VCDS разчитане на кодове
Silence
Регистриран на: Сря 20 ное 2013 12:46
Мнениеот Silence » Вто 25 ное 2014 12:51
Здравейте.Ако може някой който разбира да се изкаже,за следните данни от VCDS сканирането на моят автомобил.
Благодаря Ви.
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
7D-Aux. Heat -- Status: Malfunction 0010
Address 01 Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 EM HW: 03G 906 018 EM
Component: R4 2.0l PPD1.2 G 4369
Revision: --H32--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00325 219 87267
VCID: 74E73A5B174EF4BE80B-8021
1 Fault Found:
000665 - Boost Pressure Regulation
P0299 - 006 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 18
Mileage: 127571 km
Time Indication: 0
Date: 2014.11.11
Time: 14:17:58
Freeze Frame:
RPM: 2336 /min
Torque: 344.0 Nm
Speed: 105.0 km/h
91.26 %
Voltage: 14.35 V
Pressure: 2492.1 mbar
Pressure: 2044.8 mbar
Readiness: N/A
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 P HW: 3C0 614 095 P
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0668008796
Coding: 0013626
Shop #: WSC 05311 000 00000
VCID: 2F6DF537BEE897663D9-807A
No fault code found.
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 67DD5D1756980F26359-8032
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000006231523
Coding: E1888F0700041A00000A00000F00000000095D435C0000
VCID: 306FF64BA3D6889E243-8065
Subsystem 1 - Part No: 3C1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 05311
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 280906 014 1201
Coding: 00208933
Shop #: WSC 05311
1 Fault Found:
01800 - Light Switch (E1)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 14
Reset counter: 247
Mileage: 119328 km
Time Indication: 0
Date: 2012.05.03
Time: 19:50:00
Freeze Frame:
OFF
Voltage: 13.00 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
Component: Lenksдulenmodul 006 0010
Revision: 00006000 Serial number: 3C9953507C
Coding: 0000014
VCID: 2A5BE423850AF24EEA7-807F
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 HW: 3C0 920 871
Component: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 80093 222 69422
VCID: E1C9C30F38BCF1167BD-80B4
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C06921026F
Coding: 3DFD2C44C62002
VCID: 2149030FF83C3116BBD-8074
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 00325 219 42878
VCID: 3979CB6F70AC49D693D-806C
Subsystem 1 - Part No: 3C0 905 861 F
Component: ELV 026 0380
3C0905861F ELV 026 0380
1 Fault Found:
01176 - Key
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 252
Mileage: 118359 km
Time Indication: 0
Date: 2012.03.14
Time: 19:42:07
Address 37: Navigation Labels: 1K0-035-191.lbl
Part No SW: 1K0 035 191 D HW: 1K0 035 191 D
Component: J401 0206
Revision: 00016000 Serial number: VWZ1Z2F6414615
Coding: 0043400
Shop #: WSC 05314 000 00000
VCID: 23450907E2202306A91-8076
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1123
Revision: 12007001 Serial number: 00000073768930
Coding: 0000181
VCID: 3B75D1677A907BC6811-806E
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.135 H07 1806
Shop #: WSC 02069 000 90108
VCID: 3467FA5B57CEB4BE40B-8061
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 042 0472
Coding: 0091020051030E763004941570084F0E707C00
Shop #: WSC 00325 219 91308
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 188
Reset counter: 80
Mileage: 118359 km
Time Indication: 0
Date: 2012.03.18
Time: 00:01:17
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1123
Revision: 12007001 Serial number: 00000109868927
Coding: 0000180
VCID: 3C77D27B7F9E7CFE88B-8069
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000011
Address 56: Radio Labels: 1K0-035-191.lbl
Component: R 0206
Coding: 0043400
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1114
Revision: 11005001 Serial number: 00000000678083
Coding: 0000144
VCID: 3D71DF7F648475F6BF5-8068
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1114
Revision: 11005001 Serial number: 00000000684362
Coding: 0000144
VCID: 3E73D87369826EEEA6F-806B
Address 77: Telephone Labels: 3C0-035-729.lbl
Part No SW: 3C0 035 729 E HW: 3C0 035 729 E
Component: Telefon 6009
Revision: 00009000 Serial number: 0000000792820
Coding: 0016043
VCID: 2541171FEC14DD36C75-8070
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 29
Mileage: 127745 km
Time Indication: 0
Date: 2014.11.25
Time: 10:54:59
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D51EF3FB4E4E5760F5-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End
