Здравейте вчера сутрин като запалих колата започна да мига check engine light и двигателят не работеше равномерно (оставих го докато паднаха оборотите, тогава спря да мига на колата все още не работеше нормално) . Реших да не карам колата за да не нанеса повече повреди. Имам диагностичен кабел и отдолу прилагам грешката. Моля за съвет, благодаря.
Address 01: Engine Labels: 03C-906-032-BLG.lbl
Control Module Part Number: 03C 906 032 F HW: 03C 906 032
Component and/or Version: MED17.5.1 G 6460
Software Coding: 0000072
Work Shop Code: WSC 00384 264 82313
VCID: 204F5682F3C3E54438-8074
3 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 159683 km
Time Indication: 0
Date: 2000.00.00
Time: 22:21:11
Freeze Frame:
RPM: 1266 /min
Load: 40.4 %
Speed: 0.0 km/h
Temperature: 2.0°C
Temperature: -4.0°C
Absolute Pres.: 960.0 mbar
Voltage: 14.605 V
000771 - Cylinder 3
P0303 - 000 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 159683 km
Time Indication: 0
Date: 2000.00.00
Time: 22:21:11
Freeze Frame:
RPM: 1266 /min
Load: 40.4 %
Speed: 0.0 km/h
Temperature: 2.0°C
Temperature: -4.0°C
Voltage: 14.605 V
000772 - Cylinder 4
P0304 - 000 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 159683 km
Time Indication: 0
Date: 2000.00.00
Time: 22:21:11
Freeze Frame:
RPM: 1266 /min
Load: 40.4 %
Speed: 0.0 km/h
Temperature: 2.0°C
Temperature: -4.0°C
Voltage: 14.605 V
Readiness: 0000 0000
Touran 1T 2007 BMY - check engine light премигва
