Голф 5 Auxiliary Heater
nikola.hristow
Регистриран на: Чет 21 яну 2016 21:03
Мнениеот nikola.hristow » Пон 19 сеп 2016 8:20
След диагностика ми излязоха няколко грешки с който не се справям.Колата е Голф 5 , моля някой който е по на ти с нещата от мен да помогне за тяхното отстраняване.
Thursday,15,September,2016,16:34:04:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
VIN: WVWZZZ1KZ7B068768 License Plate:
Mileage: 161740km-100500mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WVWZZZ1KZ7B068768 Mileage: 161740km-100500miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 KK HW: 03G 906 021 KK
Component: R4 2,0L EDC G200SG 9183
Revision: --H05--- Serial number: VWZ7Z0F7137241
Coding: 0000072
Shop #: WSC 00046 000 32768
VCID: 72F3CC83F4AFD49219143CD-8026
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
Shop #: WSC 00046 000 16384
VCID: 73FDC9878BB5DD9A12E2211-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BH HW: 1K0 907 044 BH
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6ECBD8F3E097F072FD2C68D-803A
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004288161
Coding: F4090E07010415191E1400001400000000097B075C
Shop #: WSC 00046 123 24576
VCID: 2A4314E31CFFDC5261C404D-807E
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 220906 020 0501
Coding: 00038805
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 150906 014 1201
Coding: 00471077
Shop #: WSC 00046
1 Fault Found:
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 32
Reset counter: 77
Mileage: 161743 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.35 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0S9V7
Coding: 0013111
Shop #: WSC 00046 412 139264
VCID: 3D692FBFFD715BEA3406779-8068
Subsystem 1 - Serial number: 6332MSME12786E02B
Subsystem 2 - Serial number: 6342MSME0F685B4AV
Subsystem 3 - Serial number: 6352QSME141A3F13F
Subsystem 4 - Serial number: 6362QSME14014045/
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 636 0070
Coding: 0000042
VCID: 74FFCA9B8EBBDAA20BE82A5-8020
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 863 B HW: 1K0 920 863 B
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0F7137241
Coding: 0003103
Shop #: WSC 00011 888 96745
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001069098355
Coding: 3D0F0B4007000000
Shop #: WSC 00046 123 16384
VCID: 2C4F12FB160BC26293D8325-8078
2 Faults Found:
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 77
Mileage: 161745 km
Time Indication: 0
Date: 2000.00.00
Time: 16:31:40
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 77
Mileage: 161745 km
Time Indication: 0
Date: 2000.00.00
Time: 16:31:44
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1610
Последно избутана от nikola.hristow на Пон 19 сеп 2016 8:20.
Потребители, разглеждащи този форум: milench0 и 36 госта
