Голф 5 2.0 170к.с нужда от помощ за грешките коя от какво е
Heroi
Регистриран на: Чет 12 сеп 2013 17:12
Мнениеот Heroi » Пет 04 ное 2016 13:22
Може ли някой да ми помогне за грешките коя от какво е. 1вата ясна дюза на 3ти цилиндър .Възможно ли е от слаб акумулатор да ми дава някой от грешките тъй като всички крушки ми светят а дава че 8 от тях са изгорели ?
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 CT HW: 03G 906 018 G
Component: R4 2.0l PPD1.2 4343
Revision: --H22--- Serial number: VWZ7Z0F8003246
Coding: 0000072
Shop #: WSC 02359 264 93771
VCID: 79F38611303C86E9285-802C
1 Fault Found:
004710 - PD Unit Injector: Cylinder 3 (N242)
P1266 - 006 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 4
Reset counter: 40
Mileage: 187794 km
Time Indication: 0
Date: 2000.00.00
Time: 15:07:19
Freeze Frame:
RPM: 2144 /min
Torque: 0.0 Nm
Speed: 20.0 km/h
38.22 %
Text: 5.375 uF
Time: 0.00 ms
Text: 0.00 mJ
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
Shop #: WSC 00028 028 00001
VCID: 73EFB4391250FCB9629-8026
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BH HW: 1K0 907 044 BH
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6ED9A54D7972D1518D7-803B
1 Fault Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
000 - -
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004163040
Coding: 01890F2700041500001400001400000000097F075C
VCID: 2B5F6C598AE0E479EA9-807E
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 230506 020 0501
Coding: 00038805
Shop #: WSC 00028
8 Faults Found:
01501 - Bulb for Blinkers; Rear Left (M6)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 23
Mileage: 187751 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.90 V
ON
ON
OFF
OFF
ON
01505 - Bulb for Blinkers; Rear Right (M8)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 187751 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.90 V
ON
ON
OFF
OFF
ON
00987 - Lamp for Brake Light; Left (M9)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 23
Mileage: 187751 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.00 V
ON
ON
OFF
OFF
OFF
00988 - Lamp for Brake Light; Right (M10)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 23
Mileage: 187751 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
01504 - Bulb for License-Plate Light (X)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 187751 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.90 V
ON
ON
OFF
OFF
ON
00984 - Left Tail Light (M4)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 23
Mileage: 187751 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.90 V
ON
ON
OFF
OFF
ON
00985 - Right Tail Light (M2)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 187751 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.90 V
ON
ON
OFF
OFF
ON
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 6
Reset counter: 42
Mileage: 187765 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 10.30 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0J4PZ3
Coding: 0013111
VCID: 3D7B520164947AC944D-8068
Subsystem 1 - Serial number: 6332MSME0E7E4459S
Subsystem 2 - Serial number: 6342MSME0E585C0CS
Subsystem 3 - Serial number: 6352QSME0F704431B
Subsystem 4 - Serial number: 6362QSME0F62544DR
1 Fault Found:
00532 - Supply Voltage B+
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 873 B HW: 1K0 920 873 B
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0F8003246
Coding: 0003103
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 187765 km
Time Indication: 0
Date: 2000.00.00
Time: 10:08:42
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 009002005103087F2D04840560084F01E0FC00
VCID: 030FE4F942F0CC39729-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00896 - Trunk Lock Unit (F256)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 2
Reset counter: 42
Mileage: 187751 km
Time Indication: 0
Date: 2000.00.00
Time: 15:04:54
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 R
Component: Radio GR0 019 0023
Revision: 0001905S Serial number: VWZ2Z2F1210163
Coding: 0040400
VCID: 356B4A215CA4A2898CD-8060
1 Fault Found:
