Голф 5 1.6 102hp резултати от диагностика.
Радослав.Панков
Регистриран на: Чет 13 апр 2017 18:24
Мнениеот Радослав.Панков » Нед 04 юни 2017 15:05
Привет на всички колеги :)
Може ли да ми помогнете с резултатите от диагностиката. 1-2 от грешките разбирам ама останалата част си нямам ни най малка представа.
Saturday,03,June,2017,14:16:59:07094
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.3.0
Data version: 20151216
www.Ross-Tech.com
VIN: WVWZZZ1KZ7B077105 License Plate: RADO
Mileage: 167000km-103768mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ1KZ7B077105 Mileage: 167000km-103768miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Not registered 0011
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 EM
Component: SIMOS71 1.6l 2V 9428
Revision: --H03--- Serial number: VWZ7Z0F8147462
Coding: 0000071
Shop #: WSC 00046 412 196608
VCID: 6E4B43FEC71EC5DC3D-803A
No fault code found.
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0019073
Shop #: WSC 00046 412 491520
VCID: 73543DEFFB05273905-8026
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 FH
Component: Climatic PQ35 120 0606
Shop #: WSC 00000 000 00000
VCID: 6F4845FBCB11CFD525-803A
1 Fault Found:
00457 - Control Module for Network (J519)
013 - Check DTC Memory
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004428693
Coding: 098D0F2700041500001400001400000000097F075C
Shop #: WSC 00046 412 245760
VCID: 2B0CCDB7DBAD573145-807E
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 091006 020 0501
Coding: 00038805
Shop #: WSC 00046
1 Fault Found:
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 2
Reset counter: 251
Mileage: 152674 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0SWAXN
Coding: 0013111
VCID: 3D1AA141830BFBB7B5-8068
Subsystem 1 - Serial number: 6332MSME12214241V
Subsystem 2 - Serial number: 6342MSME136B0B48G
Subsystem 3 - Serial number: 6352QSME140B456BJ
Subsystem 4 - Serial number: 6362QSME143136499
1 Fault Found:
00532 - Supply Voltage B+
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BB HW: 1K0 953 549 BB
Component: Lenksäulenmodul 036 0070
Coding: 0000002
Shop #: WSC 00046 412 32768
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 853 G HW: 1K0 920 853 G
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0F8147462
Coding: 0003103
Shop #: WSC 44314 888 96745
VCID: 2E0BC3BEC7DE451C3D-807A
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 15
Mileage: 166383 km
Time Indication: 0
Date: 2000.00.00
Time: 18:04:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 15
Mileage: 166383 km
Time Indication: 0
Date: 2000.00.00
Time: 18:04:59
00771 - Fuel Level Sensor (G)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001069268692
Coding: 3D0F030007000000
VCID: 2C0DCFB4DFA0512E4D-8078
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 194
Mileage: 151074 km
Time Indication: 0
Date: 2000.00.00
Time: 11:51:50
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1610
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0961
Coding: 0000052
VCID: 3811B750EFEC995AED-806C
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.068 H07 1806
Shop #: WSC 02069 000 90108
VCID: 3415BFACFFF8A1760D-8060
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 00C802087F2D8405484A01E010CC
VCID: 78513790EF2C191AED-802C
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000052
VCID: 391EA95D93E78353D5-806C
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
012 - Electrical Fault in Circuit
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 AF
Component: Radio GR0 036 0034
Revision: 0003606S Serial number: VWZ2Z2J1262144
Coding: 0010400
VCID: 6A4F4BCAD7EAEDF85D-803E
2 Faults Found:
01042 - Control Module; Not Coded
000 - -
End-------------------------(Elapsed Time: 01:22)--------------------------
Това е всичко коеъо ми показа вчера диагностиката. Тема в която съм описъл проблема е - viewtopic.php?p=4553715#p4553715
Благодаря предварително.
ivan_pop
Автомобил: OVB
Двигател: X18XE1
Re: Голф 5 1.6 102hp резултати от диагностика.
Мнениеот ivan_pop » Нед 04 юни 2017 19:09
Кое точно не е ясно?
Тук всичко си пише!
http://www.ross-tech.com/
Vasseto
Двигател: CFFB AVF BXE
Мнениеот Vasseto » Нед 04 юни 2017 19:23
