яну 2011 23:43
Source -> REPLICAR HELLAS
http://www.replicarhellas.com/
AIRCOOLED VW T1 TURBO ENGINES
2165cc Twin Port 240HP/2275cc 280HP
SPECIFICATION
Crankcase:
New VW case. The cylinder head studs are replaced with
cromoly ones. The case is opened up for large 90.5mm or
94mm cylinders and coated with silver heat resistant paint.
New bearings, gaskets & seals are fitted plus all cases are
fitted with the late, large oil pickup pipe.
Cylinder Head:
Brand new ported and polished 044 magnum plus cylinder
heads with large 42X37.5 valves fitted. All are tested after
assembly to check for valve/seat seal integrity.
Crankshafts:
New CB forged counterweighted 78.4mm/82mm crankshaft
with HD gland nut. New camshaft drive gears are fitted.
The brass distributor drive gears are re-shaved to mesh
correctly with distributor drive shaft after case half
machining.
Connecting Rods:
New CB Performance H-beam 5.4/5.5in con rods with ARP
bolts.
Camshafts & Valve train:
The engine is fitted with an Engle TCS-20/30 camshaft with
new adjustable cam wheel, new 28mm HD lifters, new
Manton cromoly pushrods and HD rocker shafts.
Barrels & Pistons
New Mahle forged 90.5mm. Compression ratio 8.0:1
Oil Pumps - Coolers:
All engines are fitted with brand new HD 30mm gear Shadek oil pumps and drilled for full flow. Bugpack oil cooler
with fan is fitted with the engines along with an extra deep sump.
Flywheels – clutch:
200mm 12.5lbs lightened OEM flywheel with clutch & pressure plate surfaces reground to O.E. depth. The ring gear is
replaced if required and the dowel pin holes are repaired if required. Or the flywheel is replaced. Fitted with new HD
Kennedy 2100lbs pressure plate with a CB centre force clutch disc and new release bearing.
Distributor:
A new locked 009 distributor with Petronix I electronic ignition is fitted to all engines and the ignition timing is set
during testing.
Turbo-Carburators:
CB Performance turbo injection kit with water injection for the 2275cc/280HP.
А ето и спецификацията на нещо малко "по-скромно" (от същата фирма).
1915cc Twin Port 180HP
SPECIFICATION
Crankcase:
cromoly ones. The case is opened up for large 94mm
cylinders and coated with silver heat resistant paint. New
bearings, gaskets & seals are fitted plus all cases are fitted
Cylinder Head:
Crankshafts:
New forged counterweighted 69mm crankshaft with HD
gland nut. New camshaft drive gears are fitted. The brass
distributor drive gears are re-shaved to mesh correctly
with distributor drive shaft after case half machining.
Connecting Rods:
New CB Performance H-beam 5.4in con rods with ARP
bolts.
The engine is fitted with an Engle TCS-20 294° camshaft
with new adjustable cam wheel, new 28mm HD lifters, new
Barrels & Pistons
New Mahle forged 90.5mm. Compression ratio 7.5:1
Flywheels – clutch:
Kennedy 1700lbs pressure plate with Kush-Lock Clutch Disc and new release bearing.
Distributor:
during testing.
Turbo-Carburators:
AJ. Sims under the deck lid 1600T turbo kit with 1 3/8in header, T3 turbo and Holley 350cfm carburettor or side draft
carburettor.
daka
Регистриран на: Съб 07 юни 2008 22:55
Местоположение: Исперих
Re: Спецификация на T1 турбо мотори-2165cc/240hp и 2275cc/280hp
Мнениеот daka » Сря 19 яну 2011 18:52
Ех и ако знаех английски........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................ ооооо забравих то туй май беше
е български форум.
BuGmaN
Мнениеот BuGmaN » Чет 20 яну 2011 1:11
А така - каза го! :mrgreen: И аз си го мислех, ама щот си мисля, че само моя английски куца - та не се обаждам. Сага, след, като сме поне 2-ма бих помолил Неки, ако иска да е полезен да прави някакви преводи или поне коментар, то техническите данни са ясни, след като чета по темата над 10г., но на мен, обаче на повечето, камо ли начинаещите - едва ли... :beer С подобни информаций, особенно от моя архив мога да задръстя форума, но не го правя защото нямам време да превеждам и пиша всичко, а иначе ми се струва безмисленно... :)
jaro89
Регистриран на: Вто 02 ное 2010 22:48
Местоположение: varna
Мнениеот jaro89 » Чет 20 яну 2011 22:35
абе хора влизате в гугъл преводач и ще си обясните нещата
BuGmaN
Мнениеот BuGmaN » Чет 20 яну 2011 22:55
На мен мама и тати ми забраняват да ползвам гугал - би ли ми ги обяснил нещата - поне с 2 приказки? :D
asentm
airman
Мнениеот asentm » Пет 21 яну 2011 6:35
тези теми скоро ще ги сложа н графа ФАНТАСТИКА
моля спазвайте равилата на форума и пишете на БЪЛГАРСКИ :deal
