Помощ за следните грешки на VW Golf 1.6 AKL
wargod
Регистриран на: Съб 12 яну 2013 16:29
Автомобил: VW Golf IV
Двигател: 1600 AKL - 2000
Местоположение: Бургас <-> София
Мнениеот wargod » Съб 15 фев 2014 18:28
Здравейте, колеги. При компютърна диагностика ми излизат следните грешки:
Address 01: Engine Labels: 06A-906-019-AEH.lbl
Part No: 06A 906 019 BQ
Component: 1.6l 2V/R4 SIMOS HS3120
Coding: 00031
Shop #: WSC 01317
VCID: 73EFC11541AE091
2 Faults Found:
01177 - Engine Control Unit
37-10 - Faulty - Intermittent
00668 - Supply Voltage Terminal 30
36-00 - Open Circuit
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 01317
VCID: 3E7920213A6C949
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 02 AIRBAG VW5 0004
Coding: 12338
Shop #: WSC 01317
VCID: 356B3F0D0F5A571
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 801 B
Component: KOMBI+WEGFAHRS. BOO V28
Coding: 01143
Shop #: WSC 00000
VCID: 2143FB5DABD2CB1
Subsystem 1 - Part No: Ident
Component: Nr. WEGFAHRS.:VWZ6Z0Y1726663
Ident.-Nr. WEGFAHRS.:VWZ6Z0Y1726663
1 Fault Found:
01314 - Engine Control Module
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01317
VCID: F0E54E19B0B8B29
1 Fault Found:
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 Q
Component: 4C Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 01317
VCID: 4C9D7AE97CD0369
Subsystem 1 - Part No: 1J1959801C
Component: 4C Tхrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 4C Tхrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 4C Tхrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 4C Tхrsteuerger. HR0002r
2 Faults Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
00935 - Electric Window Motor; Rear Right (V27)
35-10 - - - Intermittent
End ---------------------------------------------------------------------
Четох доста неща в интернет, но не намирам точни решения. Някой ако може да помогне, ще съм много благодарен!
Благодаря Ви предварително! :)
wargod
Re: Помощ за следните грешки на VW Golf 1.6 AKL
Мнениеот wargod » Съб 15 фев 2014 18:32
Последните две грешки са ясни и ще бъдат отстранени, но другите не мога да ги разбера (или по-точно не намирам проблем... )
gogii
Регистриран на: Вто 28 авг 2012 13:46
Местоположение: Shumen
Мнениеот gogii » Съб 05 апр 2014 14:54
До колкото разбирам имаш проблем с електронния блок за управление или така наречения компютъра на колата. Намери някой като твоята кола и пробвай какво ще стане.
mincho_pz
Регистриран на: Вто 19 юни 2012 15:19
Местоположение: Pazardjik
Мнениеот mincho_pz » Нед 11 май 2014 21:02
Колега разбра ли какво означават грешките на двигателя?
Pet_rov
Автомобил: Passat Variant B4
Двигател: ADZ 1996
Мнениеот Pet_rov » Пон 12 май 2014 16:14
Когато имах проблем с отпаднал + на имобилайзера, също нямаше достъп до компютъра на колата - един път се чете, един път не. Единият майстор ми каза, че К линията минавала оттам и затова се получавало така. Колко е вярно, не знам. Успех с ремонта.
dedicha
Регистриран на: Чет 07 май 2009 23:29
Автомобил: Toledo2 Leon3 VW Golf 4
Двигател: 101HP 115HP TSI 115HP FSI
Мнениеот dedicha » Съб 25 мар 2017 21:50
Колеги , и аз имам следната грешка откато се помня:
Някой намерил ли е решение?
Смяна на Еку-то?
И моя комп и мотор са точно същите -
06А-906-019АL-,мотор AEH
Бих пробвал с ново Еку ако се наложи или с ремонт?
Но за друго Еку трябва адаптация до колкото знам
А ремонт на еку в софия някой да знае?
